My projekt
Arduino
To cool:
PC laptop
PS3
Hardware:
Arduino Mega.
Engine power shild.
Ek-DCP 4.0 18W 8-12V. (Pump 1)
Phobya 1080 Radiator
2p BeQuiet! 140mm 800rpm, 12V, 0.1A. (FAN1)
2p "NoName" 140mm 1600rpm, 12V, 0.1A. (Fan2)
2p "NoName" 100mm (exhaust fans chassis (Fan3)
1st Temp Sensor. (Water temp radiator outlet (Undecided type / model) (Temp1)
1st Temp Sensor. (Temperature chassis (Undecided type / model) (Temp2)
1st Lcd 20x4
1/2 "Hose
Info
A PS3 will be disassembled from its present's chassis and fitted into a box of MDF. The box will also contain a laptop. Also it removed from its chassis. On the outside, a standing Phobya 1080 fitted with 4 140mm fans. 2 for more or less constant cooling and 2 as a backup.
The loop will go Pump - Radiator - CPU (PS3) - GPU (PS3) - CPU (PC) - Reservoir.
PC is on 24/7. PS3 3/5
Unless Pump 1 is possible to control with PWM, I have a relay card with 8relay to use with resistance to change speed.
Function (supposed)
PC starts
-Arduino-start
-Pump 1 starts at 8V (U min)
-Fan1 starts (minimum level)
-Fan3 starts (minimum level)
-Temp1 increases to ~ 35C
-FAN1 increase (~ 50%)
-Temp1 increases to 45C
-FAN1 increase (~ 75%)
-Fan2 starts (~ 50%)
-Pump 1 increases to ~ 10V
-Temp2 increases to 40C
-Fan3 increased ~ 50%
-Temp1 increases (~ 50C)
-FAN1 increase (100%)
-Fan2 increase (100%)
-Pump increases (12V)
LCD shows a loop of current information about temperatures on Temp1-3 and percent (?) On fans and pumps. (Example Pump 1 10V, FAN1 78%)
Please come with tips or thoughts on things I might not have considered.
Ideally, I'd like to have someone who can tell me what transistors I shall avail myself of which resistors are best suited and what codes I should look at.
Please contact me on email if there is something that should be discussed.
In SWE
Arduino
Att kyla:
PC laptop
PS3
Hårdvara:
Arduino Mega.
Motor power shild.
Ek-DCP 4.0 18W 8-12V. (Pump1)
2st BeQuiet! 140mm 800rpm, 12V, 0.1A. (Fan1)
2st "NoName" 140mm 1600rpm, 12V, 0.1A. (Fan2)
2st "NoName" 100mm (frånluftsfläktar chassi (Fan3)
1st Tempsensor. (Vattentemp utlopp radiator (Inte bestämt typ/modell) (Temp1)
1st Tempsensor. (Temperatur chassi (Inte bestämt typ/modell) (Temp2)
1st Lcd 20x4
1/2" Slang
Info
En PS3 kommer monteras isär från sitt nuvarandes chassi och monteras in i en låda av MDF. Lådan kommer även att innehålla en laptop. Också den demonterad från sitt chassi. På utsidan kommer ett stående Phobya 1080 monteras med 4st 140mm fläktar. 2st för mer eller mindre konstant kylning och 2st som backup.
Slingan kommer gå: Pump - Radiator - CPU (PS3) - GPU (PS3) - CPU (pc) - Reservoar.
PC står på 24/7. PS3 3/5
Om inte Pump1 är möjlig att styra med PWM har jag ett reläkort med 8relän ja tänkt använda med motstånd för att växla hastighet.
Funktion (tänkt)
-PC startar
-Arduino startar
-Pump1 startar på 8V (U:min)
-Fan1 startar (på lägsta möjliga nivå)
-Fan3 startar (på lägsta möjliga nivå)
-Temp1 ökar till ~35C
-Fan1 ökar (~50%)
-Temp1 ökar till 45C
-Fan1 ökar (~75%)
-Fan2 startar (~50%)
-Pump1 ökar till ~10V
-Temp2 ökar till 40C
-Fan3 ökar ~50%
-Temp1 ökar (~50C)
-Fan1 ökar (100%)
-Fan2 ökar (100%)
-Pump ökar (12V)
-LCD visar löpande info om temperaturer på Temp1-3 samt procent(?) på fläktar och pump. (Ex. Pump1 10V, FAN1 78%)
Kom gärna med tips eller tankar på saker jag kanske inte tänkt på.
Helst skulle jag vilja ha någon som kan berätta för mig vilka transistorer jag skall använda mig av, vilka resistorer som är bäst lämpade och vilka koder jag borde kika på.
Ta gärna kontakt med mig på mail om det är något som borde diskuteras.
What would be wrong with a few fans run from a 12v power supply? Computer fans don't mind running 24/7.
...R
nothing wrong with that. But I think the radiator can handle cooling a laptop processor that more or less idling 20/7.
