My "loop" function only seems to work for 3 minutes then stops
I am a newbie!
I'm trying to edit the code for this project:
What I am trying to do:
I want one line of text to scroll across my LEDs continuously, never stopping, repeat forever. I have been doing research on "for" and "while" loops and I'm still having trouble making it work.
I poked at the code a bit and have managed to get it to loop my one sentence, but it stops at the 2:58 mark every single time, halfway through my first word. This makes me think it's timing out or resetting or something. The code will reboot as soon as I type something into the serial monitor but I want this project to loop without being connected to my PC.
Here's my code drop (do I drop it all? I just included what I thought was the relevant part):
cli();
  // Show something on startup so we know it is working
  // (you can delete this branding if you are that kind of person)
  appendStringToBuffer ( "        !!startup message!!        "  ) ;
// Shift keeps track of how many columns shifted over the display currently is. By shifting one column at a
// time, we can smoothly scroll text across the display.
byte shift = 0;
  // Delay so text does not scroll to quickly...
  // Remeber we can not use millis() here since interrupts are permenetly off
  // We also have to manually keep checking the serial RX so that it doe snot overflow
   appendStringToBuffer( "THIS IS THE TEXT I WANT ON FOREVER" );
 for( unsigned i=0;i < FRAME_DELAY_MS ; i++ ) {
    _delay_us(900);   // Pool just often enough that we do not miss any serial bytes at 9600bd (1 byte about 1ms)
    serialPollRX();
  // Send out the signals to the LEDs
  byte more_flag = updateLEDs( buffer , buffer_len , shift );
  if (more_flag) {
    // If there is more of the buffer to display, then we shift over one column before the next update to smooth scroll forward
    shift++;
    // If shifting gets us to the end of the current char, then we move everything forward by one char
    if (shift== FONT_WIDTH) {
      shift = 0 ;
      buffer_len--;
      // Shift the buffer to the left 1 full char
      // Note we can not use `memmove()` for this becuase it takes too long and we might drop serial chars while it is running
      // so we do it manyally so we can keep pooling the serial port the whole time.
      for( unsigned i =0; i < buffer_len ; i++ ) {
          buffer[i] = buffer[i+1];
          serialPollRX();
Welcome to the forum
Please post your complete sketch in a new reply
here is the full code
// Creates a simplified scrolling ticker tape using WS2812B Neopixel strips.
// You should have 7 LED strips with the "Data In" pin for each connected to the D1-D7 pins on an Arduino Uno. (They also need power and ground connections)
// The Arduino listens for text on its built in serial port at 960bd,n,8,1 and then scrolls it out on the LEDs. It uses a buffer to the scrolling speed can be smoothed out.
// To send the serial data, you can connect the Arduino to a computer via USB and then use the Arduino Serial Monitor. Set the monitor to 9600 and "No Line Ending".
// Type stuff in the top bar and press enter and watch it scroll out on the LEDs.
// You can also connect other serial devices like a bluetooth HC-05 to the RX pin on the Arduino.
// For more info see the full article at http://wp.josh.com/Build-a-giant-scrolling-ticker-tape-from-WS2812B-Neopixels-and-an-Arduino-Uno
// Change this to be at least as long as your pixel string (too long will work fine, just be a little slower)
#define PIXEL_COUNT 29      // Length of the strings in pixels. I am using a 1 meter long strings that have 60 LEDs per meter.
#define FRAME_DELAY_MS 30    // Max time in ms for each frame while scrolling. Lower numbers make for faster scrolling (until we run out of speed).
                           // Note that we automatically start speeding up when the buffer starts getting full and then slow down again when it starts getting empty.
// Define the color we will send for on pixels. Each value is a byte 0-255.
#define COLOR_R 0x10
#define COLOR_G 0x00
#define COLOR_B 0x00
//#define COLOR_W 0x00     // Uncomment this line if you are using RGBW LED strips
/*------------------- FONT CUT TOP HERE -------------------------------*/
// This nice 5x7 font from here...
// http://sunge.awardspace.com/glcd-sd/node4.html
// Converted from font to C code with...
// https://github.com/bigjosh/MacroMarquee/blob/master/fontgen/cpp/fontconvert.cpp
// ...but you can also manually create fonts by just typing 1's and 0's if you are patient and you squint.
// Font details:
// 1) Each char is fixed 5x7 pixels.
// 2) Each byte is one column.
// 3) Columns are left to right order, leftmost byte is leftmost column of pixels.
// 4) Each column is 8 bits high.
// 5) Bit #7 is top line of char, Bit #1 is bottom.
// 6) Bit #0 is always 0 so that the RX pin can be used for serial input.
// 7) Include optional space to put between chars (or leave out for chars that should touch each other).
// defines ascii characters 0x20-0x7F (32-127)
// PROGMEM after variable name as per https://www.arduino.cc/en/Reference/PROGMEM
#define ASCII_OFFSET (0x20)     // ASCII code of 1st char in font array
#define ASCII_NONPRINT (0x80)   // ASCII code of char to show for chars not included in the font (could also be a space)
#define FONT_WIDTH 6
const byte fontdata[][FONT_WIDTH] PROGMEM = {
    { // ASCII 0x20 (' ')
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,  // Interchar space
    { // ASCII 0x21 ('!')
       0b00000000,
       0b00000000,
       0b11111010,
       0b00000000,
       0b00000000,
    { // ASCII 0x22 ('"')
       0b00000000,
       0b11100000,
       0b00000000,
       0b11100000,
       0b00000000,
    { // ASCII 0x23 ('#')
       0b00101000,
       0b11111110,
       0b00101000,
       0b11111110,
       0b00101000,
    { // ASCII 0x24 ('$')
       0b00100100,
       0b01010100,
       0b11111110,
       0b01010100,
       0b01001000,
    { // ASCII 0x25 ('%')
       0b11000100,
       0b11001000,
       0b00010000,
       0b00100110,
       0b01000110,
    { // ASCII 0x26 ('&')
       0b01101100,
       0b10010010,
       0b10101010,
       0b01000100,
       0b00001010,
    { // ASCII 0x27 (''')
       0b00000000,
       0b10100000,
       0b11000000,
       0b00000000,
       0b00000000,
    { // ASCII 0x28 ('(')
       0b00000000,
       0b00111000,
       0b01000100,
       0b10000010,
       0b00000000,
    { // ASCII 0x29 (')')
       0b00000000,
       0b10000010,
       0b01000100,
       0b00111000,
       0b00000000,
    { // ASCII 0x2A ('*')
       0b00010000,
       0b01010100,
       0b00111000,
       0b01010100,
       0b00010000,
    { // ASCII 0x2B ('+')
       0b00010000,
       0b00010000,
       0b01111100,
       0b00010000,
       0b00010000,
    { // ASCII 0x2C (',')
       0b00000000,
       0b00001010,
       0b00001100,
       0b00000000,
       0b00000000,
    { // ASCII 0x2D ('-')
       0b00010000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00010000,
    { // ASCII 0x2E ('.')
