PeterH:
You can't declare an array of arrays of different lengths. Instead of using an array of arrays, you need to use an array of pointers; each pointer would be initialised to point to an array holding your data values, which you have defined and initialised previously. If this lot is to be held in progmem then it's going to take considerable care (and trial and error) to make sure that you get the pointer dereferencing via progmem correct.
Here's a simple example to show the general idea, ignoring the progmem issue:
Got it to work:
static const uint8_t char20[] PROGMEM = {
0x10,0x00,0xff,0xff
static const uint8_t char21[] PROGMEM = {
0x0a,0x00,0x05,0x1c,0x05,0x1b,0x05,0x1a,0x05,0x19,0x05,0x18,0x05,0x17,0x05,0x16,0x05,0x15,0x05,0x14,0x05,0x13,0x05,0x12,0x05,0x11,0x05,0x10,0x05,0x0f,0x05,0x0e,0x04,0x08,0x05,0x07,0x06,0x08,0x05,0x09,0xff,0xff
static const uint8_t char22[] PROGMEM = {
0x10,0x00,0x04,0x1c,0x04,0x1b,0x04,0x1a,0x04,0x19,0x04,0x18,0x04,0x17,0x04,0x16,0x04,0x15,0x0c,0x1c,0x0c,0x1b,0x0c,0x1a,0x0c,0x19,0x0c,0x18,0x0c,0x17,0x0c,0x16,0x0c,0x15,0xff,0xff
/////////////// lots deleted in the middle /////////////
static const uint8_t char7e[] PROGMEM = {
0x18,0x00,0x03,0x0d,0x03,0x0e,0x04,0x12,0x05,0x12,0x06,0x13,0x07,0x13,0x08,0x13,0x09,0x13,0x0a,0x12,0x0b,0x11,0x0c,0x11,0x0d,0x10,0x0e,0x0f,0x0f,0x0f,0x10,0x0e,0x11,0x0e,0x12,0x0e,0x13,0x0e,0x14,0x10,0x03,0x0f,0x03,0x10,0x04,0x11,0x05,0x11,0x06,0x12,0x07,0x12,0x08,0x12,0x09,0x12,0x0a,0x11,0x0b,0x10,0x0c,0x10,0x0d,0x0f,0x0e,0x0e,0x0f,0x0e,0x10,0x0d,0x11,0x0d,0x12,0x0d,0x13,0x0d,0x14,0x0e,0x14,0x0f,0x15,0x10,0x15,0x11,0x15,0x12,0x15,0x13,0xff,0xff
static const uint8_t char7f[] PROGMEM = {
0x0e,0x00,0x05,0x1c,0x04,0x1b,0x04,0x1a,0x03,0x19,0x03,0x18,0x03,0x17,0x03,0x16,0x04,0x15,0x05,0x15,0x06,0x14,0x07,0x14,0x08,0x14,0x09,0x14,0x0a,0x15,0x0a,0x16,0x0b,0x17,0x0b,0x18,0x0b,0x19,0x0b,0x1a,0x0a,0x1b,0x09,0x1b,0x08,0x1c,0x07,0x1c,0x06,0x1c,0xff,0xff
// pointers to all the strings
static const uint8_t *table[] PROGMEM = {
char20, char21, char22, char23, char24, char25, char26, char27, char28, char29, char2a, char2b, char2c, char2d, char2e, char2f,
///////////// deleted for clarity ////////////
char70, char71, char72, char73, char74, char75, char76, char77, char78, char79, char7a, char7b, char7c, char7d, char7e, char7f
To access each set of data:
** **pgm_read_byte(pgm_read_word(&table[character_code]) + offset into string);** **
I need a PROGMEM read word to get a pointer to the particular string of data, then use PROGMEM read byte of the word address + offset to get it all.
I can't get a string length, so I have to just blindly grab data until I hit 0xFF.
Oh well, clumsy but it works.
Thanks for the idea! It helped me on the right path.
-- Roger
