My questions about i2c
Can I connect multiple things into the same i2c pin?
If no, then how to get around that?
If yes, how to connect them?
Can I use the same modules on different boards if they have pins needed?
YES
by looking I2C up and getting more knowledge about it. Here is one random hit on a google search
Thanks. What about the 2nd question though? I think I can connect modules onto different arduinos, but I want to make sure.
you mean at the same time? or just if I2C modules are compatible with UNO, MEGA, ESP32, MKR, ...?
I meant compatibility.
yeah, I2C is I2C.
You might need to look at voltage levels (does it expect 3.3V or 5V or happy with both - there are I2C voltage adaptors / Logic Level Converter something like this) and double check pull-ups for your setup