       0b00000000,
       0b00000110,
       0b00000110,
       0b00000000,
       0b00000000,
    { // ASCII 0x2F ('/')
       0b00000100,
       0b00001000,
       0b00010000,
       0b00100000,
       0b01000000,
    { // ASCII 0x30 ('0')
       0b01111100,
       0b10001010,
       0b10010010,
       0b10100010,
       0b01111100,
    { // ASCII 0x31 ('1')
       0b00000000,
       0b01000010,
       0b11111110,
       0b00000010,
       0b00000000,
    { // ASCII 0x32 ('2')
       0b01000010,
       0b10000110,
       0b10001010,
       0b10010010,
       0b01100010,
    { // ASCII 0x33 ('3')
       0b10000100,
       0b10000010,
       0b10100010,
       0b11010010,
       0b10001100,
    { // ASCII 0x34 ('4')
       0b00011000,
       0b00101000,
       0b01001000,
       0b11111110,
       0b00001000,
    { // ASCII 0x35 ('5')
       0b11100100,
       0b10100010,
       0b10100010,
       0b10100010,
       0b10011100,
    { // ASCII 0x36 ('6')
       0b00111100,
       0b01010010,
       0b10010010,
       0b10010010,
       0b00001100,
    { // ASCII 0x37 ('7')
       0b10000000,
       0b10001110,
       0b10010000,
       0b10100000,
       0b11000000,
    { // ASCII 0x38 ('8')
       0b01101100,
       0b10010010,
       0b10010010,
       0b10010010,
       0b01101100,
    { // ASCII 0x39 ('9')
       0b01100000,
       0b10010010,
       0b10010010,
       0b10010100,
       0b01111000,
    { // ASCII 0x3A (':')
       0b00000000,
       0b01101100,
       0b01101100,
       0b00000000,
       0b00000000,
    { // ASCII 0x3B (';')
       0b00000000,
       0b01101010,
       0b01101100,
       0b00000000,
       0b00000000,
    { // ASCII 0x3C ('<')
       0b00000000,
       0b00010000,
       0b00101000,
       0b01000100,
       0b10000010,
    { // ASCII 0x3D ('=')
       0b00101000,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00101000,
    { // ASCII 0x3E ('>')
       0b10000010,
       0b01000100,
       0b00101000,
       0b00010000,
       0b00000000,
    { // ASCII 0x3F ('?')
       0b01000000,
       0b10000000,
       0b10001010,
       0b10010000,
       0b01100000,
    { // ASCII 0x40 ('@')
       0b01001100,
       0b10010010,
       0b10011110,
       0b10000010,
       0b01111100,
    { // ASCII 0x41 ('A')
       0b01111110,
       0b10001000,
       0b10001000,
       0b10001000,
       0b01111110,
    { // ASCII 0x42 ('B')
       0b11111110,
       0b10010010,
       0b10010010,
       0b10010010,
       0b01101100,
    { // ASCII 0x43 ('C')
       0b01111100,
       0b10000010,
       0b10000010,
       0b10000010,
       0b01000100,
    { // ASCII 0x44 ('D')
       0b11111110,
       0b10000010,
       0b10000010,
       0b01000100,
       0b00111000,
    { // ASCII 0x45 ('E')
       0b11111110,
       0b10010010,
       0b10010010,
       0b10010010,
       0b10000010,
    { // ASCII 0x46 ('F')
       0b11111110,
       0b10010000,
       0b10010000,
       0b10000000,
       0b10000000,
    { // ASCII 0x47 ('G')
       0b01111100,
       0b10000010,
       0b10000010,
       0b10001010,
       0b01001100,
    { // ASCII 0x48 ('H')
       0b11111110,
       0b00010000,
       0b00010000,
       0b00010000,
       0b11111110,
    { // ASCII 0x49 ('I')
       0b00000000,
       0b10000010,
       0b11111110,
       0b10000010,
       0b00000000,
    { // ASCII 0x4A ('J')
       0b00000100,
       0b00000010,
       0b10000010,
       0b11111100,
       0b10000000,
    { // ASCII 0x4B ('K')
       0b11111110,
       0b00010000,
       0b00101000,
       0b01000100,
       0b10000010,
    { // ASCII 0x4C ('L')
       0b11111110,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
    { // ASCII 0x4D ('M')
       0b11111110,
       0b01000000,
       0b00100000,
       0b01000000,
       0b11111110,
    { // ASCII 0x4E ('N')
       0b11111110,
       0b00100000,
       0b00010000,
       0b00001000,
       0b11111110,
    { // ASCII 0x4F ('O')
       0b01111100,
       0b10000010,
       0b10000010,
       0b10000010,
       0b01111100,
    { // ASCII 0x50 ('P')
       0b11111110,
       0b10010000,
       0b10010000,
       0b10010000,
       0b01100000,
    { // ASCII 0x51 ('Q')
       0b01111100,
       0b10000010,
       0b10001010,
       0b10000100,
       0b01111010,
    { // ASCII 0x52 ('R')
       0b11111110,
       0b10010000,
       0b10011000,
       0b10010100,
       0b01100010,
    { // ASCII 0x53 ('S')
       0b01100010,
       0b10010010,
       0b10010010,
       0b10010010,
       0b10001100,
    { // ASCII 0x54 ('T')
       0b10000000,
       0b10000000,
       0b11111110,
       0b10000000,
       0b10000000,
    { // ASCII 0x55 ('U')
       0b11111100,
       0b00000010,
       0b00000010,
       0b00000010,
       0b11111100,
    { // ASCII 0x56 ('V')
       0b11111000,
       0b00000100,
       0b00000010,
       0b00000100,
       0b11111000,
    { // ASCII 0x57 ('W')
       0b11111110,
       0b00000100,
       0b00011000,
