My loop does not work properly
My program is for a cut to length application. Up and button key set the length on LCD and once the set button pressed the stepper starts to rotate the number of steps set on the LCD.
My problem is that the tow buttons (up button ad down buttons) does not work. Up button work only one press and down button too. I need to set the desired length on the LCD by continuously pressing up button or down button.
Below is my code.
Further, can any on suggest me a way to work with a keyboard instead of up and down buttons.
#include <Stepper.h>
#include<LiquidCrystal.h>
int PUL = 13; int DIR = 12; int reSet = 8; int upButton = 11; int downButton = 10; int setButton = 9;
const int rs = 7, en = 6, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
Stepper myStepper(200,12,13);
int len = 2000;
int steps;
int rev;
int prev;
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Enter the Length");
myStepper.setSpeed(60);
{ if (digitalRead(upButton) == LOW);
delay(50);
while (digitalRead(upButton) == LOW);
delay(50);
{len++;
lcd.clear();
lcd.print("Length: ");
lcd.setCursor(0, 1);
lcd.print(len);
if (digitalRead(downButton) == HIGH)
delay(50);
while (digitalRead(downButton) == HIGH);
delay(50);
{len--;
lcd.clear();
lcd.print("Length:");
lcd.print(len);
if (digitalRead(setButton) == LOW); {
delay(50);
while (digitalRead(setButton) == LOW);
delay(50);
lcd.clear();
lcd.print("Length Set :");
rev=len/2;
steps=(rev-prev)*steps;
myStepper.step(steps);
lcd.clear();
lcd.print("Ready to Cut");
prev=rev;
How do you have your buttons wired? Pull-up resistors? Pull-down resistors? Why are two of them checking for LOW and one is checking for HIGH?
Are you holding your button down for more than a second to account for this period?
I think you've got quite a few semicolons you don't need. Here are the first two, but there are quite a few others.
  { if (digitalRead(upButton) == LOW);  // < ----- this semicolon ends the if block without doing anything
    delay(50);
    while (digitalRead(upButton) == LOW); // < ----- this semicolon ends the while block without doing anything
    delay(50);
Another thing that might help is to move your cursor into the IDE's source code window and press CTRL-T. This will reformat your code in a common C style. It might also help you see your brace placements.
Delta_G:
It is a mistake
[if (digitalRead(downButton) == HIGH)
delay(50);
delay(50);]
it was checked at "LOW" position and did not work.
