My new Bluetooth Arduino Robot
I have made a robot. which i purchased from the china. I am facing some difficulties. My Ultra Sonic Censor servo is not moving left and light .
#include "IRremote.h"
#include <Servo.h>
//Pins for motor A
const int MotorA1 = 7;
const int MotorA2 = 5;
const int speedPinA=6;
//Pins for motor B
const int MotorB1 = 4;
const int MotorB2 = 2;
const int speedPinB=3;
int speed = 255;
int dir;
int motor;
int time = 5000;
//Pins for ultrasonic sensor
const int trigger=12;
const int echo=13;
int leftscanval, centerscanval, rightscanval, ldiagonalscanval, rdiagonalscanval;
char choice;
//Pin for IR control
int receiver = 10; // pin 1 of IR receiver to Arduino digital pin 10
IRrecv irrecv(receiver);           // create instance of 'irrecv'
decode_results results;
char contcommand;
int modecontrol=0;
int power=0;
const int distancelimit = 27; //Distance limit for obstacles in front
const int sidedistancelimit = 12; //Minimum distance in cm to obstacles at both sides (the robot will allow a shorter distance sideways)
int distance;
int numcycles = 0;
char turndirection; //Gets 'l', 'r' or 'f' depending on which direction is obstacle free
const int turntime = 900; //Time the robot spends turning (miliseconds)
int thereis;
Servo head;
void setup(){
  head.attach(5);
  head.write(80);
  irrecv.enableIRIn(); // Start the IR receiver
  pinMode(MotorA1, OUTPUT);
  pinMode(MotorA2, OUTPUT);
  pinMode (speedPinA, OUTPUT);
  pinMode(MotorB1, OUTPUT);
  pinMode(MotorB2, OUTPUT);
  pinMode (speedPinB, OUTPUT);
  pinMode(trigger,OUTPUT);
  pinMode(echo,INPUT);
//Variable inicialization
  digitalWrite(MotorA1,LOW);
  digitalWrite(MotorA2,LOW);
  digitalWrite(MotorB1,LOW);
  digitalWrite(MotorB2,LOW);
  digitalWrite(trigger,LOW);
void go(){
   analogWrite (speedPinA, speed);
   analogWrite (speedPinB, speed);
   digitalWrite (MotorA1, HIGH);
   digitalWrite (MotorA2, LOW);
   digitalWrite (MotorB1, HIGH);
   digitalWrite (MotorB2, LOW);
void backwards(){
  digitalWrite (MotorA1 , LOW);
  digitalWrite (MotorA2, HIGH);
  digitalWrite (MotorB1, LOW);
  digitalWrite (MotorB2, HIGH);
int watch(){
  long howfar;
  delayMicroseconds(5);
  digitalWrite(trigger,HIGH);
  delayMicroseconds(15);
  howfar=pulseIn(echo,HIGH);
  howfar=howfar*0.01657; //how far away is the object in cm
  return round(howfar);
void turnleft(int t){
  analogWrite (speedPinA, LOW);
  digitalWrite (MotorA1, LOW);
  delay(t);
void turnright(int t){
  analogWrite (speedPinB, LOW);
  delay(t);
void stopmove(){
digitalWrite (speedPinA, 255);
digitalWrite (speedPinB, 255);
  digitalWrite (MotorA1 ,LOW);
void watchsurrounding(){ //Meassures distances to the right, left, front, left diagonal, right diagonal and asign them in cm to the variables rightscanval,
                         //leftscanval, centerscanval, ldiagonalscanval and rdiagonalscanval (there are 5 points for distance testing)
  centerscanval = watch();
  if(centerscanval<distancelimit){stopmove();}
  head.write(120);
  delay(100);
  ldiagonalscanval = watch();
  if(ldiagonalscanval<distancelimit){stopmove();}
  head.write(160); //Didn't use 180 degrees because my servo is not able to take this angle
  delay(300);
  leftscanval = watch();
  if(leftscanval<sidedistancelimit){stopmove();}
  head.write(120);
  delay(100);
  head.write(80); //I used 80 degrees because its the central angle of my 160 degrees span (use 90     degrees if you are moving your servo through the whole 180 degrees)
  delay(100);
  head.write(40);