       0b00000100,
       0b11111110,
    { // ASCII 0x58 ('X')
       0b11000110,
       0b00101000,
       0b00010000,
       0b00101000,
       0b11000110,
    { // ASCII 0x59 ('Y')
       0b11000000,
       0b00100000,
       0b00011110,
       0b00100000,
       0b11000000,
    { // ASCII 0x5A ('Z')
       0b10000110,
       0b10001010,
       0b10010010,
       0b10100010,
       0b11000010,
    { // ASCII 0x5B ('[')
       0b00000000,
       0b00000000,
       0b11111110,
       0b10000010,
       0b10000010,
    { // ASCII 0x5C ('\')
       0b01000000,
       0b00100000,
       0b00010000,
       0b00001000,
       0b00000100,
    { // ASCII 0x5D (']')
       0b10000010,
       0b10000010,
       0b11111110,
       0b00000000,
       0b00000000,
    { // ASCII 0x5E ('^')
       0b00100000,
       0b01000000,
       0b10000000,
       0b01000000,
       0b00100000,
    { // ASCII 0x5F ('_')
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
    { // ASCII 0x60 ('`')
       0b00000000,
       0b10000000,
       0b01000000,
       0b00100000,
       0b00000000,
    { // ASCII 0x61 ('a')
       0b00000100,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00011110,
    { // ASCII 0x62 ('b')
       0b11111110,
       0b00010010,
       0b00100010,
       0b00100010,
       0b00011100,
    { // ASCII 0x63 ('c')
       0b00011100,
       0b00100010,
       0b00100010,
       0b00100010,
       0b00000100,
    { // ASCII 0x64 ('d')
       0b00011100,
       0b00100010,
       0b00100010,
       0b00010010,
       0b11111110,
    { // ASCII 0x65 ('e')
       0b00011100,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00011000,
    { // ASCII 0x66 ('f')
       0b00010000,
       0b01111110,
       0b10010000,
       0b10000000,
       0b01000000,
    { // ASCII 0x67 ('g')
       0b00010000,
       0b00101000,
       0b00101010,
       0b00101010,
       0b00111100,
    { // ASCII 0x68 ('h')
       0b11111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00011110,
    { // ASCII 0x69 ('i')
       0b00000000,
       0b00100010,
       0b10111110,
       0b00000010,
       0b00000000,
    { // ASCII 0x6A ('j')
       0b00000100,
       0b00000010,
       0b00100010,
       0b10111100,
       0b00000000,
    { // ASCII 0x6B ('k')
       0b00000000,
       0b11111110,
       0b00001000,
       0b00010100,
       0b00100010,
    { // ASCII 0x6C ('l')
       0b00000000,
       0b10000010,
       0b11111110,
       0b00000010,
       0b00000000,
    { // ASCII 0x6D ('m')
       0b00111110,
       0b00100000,
       0b00011000,
       0b00100000,
       0b00011110,
    { // ASCII 0x6E ('n')
       0b00111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00011110,
    { // ASCII 0x6F ('o')
       0b00011100,
       0b00100010,
       0b00100010,
       0b00100010,
       0b00011100,
    { // ASCII 0x70 ('p')
       0b00111110,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00010000,
    { // ASCII 0x71 ('q')
       0b00010000,
       0b00101000,
       0b00101000,
       0b00011000,
       0b00111110,
    { // ASCII 0x72 ('r')
       0b00111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00010000,
    { // ASCII 0x73 ('s')
       0b00010010,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00000100,
    { // ASCII 0x74 ('t')
       0b00100000,
       0b11111100,
       0b00100010,
       0b00000010,
       0b00000100,
    { // ASCII 0x75 ('u')
       0b00111100,
       0b00000010,
       0b00000010,
       0b00000100,
       0b00111110,
    { // ASCII 0x76 ('v')
       0b00111000,
       0b00000100,
       0b00000010,
       0b00000100,
       0b00111000,
    { // ASCII 0x77 ('w')
       0b00111100,
       0b00000010,
       0b00001100,
       0b00000010,
       0b00111100,
    { // ASCII 0x78 ('x')
       0b00100010,
       0b00010100,
       0b00001000,
       0b00010100,
       0b00100010,
    { // ASCII 0x79 ('y')
       0b00110000,
       0b00001010,
       0b00001010,
       0b00001010,
       0b00111100,
    { // ASCII 0x7A ('z')
       0b00100010,
       0b00100110,
       0b00101010,
       0b00110010,
       0b00100010,
    { // ASCII 0x7B ('{')
       0b00000000,
       0b00010000,
       0b01101100,
       0b10000010,
       0b00000000,
    { // ASCII 0x7C ('|')
       0b00000000,
       0b00000000,
       0b11111110,
       0b00000000,
       0b00000000,
    { // ASCII 0x7D ('}')
       0b00000000,
       0b10000010,
       0b01101100,
       0b00010000,
       0b00000000,
    { // ASCII 0x7E ('~')
       0b00010000,
       0b00010000,
       0b01010100,
       0b00111000,
       0b00010000,
    { // ASCII 0x7F
       0b00010000,
       0b00111000,
       0b01010100,
       0b00010000,
       0b00010000,
    { // ASCII 0x80 (box)
       0b11111110,
       0b10000010,
       0b10000010,
       0b10000010,
       0b11111111,
/*------------------- FONT CUT BOTTOM HERE -------------------------------*/
// The hard part of actually sending data out the strings is below.
