Hello everyone,
I'm having issues compiling my program. I'm working towards a program that flashes LEDs on a wind turbine blade to spell messages out as the turbine spins. At this point, I thought I had everything done except for figuring out how to determine the velocity of the turbine and use that for timing the message, but then I changed my code around a bit and now the thing gets stuck compiling. I'll paste my code in and then explain what I changed.
const int sensorPin = A0;
const float baselineTemp = 23.5;
int enter_else = 0;
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(1, INPUT);
//Dimensions in inches, time in milliseconds
int i, sensorVal, switch_state;
float innermost_LED_radius, LED_diameter, LEDTimer, pi, rev_time, temperature, voltage;
String printout;
printout = "HELLO WORLD!";
innermost_LED_radius = 3;
LED_diameter = 0.1875;
pi = 3.14159265358979;
rev_time = 32.5 * 1000;
LEDTimer = rev_time / (innermost_LED_radius * 2 * pi / LED_diameter);
Serial.print("# of usable LED lines: ");
Serial.print(innermost_LED_radius * 2 * pi / LED_diameter);
Serial.print(", LEDTimer: ");
Serial.println(LEDTimer);
switch_state = digitalRead(1);
if(switch_state == 0/* || (enter_else && switch_state != 0)*/)
set_all_to_low();
enter_else = 0;
enter_else = 1;
for(i = 0; i <= printout.length(); i++)
print_character(printout.charAt(i), LEDTimer);
//Cout set_all_to_low();
//Cout delay(1000);
void set_all_to_low(void)
int j;
for (j = 2; j <= 8; j++)
digitalWrite(j, LOW);
void print_character(char c, double LEDTimer)
switch(c)
case 'A':
3_to_8(LEDTimer);
2_5(LEDTimer);
2_5(LEDTimer);
2_5(LEDTimer);
3_to_8(LEDTimer);
////***************************Cases B through Y cut out because my post was over 9000 characters**********
case 'Z':
2_7_8(LEDTimer);
2_6(LEDTimer);
2_5(LEDTimer);
2_4(LEDTimer);
2_3_8(LEDTimer);
case '1':
4_8(LEDTimer);
3_8(LEDTimer);
2_to_8(LEDTimer);
8(LEDTimer);
8(LEDTimer);
////***********************Cases 2-8 cut out to make post smaller****************************
case '9':
3_4_7(LEDTimer);
2_5_8(LEDTimer);
2_5_8(LEDTimer);
2_5_8(LEDTimer);
3_4_6_7(LEDTimer);
case ' ':
nothing(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
case '.':
nothing(LEDTimer);
8(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
case ':':
nothing(LEDTimer);
4_6(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
case '!':
nothing(LEDTimer);
2_to_6_8(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
nothing(LEDTimer);
case '?':
3_4(LEDTimer);
2(LEDTimer);
2_6_8(LEDTimer);
2_5(LEDTimer);
3_4(LEDTimer);
void 2(float LEDTimer)
digitalWrite(2, HIGH);
digitalWrite(3, LOW);
digitalWrite(4, LOW);
digitalWrite(5, LOW);
digitalWrite(6, LOW);
digitalWrite(7, LOW);
digitalWrite(8, LOW);
delay(LEDTimer);
void 2_3(float LEDTimer)
digitalWrite(3, HIGH);
delay(LEDTimer);
void 2_3_7_8(float LEDTimer)
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);
delay(LEDTimer);
////************************Most functions cut out of this group too, again because of being >9000*************
void 7_8(float LEDTimer)
digitalWrite(2, LOW);
delay(LEDTimer);
void 8(float LEDTimer)
delay(LEDTimer);
void nothing(float LEDTimer)
delay(LEDTimer);
So basically, right now I have a function called print_character that uses a switch-case statement to print a character. Each case speels out a letter by making a series of function calls to different functions that just use digitalWrite to turn on or off select LEDs. Yesterday, I was just making the digitalWrite calls directly inside of print_character and skipping the extra step of helper functions, and it was compiling/running just fine. Then, this morning, I went from running five LEDs for four cycles per letter to 7 LEDs for five cycles per letter and added in the helper functions. Now, it just freezes at "Compiling sketch..." when I try to compile and upload to the board. Any idea what's going on?
