I have Arduino UNO and i found some diy game joystick tutorial on YT
code:
// Arduino pin numbers
const int SW_pin = 2; // digital pin connected to switch output
const int X_pin = 14; // analog pin connected to X output
const int Y_pin = 15; // analog pin connected to Y output
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
Use code tags (the < CODE/ > icon above the compose window) to make it easier to read and copy for examination
@tikulik - Try this simulation. It has your code, and you can save it and change it as you feel. Press the green > button, then mouse-click on the four joystick directions.