#define RES_NS 500000   // Width of the low gap between bits to cause a frame to latch, from the WS2812B datasheets (recently increased to 50us for newer chips)
// We access the digital pins directly for speed. See https://www.arduino.cc/en/Reference/PortManipulation
#define PIXEL_PORT  PORTD  // Data register of the pins the pixels are connected to
#define PIXEL_DDR   DDRD   // Direction register of the pins the pixels are connected to
// Sends a full 8 bits down all the pins, represening a single color of 1 pixel
/// Assumes interrupts are *off* on entry and returns with them off.
// At 16Mhz, each cycle is 62.5ns. We will aim for...
// T0H 375ns =  6 cycles
// T1H 750ns = 12 cycles
// T1L 375ns =  6 cycles
// Send one bit to each LED string using WS2812B signaling based on the value of the coresponding bit in `bits`
// EX: if bit #3 in `bits` is 1, then a 1 waveform is sent out on digital pin 3.
static void inline sendBits( const byte bits ) {
    __asm__ __volatile__ (
      "out %[port], %[onBits] \n\t"                 // Both 0 and 1 waveforms start with signal going high
      "nop \n\t "                                   // (1 cycles)
      "out %[port], %[bits]   \n\t"                 // (1 cycles) - Any pins that have a `0` in `bits` will now go low forming a `0` signal
                                                    // (6 cycles) - T0H = 375ns
      "nop \n\t "                                   // (1 cycles) - Any pins that had a `1` in `bits` are still high here.
      "out %[port], __zero_reg__ \n\t"              // (1 cycles) - Now all pins that were sending a `1` now go low.
      ::                                            // No outputs
      [port]    "I" (_SFR_IO_ADDR(PIXEL_PORT)),
      [bits]   "d" (bits),
      [onBits]   "d" (0xff)
    // We assume here that whatever called `sendBits()` will take long enough to call it again that we will have some space between the signals.
    // Note that the inter-bit gap can be as long as you want as long as it doesn't exceed the reset timeout (which is a relatively long 5us)
// Just wait long enough without sending any bits to cause the pixels to latch and display the last sent frame
// This is the "RESET" period in the WS2812B datasheets
void show() {
  _delay_us( (RES_NS / 1000UL) + 1);       // Round up since the delay must be _at_least_ this long (too short might not work, too long not a problem)
// Must be big enough to hold serial data coming in while we are showing a message on the LEDs
#define BUFFER_SIZE 1000
byte buffer[ BUFFER_SIZE ];
volatile unsigned buffer_len = 0;      // Number of bytes currently in buffer
// Add a byte to the end of the buffer. Siliently discards byte if buffer already full.
void inline appendToBuffer( const byte b ) {
  if ( buffer_len < BUFFER_SIZE ) {
    buffer[ buffer_len++ ] = b;
void appendStringToBuffer( const char *s ) {
  while (*s) {
    appendToBuffer( *s );
    s++;
// Check if a byte is available from the serial port. If so, read it and add it to the buffer.
void inline serialPollRX() {
  if (UCSR0A & _BV(RXC0) ) {      // If there is a byte ready in the recieve buffer
    appendToBuffer( UDR0 );       // Read it and add to our buffer. Note reading the byte clears the RXC0 flag
// Send a byte of color data out the pins to the LED strings
// If bit `n` in `bits` is 1, then the byte `color` is sent on digital pin `n`. Otherwise the byte 0x00 is sent on that pin.
// Note WS2812B strips expect the color bits in highest-bit-first order as per datasheet.
static inline void sendByte( const byte bits , byte color ) {
    sendBits( (color & 0b10000000) ? bits : 0x00 );
    sendBits( (color & 0b01000000) ? bits : 0x00 );
    sendBits( (color & 0b00100000) ? bits : 0x00 );
    sendBits( (color & 0b00010000) ? bits : 0x00 );
    sendBits( (color & 0b00001000) ? bits : 0x00 );
    sendBits( (color & 0b00000100) ? bits : 0x00 );
    sendBits( (color & 0b00000010) ? bits : 0x00 );
    sendBits( (color & 0b00000001) ? bits : 0x00 );
// Send 3 bytes of color data (R,G,B) for a single pixel down all the connected strings at the same time
// Note that WS2812B strips expect color bytes in G,R,B order as per datasheet.
static inline void sendCol( byte colBits  ) {
  sendByte( colBits , COLOR_G );    // WS2812 takes colors in GRB order
  serialPollRX();                   // Poll serial port to see if anything new came in. This is the best time to do it when we have some extra time.
  sendByte( colBits , COLOR_R );    // WS2812 takes colors in GRB order
  sendByte( colBits , COLOR_B );    // WS2812 takes colors in GRB order
  #ifdef COLOR_W
    sendByte( colBits , COLOR_W );    // White for RGBW strips. Uncomment line above to use these strips.
  #endif
// Send a full batch of data out to the LEDs
// s points to an array of bytes that should be displayed. len is the number of bytes in that array to display.
// shift will shift the display `shift` columns to the left. By shifting through we can smooth scroll it across the width of the char.
// when shift=0 that means start at col 0, which means send the full char width of the first char.
// Returns true if there is more left in the buffer that did not fit on the display.
byte updateLEDs( const byte *s , unsigned len , byte shift ) {
  unsigned pixel_count = PIXEL_COUNT;  // How many pixels left to fill on the display?
  byte font_col =0;     // What column of the current font char are we currently on?
  while (len && pixel_count) {
    if (shift) {
      // Use up all the shift columns without actually sending them to the display
      shift--;
      byte font_index = (*s) -ASCII_OFFSET;     // The letter in the font of the current byte to display
      sendCol( pgm_read_byte_near( &fontdata[font_index ][font_col] ) );    // The column in the font of the current letter (read from PROGMEM)
      pixel_count--;
    font_col++;
    if (font_col==FONT_WIDTH) {       // Finished with this letter?
      // Move on to next letter
      font_col=0;
      s++;
      len--;
  // If the display is longer than the string, fill any remaining pixels with blanks
  while (pixel_count--) {
    sendCol(  0  );    // All pixels in column off
  // Latch everything we just sent into the pixels so it is actually displayed
  show();
  return len>0;     // If len>0 then we ran out of pixels before we ran out of message to display
  // Set up serial. We really only use the Ardunio `Serial` class to initialize the port for us, after that we do everything
  // ourselves manually becuase we need to keep interrupts off and the Aurduino stuff is just too slow for our timing requirements.
