My Obstacle Avoiding Bot does not operate well, I need help please.
Hey Guys
I am very new at Arduino or any type of coding - I mostly copy and paste, but want to learn more. I completed all the beginner projects and decided to challenge myself.
So this is my first post, born from desperation to succeed.
I purchased and assembled my obstacle avoiding bot kit which came as an incomplete set without instructions or code.
The project is based on an UNO, other parts as per attached images.
So basing my build on various online examples and using code from here and there, did not work.
I finally settled on using the example given at http://www.ardumotive.com/obstacle-avoiding-robot.html, even though mine is a 4x4, and the example only 2x2.
The code were not accepted, but eventually, after much research, I were able to upload the required Ultrasonic.h libraries, make the necessary adjustments (change the “WProgram.h” reference to “Arduino.h”) and magic!
Code loaded!
Bot responds!
Excitement!
But the problem is, it does not back up to give itself a clear path. It turns , but that is all.
Thank you Michalis Vasilakis for your examples that got me this far.
Any help, suggestions or such will be much appreciated.
Thank You
My code is as follows:
//Libraries
#include <Servo.h>
#include <Ultrasonic.h>
//Constants
const int button = 2; //Button pin to pin 2
const int led = 3; //Led pin (throught resistor) to pin 3
const int buzzer = 4; //Buzzer pin to pin 4
const int motorA1 = 6; //motor A positive (+) pin to pin 6 (PWM) (from L298 module!)
const int motorA2 = 9; //motor A negative (-) pin to pin 9 (PWM)
const int motorB1 = 10; //motor B positive (+) pin to pin 10 (PWM)
const int motorB2 = 11; //motor B negative (-) pin to pin 11 (PWM)
Ultrasonic ultrasonic(A4 , A5); //Create Ultrsonic object ultrasonic(trig pin,echo pin)
Servo myservo; //Create Servo object to control a servo
//Variables
int distance; //Variable to store distance from an object
int checkRight;
int checkLeft;
int function = 0; //Variable to store function of robot: ‘1’ running or ‘0’ stoped. By default is stoped
int buttonState = 0; //Variable to store the state of the button. By default ‘0’
int pos = 90; //Variable to store the servo position. By default 90 degrees - sensor will ‘look’ forward
int flag = 0; //Useful flag to keep the button state when button is released
myservo.attach(5); //Servo pin connected to pin 5
myservo.write(pos); // tell servo to go to position in variable ‘pos’
pinMode(button, INPUT_PULLUP);
pinMode(led, OUTPUT);
pinMode(buzzer, OUTPUT);
pinMode(motorA1, OUTPUT);
pinMode(motorA2, OUTPUT);
pinMode(motorB1, OUTPUT);
pinMode(motorB2, OUTPUT);
//Check button state
buttonState = digitalRead(button);
unsigned long currentMillis = millis(); //counting…
//Change main function (stoped/running) when button is pressed
if (buttonState == LOW) {//If button is pressed once…
delay(2);
if ( flag == 0) {
function = 1;
flag = 1; //change flag variable
else if ( flag == 1) { //If button is pressed twice
function = 0;
flag = 0; //change flag variable again
if (function == 0) { //If button is unpressed or pressed twice then:
myservo.write(90); //set servo 90 degress - sensor will look forward
stop(); //robot remain stoped
noTone(buzzer); //buzzer off
digitalWrite(led, HIGH);// and led on
else if (function == 1) { //If button is pressed then:
//Read distance…
distance = ultrasonic.Ranging(CM); //Tip: Use ‘CM’ for centimeters or ‘INC’ for inches
//Check for objects…
if (distance > 15) {
forward(); //All clear, move forward!
noTone(buzzer);
digitalWrite(led, LOW);
else if (distance <= 10) {
stop(); //Object detected! Stop the robot and check left and right for the better way out!
tone(buzzer, 500); // play a tone
digitalWrite(led, HIGH); // turn the led on
//Start scanning…
for (pos = 0; pos < 180; pos += 1) { //goes from 0 degrees to 180 degrees
myservo.write(pos); //tell servo to go to position in variable ‘pos’
delay(10); //waits 10ms for the servo to reach the position
checkLeft = ultrasonic.Ranging(CM); //Take distance from the left side
for (pos = 180; pos >= 0; pos -= 1) { //goes from 180 degrees to 0 degrees
checkRight = ultrasonic.Ranging(CM);
myservo.write(90); // Sensor “look” forward again
//Finally, take the right decision, turn left or right?
if (checkLeft < checkRight) {
left();
delay(400); // delay, change value if necessary to make robot turn.
else if (checkLeft > checkRight) {
right();
else if (checkLeft <= 15 && checkRight <= 15) {
backward(); //The road is closed… go back and then left :wink:
left();
void forward() {
digitalWrite(motorA1, HIGH);
digitalWrite(motorA2, LOW);
digitalWrite(motorB1, HIGH);
digitalWrite(motorB2, LOW);
void backward() {
digitalWrite(motorA1, LOW);
digitalWrite(motorA2, HIGH);
digitalWrite(motorB1, LOW);
digitalWrite(motorB2, HIGH);
void left() {
void right() {
void stop() {
  if (buttonState == LOW) {//If button is pressed once...
That is NOT what that code does.
You are not looking at the switch changing state. You should look at the state change detection example.
    if ( flag == 0) {
      function = 1;
Those names are completely useless in terms of conveying information. We have no clue what they are for/contain.
Make a table with 4 columns - go forward, turn left, turn right, and back up. In each column, write the conditions that are necessary to execute that action. Then, match those conditions to the code, to see if the code is correct.
Right now, the only reason to back up is if the distance to the left is exactly the same as the distance to the right AND both distances are less than or equal to 15 centimeters. How likely is that condition to be true?
Some people disagree with me, but I think that a person in your position should google "C++ tutorial" and do the first few chapters of any one of the dozens of free tutorials on the web. The arduino environment has some specific things that these tutorials won't cover, but they will give you a structured rundown of how the language works.
Thank You Paul. I will put my project aside for a bit and spend some time on that link.
