my little script to monitor 2-wheel-balancing car data
you can use this to dump the serial data, show angle and omega as two little needles. you most likely need to make some changes to suit your needs.
from Tkinter import *
import time
import re
import sys
import math
import threading
import serial
class MyWindow:
    def __init__(self,root):
 	self.w = 800
        self.h = 500
        self.angle = 0;
        self.omega = 0;
        self.canvas = Canvas(root,width=self.w, height=self.h, bg="#456", relief= "sunken", border=10)
        self.canvas.create_line(0,0,0,0, tags="angle", fill="red")
        self.canvas.create_line(0,0,0,0, tags="omega", fill="blue")
        self.canvas.pack()
        self.update(root)
    def update(self, root):
        wrapped = lambda : self.update(root)
        self.canvas.coords("angle", calc_coords(self.angle, self.w, self.h))
        self.canvas.coords("omega", calc_coords(self.omega, self.w, self.h))
        root.after(25, wrapped)
        print "running " + str(self.angle)
    def set_data(self, angle, omega):
        self.angle = angle
        self.omega = omega
def calc_coords(angle, w, h):
    r = min(w,h) * 0.8 /2;
    return (w/2, h/2 , w/2 + r * math.sin(angle), h/2 - r * math.cos(angle))
root = Tk()
w = MyWindow(root)
class MyThread(threading.Thread):
    def __init__(self):
        threading.Thread.__init__(self)
        self.ser = serial.Serial('/dev/tty.YOUR-bluetooth-serial-DevB', 230400)
    def run(self):
        angle = 0
        omega = 0
        while (True):
            angle += 2.0/180 * math.pi / (1000/25 ) # double speed
            omega += 2.0 *2.0/180 * math.pi / (1000/25 ) # double speed
            line = serial.readline()[:-1]
            fields = re.split("\s+", line)
            angle = float(fields[3]) * math.pi / 180
            omega = float(fields[5]) * math.pi/2 / ( 1<<15)
            w.set_data(angle, omega)
            time.sleep(0.025)
data_controller = MyThread()
data_controller.start()
root.mainloop()
Which Arduino does that run on ?