  Serial.begin(9600);         // Set up the serial port for recieving
  UCSR0B &= ~ _BV( TXEN0 );   // Disable the serial TX pin (digital pin 1) so we can use it as digital IO for an LED string
                              // Note that you can remove this line if you want to have bidirectional serial communication,
                              // but then you will loose a string of LEDS and will need to make the font be only 6 pixels tall.
  // initialize LED strip pins
  PIXEL_DDR |= 0xff;         // Set all 8 pins to output mode (note that digital pin 0 is controlled by the serial port so this has no effect on it)
  // This blinking signal seems to reset some stuck pixels and leaves all outputs cleanly low
  PIXEL_PORT |= 0xff;       // Set all outputs to 1
  delay( 100);
  PIXEL_PORT &= ~0xff;      // Set all outputs to 0
  delay( 100);
  delay( 100);
  delay( 100);
  // Turn off interrupts, forever. For now on we are repsonsible for polling the incoming serial data.
  // We turn off interrupts becuase if they happen durring our WS2812B waveform generation then they will mess up
  // our timing. We can not just turn them off durring waveform generation and then turn back on when we are done becuase
  // they would be off long enough to drop bytes, so we have to poll.
  cli();
byte shift = 0;
   appendStringToBuffer( "   PROTECT ME FROM WHAT I WANT   " );
    serialPollRX();
  if (more_flag) {
    shift++;
      shift = 0 ;
      buffer_len--;
          serialPollRX();
for ( unsigned i = 0;....
should this not be
for ( unsigned char/int/long i = 0;..
for ( unsigned char/int/long i = 0;i < FRAME_DELAY_MS ; i++ ) {
it comes up with this error
"expected unqualified-id before '/' token"
you was clever enough to replace "...". Now choose your favorite type of variable between "unsigned int" and "unsigned long". other words must be removed.
Just so you know
unsigned is a data type! And it happens to alias to unsigned int . When you’re writing unsigned x; you are not omitting any data type. This is completely different from “default int ” which exists in C (but not in C++!) where you really omit the type on a declaration and C automatically infers that type to be int.
 unsigned x;
is fine, but it would be better to not, if only because ppl think it is a mistake.
Compilers would complain if it was: it's 2022, you can mostly rely on them to be the arbiter of what is, and isn't, valid C/C++.
#include <iostream>
unsigned x;
using namespace std;
int main()
    x = 49777;
    cout << "Hello World " << x;
    return 0;
a7
oh boy. 25 days later and I'm still meddling with my code. I still need help!
I've edited it a bit and hopefully improved it for my purposes.
My objective: to get ( "...looping...text" ); to do just that!
Code drop:
#define PIXEL_COUNT 192      // Length of the strings in pixels. I am using 3.048 meter long strings that have 60 LEDs per meter.
#define FRAME_DELAY_MS 15    // Max time in ms for each frame while scrolling. Lower numbers make for faster scrolling (until we run out of speed).
#define COLOR_R 0x59
// Font details:
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b11111010,
       0b00000000,
       0b00000000,
       0b00000000,
       0b11100000,
       0b00000000,
       0b11100000,
       0b00000000,
       0b00101000,
       0b11111110,
       0b00101000,
       0b11111110,
       0b00101000,
       0b00100100,
       0b01010100,
       0b11111110,
       0b01010100,
       0b01001000,
       0b11000100,
       0b11001000,
       0b00010000,
       0b00100110,
       0b01000110,
       0b01101100,
       0b10010010,
       0b10101010,
       0b01000100,
       0b00001010,
       0b00000000,
       0b10100000,
       0b11000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00111000,
       0b01000100,
       0b10000010,
       0b00000000,
       0b00000000,
       0b10000010,
       0b01000100,
       0b00111000,
       0b00000000,
       0b00010000,
       0b01010100,
       0b00111000,
       0b01010100,
       0b00010000,
       0b00010000,
       0b00010000,
       0b01111100,
       0b00010000,
       0b00010000,
       0b00000000,
       0b00001010,
       0b00001100,
       0b00000000,
       0b00000000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00000000,
       0b00000110,
       0b00000110,
       0b00000000,
       0b00000000,
       0b00000100,
       0b00001000,
       0b00010000,
       0b00100000,
       0b01000000,
       0b01111100,
       0b10001010,
       0b10010010,
       0b10100010,
       0b01111100,
       0b00000000,
       0b01000010,
       0b11111110,
       0b00000010,
       0b00000000,
       0b01000010,
       0b10000110,
       0b10001010,
       0b10010010,
       0b01100010,
       0b10000100,
       0b10000010,
       0b10100010,
       0b11010010,
       0b10001100,
       0b00011000,
       0b00101000,
       0b01001000,
       0b11111110,
       0b00001000,
       0b11100100,
       0b10100010,
       0b10100010,
       0b10100010,
       0b10011100,
       0b00111100,
       0b01010010,
       0b10010010,
       0b10010010,
       0b00001100,
       0b10000000,
       0b10001110,
       0b10010000,
       0b10100000,
       0b11000000,
       0b01101100,
       0b10010010,
       0b10010010,
       0b10010010,
       0b01101100,
       0b01100000,
       0b10010010,
       0b10010010,
       0b10010100,
       0b01111000,
       0b00000000,
       0b01101100,
       0b01101100,
       0b00000000,
       0b00000000,
       0b00000000,
       0b01101010,
       0b01101100,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00010000,
       0b00101000,
       0b01000100,
       0b10000010,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00101000,
       0b10000010,
       0b01000100,
       0b00101000,
       0b00010000,
       0b00000000,
       0b01000000,
       0b10000000,
       0b10001010,
       0b10010000,
       0b01100000,
       0b01001100,
       0b10010010,
       0b10011110,
       0b10000010,
       0b01111100,
       0b01111110,
       0b10001000,
       0b10001000,
       0b10001000,
       0b01111110,
       0b11111110,
       0b10010010,
       0b10010010,
       0b10010010,
       0b01101100,
       0b01111100,
       0b10000010,
       0b10000010,
       0b10000010,
       0b01000100,
       0b11111110,
       0b10000010,
       0b10000010,
       0b01000100,
       0b00111000,
       0b11111110,
       0b10010010,
       0b10010010,
       0b10010010,
       0b10000010,
       0b11111110,
