My relay is working , just makes the noise of a water drop
This is the relay/ power supply.
I have a float switch at the bottom of a tank Its has 497k resistance when open all the way. The code I have see it in digital I had to put a 10 k resistor on the switch because I was getting interference now it's working and on a 3000 delay
Is this a hardware issue? I am looking into debounce instead of delay
The float is automatic safety shut of for the relay (pump)
Does your relay operate correctly when you apply 5 volts DC directly to the terminals?
A schematic of you wiring is kind of important for questions like this!
Paul
Sorry, but I have to ask, are the wires to the float switch submerged in water?
outsider:
In prototyping not in water
