MY PC DOES NOT RECOGNIZE MY ARDUINO UNO
I’ve bought an arduino uno R3 (non-official) and it’s works fine for one month, but now when I plug-it on my pc, it don’t recognize my arduino :frowning:
I’ve already tryed to update driver and reset my arduino .
But it always comes to the same error:
Here is the error log in the Arduino IDE when I put the Blink basic code:
avrdude: ser_open(): can’t open device “\.\COM3”: Le fichier spécifié est introuvable.
Erreur lors de la gravure de la séquence d’initialisation.
Can you help me ?
Cheers
Can you help me ?
Is the Arduino still connected to COM3? Or, is it now connected to a different COM port?
i tryed with all of my pc ports and it doesn't works :'( I updated USB driver with the file ch340ser.exe and nothing changed. And when i update driver manually by devices manager (i select the arduino UNO.inf file) my pc say error during the driver updating :'( In my ARDUINO IDE I can't select a port (the line is in grey). On my arduino uno R3 ATMEGA328P-PU the "L" led and "on" led" are turned on .
Then it is pointless to try to upload anything.
I'm almost certain it said more than that.
PaulS:
I’m almost certain it said more than that.
My PC says :
Windows cant install your unknow device :
Here is a screenshoot (in french sorry)https://postimg.org/image/7kmplrtvj/
Do you know what i can do ?
I've bought an arduino uno R3 (non-official)
Buy an official UNO ;)
i will buy a new one but can i repair my old arduino ?
LoadzFire: Hi, I've bought an arduino uno R3 (non-official) and it's works fine for one month, but now when I plug-it on my pc, it don't recognize my arduino :( I've already tryed to update driver and reset my arduino . But it always comes to the same error: Here is the error log in the Arduino IDE when I put the Blink basic code: avrdude: ser_open(): can't open device "\.\COM3": Le fichier spécifié est introuvable. Erreur lors de la gravure de la séquence d'initialisation. Can you help me ? Cheers
Hey LoadzFire,
You should try this thread https://forum.arduino.cc/index.php?topic=302362.0
Let me know if it works.
Thank for answer me,
When i plug my Arduino I dont see it on COM category in the device manager, so i can’t unistall driver :’(.
I try to plug my Arduino in the other usb port of my pc, same error :frowning:
Have you go an idea ?
Your IDE version?
I download and install the very latest version (1.8.0) and i've download it one the official arduino website
Hello,
Did you try your Arduino on an another PC?
yes but i think i find the problem, I use my arduino with unojoy to make this projecthttps://www.youtube.com/watch?v=93oCS9nF_y0, And now when i want to turn my arduino as an arduino (because now it is in joystick mode) the cmd say :
AT90USB82 - USB - USB/DFU
Device selection....................... PASS
Hardware selection..................... PASS
Opening port........................... AtLibUsbDfu: 3EB 2FF7 no device present.
FAIL    Could not open USB device.
ISP done.
Trying to re-flash for an Arduino Uno R3
C:\Users\name\Downloads\UnoJoy-master\UnoJoy\ATmega8u2Code\HexFiles>batchisp -device atmega16u2 -hardware usb -operation erase f memory flash blankcheck loadbuffer "Arduino-usbserial-uno.hex" program verify start reset 0
Running batchisp 1.2.5 on Tue Dec 27 18:23:46 2016
ATMEGA16U2 - USB - USB/DFU
Opening port........................... AtLibUsbDfu: 3EB 2FEF no device present.
ISP done.
-1
The firmware was NOT loaded...
Did you install the Atmel FLIP program? - http://www.atmel.com/tools/FLIP.aspx -
Is the Arduino plugged in?
Is is it in 'Arduino UNO DFU' mode?
Press any key to exit..