       0b10010000,
       0b10010000,
       0b10000000,
       0b10000000,
       0b01111100,
       0b10000010,
       0b10000010,
       0b10001010,
       0b01001100,
       0b11111110,
       0b00010000,
       0b00010000,
       0b00010000,
       0b11111110,
       0b00000000,
       0b10000010,
       0b11111110,
       0b10000010,
       0b00000000,
       0b00000100,
       0b00000010,
       0b10000010,
       0b11111100,
       0b10000000,
       0b11111110,
       0b00010000,
       0b00101000,
       0b01000100,
       0b10000010,
       0b11111110,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b11111110,
       0b01000000,
       0b00100000,
       0b01000000,
       0b11111110,
       0b11111110,
       0b00100000,
       0b00010000,
       0b00001000,
       0b11111110,
       0b01111100,
       0b10000010,
       0b10000010,
       0b10000010,
       0b01111100,
       0b11111110,
       0b10010000,
       0b10010000,
       0b10010000,
       0b01100000,
       0b01111100,
       0b10000010,
       0b10001010,
       0b10000100,
       0b01111010,
       0b11111110,
       0b10010000,
       0b10011000,
       0b10010100,
       0b01100010,
       0b01100010,
       0b10010010,
       0b10010010,
       0b10010010,
       0b10001100,
       0b10000000,
       0b10000000,
       0b11111110,
       0b10000000,
       0b10000000,
       0b11111100,
       0b00000010,
       0b00000010,
       0b00000010,
       0b11111100,
       0b11111000,
       0b00000100,
       0b00000010,
       0b00000100,
       0b11111000,
       0b11111110,
       0b00000100,
       0b00011000,
       0b00000100,
       0b11111110,
       0b11000110,
       0b00101000,
       0b00010000,
       0b00101000,
       0b11000110,
       0b11000000,
       0b00100000,
       0b00011110,
       0b00100000,
       0b11000000,
       0b10000110,
       0b10001010,
       0b10010010,
       0b10100010,
       0b11000010,
       0b00000000,
       0b00000000,
       0b11111110,
       0b10000010,
       0b10000010,
       0b01000000,
       0b00100000,
       0b00010000,
       0b00001000,
       0b00000100,
       0b10000010,
       0b10000010,
       0b11111110,
       0b00000000,
       0b00000000,
       0b00100000,
       0b01000000,
       0b10000000,
       0b01000000,
       0b00100000,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000000,
       0b10000000,
       0b01000000,
       0b00100000,
       0b00000000,
       0b00000100,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00011110,
       0b11111110,
       0b00010010,
       0b00100010,
       0b00100010,
       0b00011100,
       0b00011100,
       0b00100010,
       0b00100010,
       0b00100010,
       0b00000100,
       0b00011100,
       0b00100010,
       0b00100010,
       0b00010010,
       0b11111110,
       0b00011100,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00011000,
       0b00010000,
       0b01111110,
       0b10010000,
       0b10000000,
       0b01000000,
       0b00010000,
       0b00101000,
       0b00101010,
       0b00101010,
       0b00111100,
       0b11111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00011110,
       0b00000000,
       0b00100010,
       0b10111110,
       0b00000010,
       0b00000000,
       0b00000100,
       0b00000010,
       0b00100010,
       0b10111100,
       0b00000000,
       0b00000000,
       0b11111110,
       0b00001000,
       0b00010100,
       0b00100010,
       0b00000000,
       0b10000010,
       0b11111110,
       0b00000010,
       0b00000000,
       0b00111110,
       0b00100000,
       0b00011000,
       0b00100000,
       0b00011110,
       0b00111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00011110,
       0b00011100,
       0b00100010,
       0b00100010,
       0b00100010,
       0b00011100,
       0b00111110,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00010000,
       0b00010000,
       0b00101000,
       0b00101000,
       0b00011000,
       0b00111110,
       0b00111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00010000,
       0b00010010,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00000100,
       0b00100000,
       0b11111100,
       0b00100010,
       0b00000010,
       0b00000100,
       0b00111100,
       0b00000010,
       0b00000010,
       0b00000100,
       0b00111110,
       0b00111000,
       0b00000100,
       0b00000010,
       0b00000100,
       0b00111000,
       0b00111100,
       0b00000010,
       0b00001100,
       0b00000010,
       0b00111100,
       0b00100010,
       0b00010100,
       0b00001000,
       0b00010100,
       0b00100010,
       0b00110000,
       0b00001010,
       0b00001010,
       0b00001010,
       0b00111100,
       0b00100010,
       0b00100110,
       0b00101010,
       0b00110010,
       0b00100010,
       0b00000000,
       0b00010000,
       0b01101100,
       0b10000010,
       0b00000000,
       0b00000000,
       0b00000000,
       0b11111110,
       0b00000000,
       0b00000000,
       0b00000000,
       0b10000010,
       0b01101100,
       0b00010000,
       0b00000000,
       0b00010000,
       0b00010000,
       0b01010100,
       0b00111000,
       0b00010000,
    { // ASCII 0x7F
       0b00010000,
       0b00111000,
       0b01010100,
       0b00010000,
       0b00010000,
       0b11111110,
       0b10000010,
       0b10000010,
       0b10000010,
       0b11111111,
      ::                                            // No outputs
      [bits]   "d" (bits),
      [onBits]   "d" (0xff)
void show() {
volatile unsigned int buffer_len = 0;      // Number of bytes currently in buffer
void inline appendStringToBuffer( const char *s ) {
  while (*s) {
    s++;
 byte updateLEDs( const byte *s , unsigned int len , byte shift ) {
  unsigned int pixel_count = PIXEL_COUNT;  // How many pixels left to fill on the display?
    if (shift) {
      shift--;
      pixel_count--;
    font_col++;
      font_col=0;
      s++;
      len--;
  show();
  delay( 100);
  delay( 100);
  delay( 100);
  delay( 100);
  cli();
  appendStringToBuffer( "  .....   booting up  .....    " );
byte shift = 0;
  for( unsigned int i=0;i < FRAME_DELAY_MS ; i++ ) {
    appendStringToBuffer( "...looping...text" );
  if (more_flag) {
    shift++;
      shift = 0 ;
      buffer_len--;
      for( unsigned int i =0; i < buffer_len ; i++ ) {
Things I'm unsure about:
My loop code -
  if (more_flag) {
    shift++;
      shift = 0 ;
      buffer_len--;
Is this the best way to do it?
