My lcd display not showing anything
im doing an energy meter that i saw from the internet and i follow the right step.i'm clueless as to how does the lcd display doesnt display.Please share some insights
the code
// Set the LCD address to 0x27 for a 16 chars and 2 line display
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define BLYNK_PRINT Serial
#include "EmonLib.h"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
EnergyMonitor emon;
#define vCalibration 83.3
#define currCalibration 0.50
BlynkTimer timer;
char auth[] = "apYc_VS8FMFL6SWw5TMM4HXZRWN4ee4p";
char ssid[] = "Omar";
char pass[] = "password";
float kWh = 0;
unsigned long lastmillis = millis();
void myTimerEvent()
  emon.calcVI(20, 2000);
  kWh = kWh + emon.apparentPower * (millis() - lastmillis) / 3600000000.0;
  yield();
  Serial.print("Vrms: ");
  Serial.print(emon.Vrms, 2);
  Serial.print("V");
  Serial.print("\tIrms: ");
  Serial.print(emon.Irms, 4);
  Serial.print("A");
  Serial.print("\tPower: ");
  Serial.print(emon.apparentPower, 4);
  Serial.print("W");
  Serial.print("\tkWh: ");
  Serial.print(kWh, 5);
  Serial.println("kWh");
  lcd.clear();
  lcd.setCursor(0, 0);
  lcd.print("Vrms:");
  lcd.print(emon.Vrms, 2);
  lcd.print("V");
  lcd.setCursor(0, 1);
  lcd.print("Irms:");
  lcd.print(emon.Irms, 4);
  lcd.print("A");
  delay(2500);
  lcd.clear();
  lcd.print("Power:");
  lcd.print(emon.apparentPower, 4);
  lcd.print("W");
  lcd.print("kWh:");
  lcd.print(kWh, 4);
  lcd.print("W");
  delay(2500);
  Blynk.virtualWrite(V0, emon.Vrms);
  Blynk.virtualWrite(V13, emon.Irms);
  Blynk.virtualWrite(V2, emon.apparentPower);
  Blynk.virtualWrite(V3, kWh);
  lcd.begin();
  lcd.backlight();
  Blynk.begin(auth, ssid, pass);
  emon.voltage(35, vCalibration, 1.7);
  emon.current(34, currCalibration);
  timer.setInterval(5000L, myTimerEvent);
  lcd.setCursor(3, 0);
  lcd.print("IoT Energy");
  lcd.setCursor(5, 1);
  lcd.print("Meter");
  delay(3000);
  lcd.clear();
  Blynk.run();
  timer.run();
IoT-Based-Electricity-Energy-Meter-635x360 (1)
Start by only using the lcd and the microcontroller board. Get that working first.
Your topic has been moved to a more suitable location on the forum. Installation and Troubleshooting is not for problems with (nor for advice on) your project :wink: See About the Installation & Troubleshooting category.
i think its from my code because on other code that involves an lcd works but this doesnt
Do you have a simple "hello world" sketch for the LCD?
Does that work?
This wiring of LCD seems wrong for ESP32.
With this library changing lcd.begin to lcd.init your code can print on LCD with this wiring.
Here the pinout for ESP32
when i change to lcd.init
Install the library from my link or try your current code after fix the wiring.
@yabedibedoo Diagram illegible. Is the red trace connected to Vin, or 5V, on the Arduino and GND/0V on the LCD? It's impossible to tell.
still the same error
Post good pictures showing how it's wired and show us your current code.
Also tell us if it can work with some example from library.
#include <EEPROM.h>
#include <WiFi.h>
EnergyMonitor emon;
BlynkTimer timer;
char auth[] = "nrexz-lNuB963age87Dlm7GvtmGure2y";
char ssid[] = "prateeksingh";
char pass[] = "kumar@12345";
float kWh = 0;
void myTimerEvent()
  yield();
  Serial.print("V");
  EEPROM.update(0, emon.Vrms);
  delay(100);
  Serial.print("A");
  EEPROM.update(1, emon.Irms);
  delay(100);
  Serial.print("W");
  EEPROM.update(2, emon.apparentPower);
  delay(100);
  EEPROM.update(3, kWh);
  lcd.clear();
  lcd.print("Vrms:");
  lcd.print("V");
  lcd.print("Irms:");
  lcd.print("A");
  lcd.setCursor(0, 2);
  lcd.print("W");
  lcd.setCursor(0, 3);
  lcd.print("kWh:");
  lcd.print(kWh, 4);
  lcd.print("W");
  Blynk.virtualWrite(V1, emon.Irms);
  lcd.begin();
  lcd.backlight();
  eepromState();
  emon.voltage(35, vCalibration, 1.7);  // Voltage: input pin, calibration, phase_shift
  emon.current(34, currCalibration);    // Current: input pin, calibration.
  lcd.print("Meter");
  delay(3000);
  lcd.clear();
    Blynk.run();
    timer.run();
:point_up_2:
