I'm writing a class template for a small coding project of mine. Once working, the class should allow me to parse data along different serial channels using the same functions on the Arduino Nano/Uno.
Expectation:
Program should call the setup function and then proceed to the loop and behave as normal.
The Bug: Keeps crashing
Last output to Serial Monitor depends on where I put flushes and delays. The program must crash somewhere after the last print line and then reboots (well sometimes it doesn't reboot and just crashes) this goes into a cycle. However, I know that the last output to the serial monitor is not a good indication of the exact line that the program fails.
Maybe someone here could look at my code and give me a hand? Any help would be much appreciated!
I have used the memory free library already and it tells me that there is still about 1.4K bytes left in the SRAM at the point of crash. So this bug is not due to a catastrophic collision between the stack and heap.
I don't think the crash is due to trying to access an index that is out of bounds. Neither is it caused by any memory leaks due to passing pointers that no longer point to allocated memory.
The Arduino IDE compiles the whole program without errors and no warnings from my code.
The crash maybe happening upon the call to AltSoftSerial::available() when the Comms.read() function is evaluated. This happens on both the nano and uno. Can someone tell me what how to solve it?
This is my sketch.
#include <Arduino.h>
#include <Comms1_2.h> //written by me
#include <AltSoftSerial.h>
//#include <MemoryFree.h>
//Declare and instantiate
SerialCommsClass<AltSoftSerial> Comms ("Bytes", 500); //Bluetooth
SerialCommsClass<HardwareSerial> Comms1 ("Bytes", 500); //Hardware Serial
//Call begin() for both channels
Comms1.begin(9600);
Comms.begin(9600);
Serial.flush();
//SETUP PINS AND STUFF;
//Serial.print("treeMemory1()=");
//Serial.println(freeMemory());
if (Comms1.read()) {/*do stuff*/}
if (Comms.read()) {/*do even more stuff*/}
And here is the Comms1_2.h class with its corresponding cpp file.
//Allows reading of both hardware Serial and altsoftserial.
//incoming info can be interpretted as either strings or bytes
//Will also write bytes or strings if necessary.
//must be instantiated with SerialCommsClass<ReplaceWithMyChannel> Comms()
#ifndef Comms1_2_h
#define Comms1_2_h
#ifndef OPERAND_SIZE
#define OPERAND_SIZE 3
#endif
#include "AltSoftSerial.h"
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include "EEPROM.h"
template <typename T>//Allows you to give it instantiations of class for different forms of communication
class SerialCommsClass { //SerialCommsClass<AltSoftSerial> Comms()
public:
SerialCommsClass (const String& arg, unsigned int timeOut); //Constructor "Bytes" or "Strings" and timeOut
bool read(); //function will call the relevant methods read the appropriate buffer as either Bytes or strings
bool write(char opcode, const unsigned long operand[OPERAND_SIZE]); //passes array by reference
//format data to be sent and then write to the output buffer
//if bytes used, input parameters must be between 0-255
bool begin(unsigned long baud); //just like all the other libraries
bool flush();
private:
bool _bytesOrStrings; //0 for bytes, 1 for strings
bool extractBytes();
const unsigned int _Time_Out; //Time the program waits before it decides that
//it hasn't received the expected termination
const char _Terminating_Char; //character marking end of command is currently a space
T* _Channel; //stores pointer to object
char _opcode;
unsigned long _operand[OPERAND_SIZE]; //template
String _command; //received chars stored here
unsigned int _timeStamp;
#endif
//takes only operands, terminating char is ' '
#include "MemoryFree.h"
#include "Comms1_2.h"
SerialCommsClass<T>::SerialCommsClass (const String& arg, unsigned int timeOut) //constructor
: _Time_Out (timeOut), //upto 32 seconds
_Terminating_Char (' ')
T channel;
_Channel = &channel;
if (arg == "Bytes") {
_bytesOrStrings = 0; //try to make sure that realloc() is not called. Try to avoid fragmenting the heap
_command.reserve(OPERAND_SIZE + 2);
} else if (arg == "Strings") {
_bytesOrStrings = 1; //try to make sure that realloc() is not called. Try to avoid fragmenting the heap
_command.reserve(OPERAND_SIZE * 5 + 2);
Serial.println(F("Invalid arg"));
Serial.flush();
template <>
SerialCommsClass<HardwareSerial>::SerialCommsClass (const String& arg, unsigned int timeOut) //explicit specialization of constructor
_Channel = &Serial;
Serial.flush();
bool SerialCommsClass<T>::read () { //Takes either Serial or an instantiation of AltSerial
//arg is either "Bytes" or "Strings"
Serial.println("read");
Serial.println(_command.length());
if (_command.length() == 0) { //time out tested
//Serial.flush();
_timeStamp = (unsigned int)millis(); //equivalent to mod 65536
Serial.println("1");
Serial.flush();
//resets every call
} /*else if ((unsigned int)((unsigned int)millis() - _timeStamp) > _Time_Out) {
//if it doesn't receive the terminating char after expected time
Serial.println(F("Received incomplete command")); //No termination
Serial.flush();
Serial.println(_command);
_command = ""; //gets rid of data
//perhaps should ask to resend command
delay(5000); //all the serial prints around here are for debugging purposes
Serial.println("available"); //note this line will not print if you replace with Serial.println(_Channel->template available())
Serial.flush();
while (_Channel->template available()) {
char c = _Channel->template read();
_command += c; //add to command
Serial.println("3");
return _bytesOrStrings ? extractStrings() : extractBytes(); //return appropriate interpretation
bool SerialCommsClass<T>::extractBytes () {
Serial.println ("got here");
Serial.flush();
Serial.flush();
//takes the command and turns into an opcode and operand
//if the string is empty or is not terminated,
//a complete command hasn't been received yet
return false;
} else if (_command[_command.length() - 1] != _Terminating_Char) {
//not terminated
return false;
} else if (_command.length() != OPERAND_SIZE + 2) { //2 bytes for opcode and delimiter
//if something weird is received
Serial.println(F("Invalid data length"));
Serial.flush();
_command = "";
return false;
//must be a valid command
Serial.println(F("Something Received"));
_opcode = _command[0]; //expects the first character to be an opcode
for (unsigned int i = 0; i < OPERAND_SIZE; i++) {
_operand[i] = _command[i + 1];
_command = ""; //Finished using command, so delete it. All info is in operand and opcode
return true;
bool SerialCommsClass<T>::write (char opcode, const unsigned long operand[OPERAND_SIZE]) {
//Specifying array size makes no difference
static String buffer; //reserves space
buffer = ""; //empties buffer
if(_bytesOrStrings) {
//allows for delimiters and average 4 chars per number
buffer.reserve(OPERAND_SIZE * 5 + 3);
//accounts for 1 byte per input, delimiters and char
buffer.reserve(OPERAND_SIZE + 3);
buffer += '?';
buffer += opcode;
if (_bytesOrStrings) { //for strings
buffer += String(operand[i]); //constructor used to convert between ulong and string
buffer += ",";
buffer[OPERAND_SIZE + 2] = '!'; //gets rid of extra comma at the end
} else { //must be bytes
if (operand[0] > 255 || operand[1] > 255 || operand[2] > 255) {
return false;
buffer += (byte)operand[i];
buffer += '!';
flush();
for (unsigned int i = 0; i < OPERAND_SIZE + 3; i++) {
_Channel->template write(buffer[i]); //read byte by byte necessary fo compatibility between the 2 different
//implementations of altsoftserial and HardwareSerial
//flush();
return true;
bool SerialCommsClass<T>::begin (unsigned long baud) {
_Channel->template begin(baud);
Serial.println(F("Channel opened"));
Serial.flush();
return true;
bool SerialCommsClass<T>::flush() {
_Channel->template flush();
return true;
//instantiated here
template class SerialCommsClass<AltSoftSerial>;
template class SerialCommsClass<HardwareSerial>;
Here is a sample from the Serial Monitor
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
available
Channel opened
Channel opened
read
0
1
Oh ok thanks. Anyway, I found the original problem.
T channel;
Serial.flush();
After looking more closely, there is a memory leak in this constructor.
