Here is some info about them:
they are WayinTop NRF24L01 + PA + LNA RF nrfs.
they also have a breakout adapter.
so I have tried a lot of diferent connections and different code and my nrfs still don't work.
at first I followed this Simple nRF24L01+ 2.4GHz transceiver demo
but then I it didn't work and I also didn't have a capacitor so I used the breadkout adapter.
and it still doen't work.
here is what I have:
// SimpleTx - the master or the transmitter
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte slaveAddress[5] = {'R','x','A','A','A'};
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
char dataToSend[10] = "Message 0";
char txNum = '0';
unsigned long currentMillis;
unsigned long prevMillis;
unsigned long txIntervalMillis = 1000; // send once per second
Serial.println("SimpleTx Starting");
radio.begin();
radio.setDataRate( RF24_250KBPS );
radio.setRetries(3,5); // delay, count
radio.openWritingPipe(slaveAddress);
currentMillis = millis();
if (currentMillis - prevMillis >= txIntervalMillis) {
send();
prevMillis = millis();
void send() {
bool rslt;
rslt = radio.write( &dataToSend, sizeof(dataToSend) );
// Always use sizeof() as it gives the size as the number of bytes.
// For example if dataToSend was an int sizeof() would correctly return 2
Serial.print("Data Sent ");
Serial.print(dataToSend);
if (rslt) {
Serial.println(" Acknowledge received");
updateMessage();
else {
Serial.println(" Tx failed");
void updateMessage() {
// so you can see that new data is being sent
txNum += 1;
if (txNum > '9') {
txNum = '0';
dataToSend[8] = txNum;
code for the receiver:
// SimpleRx - the slave or the receiver
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
const byte thisSlaveAddress[5] = {'R','x','A','A','A'};
char dataReceived[10]; // this must match dataToSend in the TX
bool newData = false;
Serial.println("SimpleRx Starting");
radio.begin();
radio.openReadingPipe(1, thisSlaveAddress);
radio.startListening();
getData();
showData();
void getData() {
if ( radio.available() ) {
radio.read( &dataReceived, sizeof(dataReceived) );
newData = true;
void showData() {
if (newData == true) {
Serial.print("Data received ");
Serial.println(dataReceived);
newData = false;
If you read throught the tutorial you linked to there is a 'connection test' program, which tests the wiring between the Arduino and the NRFs, without engaging transmit or receive mode.
So try that progrem and post the results ..............
you need the seral monitor results right?
if so then: this is for the rx
CheckConnection Starting
FIRST WITH THE DEFAULT ADDRESSES after power on
Note that RF24 does NOT reset when Arduino resets - only when power is removed
If the numbers are mostly 0x00 or 0xff it means that the Arduino is not
communicating with the nRF24
SPI Speedz = 10 Mhz
STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1 = 0xe7e7e7e7e7 0x4141417852
RX_ADDR_P2-5 = 0xc3 0xc4 0xc5 0xc6
TX_ADDR = 0xe7e7e7e7e7
RX_PW_P0-6 = 0x20 0x20 0x20 0x20 0x20 0x20
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0e
DYNPD/FEATURE = 0x00 0x00
Data Rate = 1 MBPS
Model = nRF24L01+
CRC Length = 16 bits
PA Power = PA_MAX
ARC = 0
AND NOW WITH ADDRESS AAAxR 0x41 41 41 78 52 ON P1
and 250KBPS data rate
SPI Speedz = 10 Mhz
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x27
CONFIG = 0x0e
Data Rate = 250 KBPS
Model = nRF24L01+
PA Power = PA_MAX
ARC = 0
and this is for the TX
SPI Speedz = 10 Mhz
STATUS = 0x00 RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=0 TX_FULL=0
RX_ADDR_P0-1 = 0x0000000000 0x0000000000
RX_ADDR_P2-5 = 0x00 0x00 0x00 0x00
TX_ADDR = 0x0000000000
RX_PW_P0-6 = 0x00 0x00 0x00 0x00 0x00 0x00
EN_AA = 0x00
EN_RXADDR = 0x00
RF_CH = 0x00
RF_SETUP = 0x00
CONFIG = 0x00
Data Rate = 1 MBPS
Model = nRF24L01+
CRC Length = Disabled
PA Power = PA_MIN
ARC = 0
SPI Speedz = 10 Mhz
RX_ADDR_P0-1 = 0x4141417852 0x4141417852
TX_ADDR = 0x4141417852
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x07
CONFIG = 0x0e
Data Rate = 1 MBPS
Model = nRF24L01+
PA Power = PA_MAX
ARC = 5
SPI Speedz = 10 Mhz
EN_AA = 0x3f
EN_RXADDR = 0x03
RF_CH = 0x4c
RF_SETUP = 0x27
CONFIG = 0x0e
Model = nRF24L01+
PA Power = PA_MAX
ARC = 5
it's for the mega
it still doesn't really work it may be beacuase of this:
it also shows that on the uno
I also tried putting them 3m form each other
Honestly ive been trying to get these modules to work for like over a year,My best advice is to upload the two sketches to genuine boards,then if you dont get a error message from the serial monitor try uploading the sketch in the library that scans all channels so that way you know the modules sre working and then if that is still not working i buy a new module these ones to my knowledge are not the most reliable and always a pain to get up and running
Alright so update time I tried checking if the conection is right and now here is what I have right now. (update for @groundFungus and anyone who may have this problem or i don't just here is what I have)
TX:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
char txNum = '0';
radio.begin();
radio.setPALevel(RF24_PA_LOW);
send();
void send() {
bool rslt;
if (rslt) {
updateMessage();
else {
txNum += 1;
if (txNum > '9') {
txNum = '0';
RX:
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
radio.begin();
getData();
showData();
void getData() {
newData = true;
void showData() {
newData = false;
So in the Serial monitor of the TX it says that ist's not working right Data Sent Message 0 Tx failed
So then when I plug in th RX it says this: Datssage 0 Tx failed
Also when I start the programm it says that it is runing: SimpleTx Starting
But when I plug in the RX it says: DSimpleTx Starting
So it like crashes
but it does that just when I plug in but then it's just showing that is't not working: Data Sent Message 0 Tx failed