  delay(100);
  rdiagonalscanval = watch();
  if(rdiagonalscanval<distancelimit){stopmove();}
  head.write(0);
  delay(100);
  rightscanval = watch();
  if(rightscanval<sidedistancelimit){stopmove();}
  head.write(80); //Finish looking around (look forward again)
  delay(300);
char decide(){
  watchsurrounding();
  if (leftscanval>rightscanval && leftscanval>centerscanval){
    choice = 'l';
  else if (rightscanval>leftscanval && rightscanval>centerscanval){
    choice = 'r';
  else{
    choice = 'f';
  return choice;
void translateIR() { //Used when robot is switched to operate in remote control mode
  switch(results.value)
  case 0xFF629D: //Case 'FORWARD'
    go();
  case 0xFF22DD: //Case 'LEFT'
    turnleft(turntime);
    stopmove();
  case 0xFF02FD: //Case 'OK'
    stopmove();
  case 0xFFC23D: //Case 'RIGHT'
    turnright(turntime);
    stopmove();
  case 0xFFA857: //Case 'REVERSE'
    backwards();
  case 0xFF42BD:  //Case '*'
    modecontrol=0; stopmove(); // If an '*' is received, switch to automatic robot operating mode
  default:
  }// End Case
  delay(500); // Do not get immediate repeat
void loop(){
  if (irrecv.decode(&results)){ //Check if the remote control is sending a signal
    if(results.value==0xFF6897){ //If an '1' is received, turn on robot
      power=1; }
    if(results.value==0xFF4AB5){ //If a '0' is received, turn off robot
      stopmove();
      power=0; }
    if(results.value==0xFF42BD){ //If an '*' is received, switch operating mode from automatic robot to remote control (press also "*" to return to automatic robot mode)
      modecontrol=1; //  Activate remote control operating mode
      stopmove(); //The robot stops and starts responding to the user's directions
    irrecv.resume(); // receive the next value
  while(modecontrol==1){ //The system gets into this loop during the remote control mode until modecontrol=0 (with '*')
    if (irrecv.decode(&results)){ //If something is being received
      translateIR();//Do something depending on the signal received
  if(power==1){
  go();  // if nothing is wrong go forward using go() function above.
  ++numcycles;
  if(numcycles>130){ //Watch if something is around every 130 loops while moving forward
    watchsurrounding();
    if(leftscanval<sidedistancelimit || ldiagonalscanval<distancelimit){
    if(rightscanval<sidedistancelimit || rdiagonalscanval<distancelimit){
      turnleft(turntime);
    numcycles=0; //Restart count of cycles
  distance = watch(); // use the watch() function to see if anything is ahead (when the robot is just moving forward and not looking around it will test the distance in front)
  if (distance<distancelimit){ // The robot will just stop if it is completely sure there's an obstacle ahead (must test 25 times) (needed to ignore ultrasonic sensor's false signals)
      ++thereis;}
  if (distance>distancelimit){
      thereis=0;} //Count is restarted
  if (thereis > 25){
    stopmove(); // Since something is ahead, stop moving.
    turndirection = decide(); //Decide which direction to turn.
    switch (turndirection){
      case 'l':
        turnleft(turntime);
      case 'r':
      case 'f':
        ; //Do not turn if there was actually nothing ahead
    thereis=0;
Both MotorA2 and the head servo are using pin 5.
Thank, Its work great. How can i make the robot to run backward.
Pick it up and turn it around. This is such an obvious thing, I can't imagine why you need to ask. That is, how to do it properly, not my smart-ass way.