My issue is that the LEDs display the looping text for only about 2:00 (2minutes) and then display ellipses (........) forever after that. Prior to this, my display would just stop at around the two minute mark.
the reason for thi could be a lot of different things.
How do you power your LEDs?
How many LEDs build up your panel?
Does your hardware setup exactly follow these instructions?
best regards Stefan
Be the change you want to see in the world
This notion of be the change you want to see in the world does 3 powerful things when we adopt it:
It stops us from judging others;
It replaces complaining about others with reflection on self;
It stirs us into taking action within the only thing in the world over which we have any control: ourselves.
The root of your problems is in this line...
You keep making the string longer and longer until at some point it gets so long that it starts overwriting other important things also stored in RAM (like, for example, the stack that keeps track of where function calls should return to).
So instead you want to find a way to have a single fixed string repeatedly scroll through.
With that in mind, want to give it another go and see if you can get it working?
yay! josh! I will give it a try now
Cross Post : https://forum.arduino.cc/t/my-loop-function-only-seems-to-work-properly-for-2-minutes/972293/5
I want one line of text ( "...looping...text" ) to scroll across my LEDs continuously.
My issue is that the LEDs display the looping text for only about 2 minutes and then display ellipses (...) forever after that. The code will reboot as soon as I type something into the serial monitor but I want this project to loop without being connected to anything. I'm wondering if someone could help me to see what could be wrong with my loop function.
Code drop:
// Font details:
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b11111010,
       0b00000000,
       0b00000000,
       0b00000000,
       0b11100000,
       0b00000000,
       0b11100000,
       0b00000000,
       0b00101000,
       0b11111110,
       0b00101000,
       0b11111110,
       0b00101000,
       0b00100100,
       0b01010100,
       0b11111110,
       0b01010100,
       0b01001000,
       0b11000100,
       0b11001000,
       0b00010000,
       0b00100110,
       0b01000110,
       0b01101100,
       0b10010010,
       0b10101010,
       0b01000100,
       0b00001010,
       0b00000000,
       0b10100000,
       0b11000000,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00111000,
       0b01000100,
       0b10000010,
       0b00000000,
       0b00000000,
       0b10000010,
       0b01000100,
       0b00111000,
       0b00000000,
       0b00010000,
       0b01010100,
       0b00111000,
       0b01010100,
       0b00010000,
       0b00010000,
       0b00010000,
       0b01111100,
       0b00010000,
       0b00010000,
       0b00000000,
       0b00001010,
       0b00001100,
       0b00000000,
       0b00000000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00010000,
       0b00000000,
       0b00000110,
       0b00000110,
       0b00000000,
       0b00000000,
       0b00000100,
       0b00001000,
       0b00010000,
       0b00100000,
       0b01000000,
       0b01111100,
       0b10001010,
       0b10010010,
       0b10100010,
       0b01111100,
       0b00000000,
       0b01000010,
       0b11111110,
       0b00000010,
       0b00000000,
       0b01000010,
       0b10000110,
       0b10001010,
       0b10010010,
       0b01100010,
       0b10000100,
       0b10000010,
       0b10100010,
       0b11010010,
       0b10001100,
       0b00011000,
       0b00101000,
       0b01001000,
       0b11111110,
       0b00001000,
       0b11100100,
       0b10100010,
       0b10100010,
       0b10100010,
       0b10011100,
       0b00111100,
       0b01010010,
       0b10010010,
       0b10010010,
       0b00001100,
       0b10000000,
       0b10001110,
       0b10010000,
       0b10100000,
       0b11000000,
       0b01101100,
       0b10010010,
       0b10010010,
       0b10010010,
       0b01101100,
       0b01100000,
       0b10010010,
       0b10010010,
       0b10010100,
       0b01111000,
       0b00000000,
       0b01101100,
       0b01101100,
       0b00000000,
       0b00000000,
       0b00000000,
       0b01101010,
       0b01101100,
       0b00000000,
       0b00000000,
       0b00000000,
       0b00010000,
       0b00101000,
       0b01000100,
       0b10000010,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00101000,
       0b10000010,
       0b01000100,
       0b00101000,
       0b00010000,
       0b00000000,
       0b01000000,
       0b10000000,
       0b10001010,
       0b10010000,
       0b01100000,
       0b01001100,
       0b10010010,
       0b10011110,
       0b10000010,
       0b01111100,
       0b01111110,
       0b10001000,
       0b10001000,
       0b10001000,
       0b01111110,
       0b11111110,
       0b10010010,
       0b10010010,
       0b10010010,
       0b01101100,
       0b01111100,
       0b10000010,
       0b10000010,
       0b10000010,
       0b01000100,
       0b11111110,
       0b10000010,
       0b10000010,
       0b01000100,
       0b00111000,
       0b11111110,
       0b10010010,
       0b10010010,
       0b10010010,
       0b10000010,
       0b11111110,
       0b10010000,
       0b10010000,
       0b10000000,
       0b10000000,
       0b01111100,
       0b10000010,
       0b10000010,
       0b10001010,
       0b01001100,
       0b11111110,
       0b00010000,
       0b00010000,
       0b00010000,
       0b11111110,
       0b00000000,
       0b10000010,
       0b11111110,
       0b10000010,
       0b00000000,
       0b00000100,
       0b00000010,
       0b10000010,
       0b11111100,
       0b10000000,
       0b11111110,
       0b00010000,
       0b00101000,
       0b01000100,
       0b10000010,
       0b11111110,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b11111110,
       0b01000000,
       0b00100000,
       0b01000000,
       0b11111110,
       0b11111110,
       0b00100000,
       0b00010000,
       0b00001000,
       0b11111110,
       0b01111100,
       0b10000010,
       0b10000010,
       0b10000010,
       0b01111100,
       0b11111110,
       0b10010000,
