My relay won't get HIGH after reading serial read
Arduino code
#include <Wire.h>
const int coinInt = 0;
//Attach coinInt to Interrupt Pin 0 (Digital Pin 2). Pin 3 = Interrpt Pin 1.
volatile float coinsValue = 0.00;
//Set the coinsValue to a Volatile float
//Volatile as this variable changes any time the Interrupt is triggered
int coinsChange = 0;
//A Coin has been inserted flag
bool coins = false;
int relay = 8;
void setup(){
//Start Serial Communication
attachInterrupt(coinInt, coinInserted, RISING);
pinMode(relay, OUTPUT);
digitalWrite(relay, LOW);
void coinInserted()
coinsValue = coinsValue + 1;
coinsChange = 1;
void loop
if (coinsChange == 1)
coinsChange = 0;
Serial.print("Credit: £");
Serial.println(coinsValue);
if (coinsValue == 5)
digitalWrite(relay, HIGH);
while(coins == true)
if (Serial.available() > 0 )
char ltr = Serial.read();
if (ltr == 'a')
coinsValue = 0;
coins = false;
Serial.flush();
return;
Unity code
using System.Collections;
using System.Collections.Generic;
using UnityEngine;
using UnityEngine.UI;
using System.IO.Ports;
using System.Threading;
public class GameTimer : MonoBehaviour
SerialPort sp = new SerialPort("COM3", 9600);
public Text gameTimerText;
public static float gameTimer = 10f;
void start()
sp.Open();
sp.ReadTimeout = 1;
void update()
void Update()
if (sp.IsOpen)
try
print(sp.ReadByte());
catch (System.Exception)
gametimer-= 1 * Time.deltaTime;
gameTimerText.text = gameTimer.ToString("0");
if (gameTimer <= 0)
sp.Write("a");
Your Arduino code does not compile
Quite apart from other errors it does not have a setup() function
Have you posted the right version ?
Oh sorry I put the wrong code it should be void setup() not void start().
It still does not compile
void coinInserted()
coinsChange = 1;
void loop
There is an extra { in your code and look carefully at the name of the loop function. Is something missing ?
If you post revised code again please put it in new post rather than revising an old one so that comments in the thread make sense
The revised arduino code
Arduino code
#include <Wire.h>
bool coins = false;
int relay = 8;
void setup(){
void coinInserted()
coinsChange = 1;
void loop
coinsChange = 0;
if (ltr == 'a')
coinsValue = 0;
coins = false;
Serial.flush();
return;
Have you tried to compile that code ?
Obviously not, because it won't
Sorry I forgot to put () in void loop
#include <Wire.h>
bool coins = false;
int relay = 8;
void setup(){
void coinInserted()
coinsChange = 1;
coinsChange = 0;
if (ltr == 'a')
coinsValue = 0;
coins = false;
Serial.flush();
return;
UKHeliBob:
I revised the code did you find the solution?
Thank you in advance
I don't appreciate a nudge after only 30 minutes. When is your assignment due to be submitted ?
Take a look at the coins variable
It is declared false
Later you have this line
while (coins == true)
But the value of coins has not been changed. In fact it is never set to true in the program
UKHeliBob:
I revised it but still not been solved.
#include <Wire.h>
bool coins = false;
int relay = 8;
void setup(){
void coinInserted()
coinsChange = 1;
coinsChange = 0;
coins = true;
if (ltr == 'a')
coinsValue = 0;
coins = false;
Serial.flush();
return;
So have you done this? All variables used in an interrupt service routine need to be volatile.
Grumpy_Mike:
When I send 'a' from serial monitor it works but when the data is from unity it doesn't work.
Badly needed cause tomorrow is our thesis defense. Thank you
Did you note that all variables used in an interrupt service routine need to be volatile.
UKHeliBob:
I used volatile to increment the coinsValue until it reach 5.
Should I change it?
void coinInserted()
coinsChange = 1;
Are all of the variables used in the ISR declared as volatile ?
UKHeliBob:
void coinInserted()
coinsChange = 1;
Are [u]all[/u] of the variables used in the ISR declared as volatile ?
Yeah. When inserted a coin the output will be
Credit: £1
Credit: £2
Credit: £3
Credit: £4
Credit: £5
UKHeliBob:
What about this one ?
//If coinInt goes HIGH (a Pulse), call the coinInserted function
//An attachInterrupt will always trigger, even if your using delays
void coinInserted()
//The function that is called every time it recieves a pulse
//As we set the Pulse to represent 5p or 5c we add this to the coinsValue
coinsChange = 1;
//Flag that there has been a coin inserted
if(coinsChange == 1)
//Check if a coin has been Inserted
coinsChange = 0;
//unflag that a coin has been inserted
//Print the Value of coins inserted
That's the full code of my coinslot
Read this comment from your code
Now, what about the coinsChange ?
Does that change when the interrupt is triggered ?