       0b10010000,
       0b10010000,
       0b01100000,
       0b01111100,
       0b10000010,
       0b10001010,
       0b10000100,
       0b01111010,
       0b11111110,
       0b10010000,
       0b10011000,
       0b10010100,
       0b01100010,
       0b01100010,
       0b10010010,
       0b10010010,
       0b10010010,
       0b10001100,
       0b10000000,
       0b10000000,
       0b11111110,
       0b10000000,
       0b10000000,
       0b11111100,
       0b00000010,
       0b00000010,
       0b00000010,
       0b11111100,
       0b11111000,
       0b00000100,
       0b00000010,
       0b00000100,
       0b11111000,
       0b11111110,
       0b00000100,
       0b00011000,
       0b00000100,
       0b11111110,
       0b11000110,
       0b00101000,
       0b00010000,
       0b00101000,
       0b11000110,
       0b11000000,
       0b00100000,
       0b00011110,
       0b00100000,
       0b11000000,
       0b10000110,
       0b10001010,
       0b10010010,
       0b10100010,
       0b11000010,
       0b00000000,
       0b00000000,
       0b11111110,
       0b10000010,
       0b10000010,
       0b01000000,
       0b00100000,
       0b00010000,
       0b00001000,
       0b00000100,
       0b10000010,
       0b10000010,
       0b11111110,
       0b00000000,
       0b00000000,
       0b00100000,
       0b01000000,
       0b10000000,
       0b01000000,
       0b00100000,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000010,
       0b00000000,
       0b10000000,
       0b01000000,
       0b00100000,
       0b00000000,
       0b00000100,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00011110,
       0b11111110,
       0b00010010,
       0b00100010,
       0b00100010,
       0b00011100,
       0b00011100,
       0b00100010,
       0b00100010,
       0b00100010,
       0b00000100,
       0b00011100,
       0b00100010,
       0b00100010,
       0b00010010,
       0b11111110,
       0b00011100,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00011000,
       0b00010000,
       0b01111110,
       0b10010000,
       0b10000000,
       0b01000000,
       0b00010000,
       0b00101000,
       0b00101010,
       0b00101010,
       0b00111100,
       0b11111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00011110,
       0b00000000,
       0b00100010,
       0b10111110,
       0b00000010,
       0b00000000,
       0b00000100,
       0b00000010,
       0b00100010,
       0b10111100,
       0b00000000,
       0b00000000,
       0b11111110,
       0b00001000,
       0b00010100,
       0b00100010,
       0b00000000,
       0b10000010,
       0b11111110,
       0b00000010,
       0b00000000,
       0b00111110,
       0b00100000,
       0b00011000,
       0b00100000,
       0b00011110,
       0b00111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00011110,
       0b00011100,
       0b00100010,
       0b00100010,
       0b00100010,
       0b00011100,
       0b00111110,
       0b00101000,
       0b00101000,
       0b00101000,
       0b00010000,
       0b00010000,
       0b00101000,
       0b00101000,
       0b00011000,
       0b00111110,
       0b00111110,
       0b00010000,
       0b00100000,
       0b00100000,
       0b00010000,
       0b00010010,
       0b00101010,
       0b00101010,
       0b00101010,
       0b00000100,
       0b00100000,
       0b11111100,
       0b00100010,
       0b00000010,
       0b00000100,
       0b00111100,
       0b00000010,
       0b00000010,
       0b00000100,
       0b00111110,
       0b00111000,
       0b00000100,
       0b00000010,
       0b00000100,
       0b00111000,
       0b00111100,
       0b00000010,
       0b00001100,
       0b00000010,
       0b00111100,
       0b00100010,
       0b00010100,
       0b00001000,
       0b00010100,
       0b00100010,
       0b00110000,
       0b00001010,
       0b00001010,
       0b00001010,
       0b00111100,
       0b00100010,
       0b00100110,
       0b00101010,
       0b00110010,
       0b00100010,
       0b00000000,
       0b00010000,
       0b01101100,
       0b10000010,
       0b00000000,
       0b00000000,
       0b00000000,
       0b11111110,
       0b00000000,
       0b00000000,
       0b00000000,
       0b10000010,
       0b01101100,
       0b00010000,
       0b00000000,
       0b00010000,
       0b00010000,
       0b01010100,
       0b00111000,
       0b00010000,
    { // ASCII 0x7F
       0b00010000,
       0b00111000,
       0b01010100,
       0b00010000,
       0b00010000,
       0b11111110,
       0b10000010,
       0b10000010,
       0b10000010,
       0b11111111,
      ::                                            // No outputs
      [bits]   "d" (bits),
      [onBits]   "d" (0xff)
void show() {
  while (*s) {
    s++;
    if (shift) {
      shift--;
      pixel_count--;
    font_col++;
      font_col=0;
      s++;
      len--;
  show();
  delay( 100);
  delay( 100);
  delay( 100);
  delay( 100);
  cli();
byte shift = 0;
  if (more_flag) {
    shift++;
      shift = 0 ;
      buffer_len--;
You are undoubtedly violating array bounds, and writing into memory that you don't own. That is one of the surest ways of crashing any computer.
When moving strings around, it is absolutely essential to check the bounds. I see little of that in the posted code.
Your post was MOVED to its current location as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
This overflows the buffer on the read side. That's less dangerous than on the write side, but it could lead (eventually?) to buffer[] being full of garbage...
I'd look carefully here to check that the character pointed at by 's' yields a font_index in the range of the array you are addressing. A null character, for example, would result in an array subscript of -20 (or 236)
Cross Post : My "loop" function only seems to work for 3 minutes then stops
@wstacey,
Why have you started a new topic on the same subject? Asking the same question multiple times is against the forum rules as it wastes the time of the volunteers trying to help you. I have merged your topics. Please do not start another on the same subject, doing so is likely to result in you being prevented from posting.
You have had the forum instructions pointed out to you, please read them before making a new post.
Thanks you.
