my robot doesn't move..check the codes plz
hello
im using L298n + wifi cc3000 breakout board +arduono uno
i have these codes and everything is fine when i verify the code om IDE
also the connection is fine in the serial monitor as shows here
العاب
i have tried all those in my browser
192.168.1.10:3000
192.168.1.10/id
192.168.1.10:3000/id
but the same things is shown the “page not available”
so what i should do plz any help
// Include required libraries
#include <Adafruit_CC3000.h>
#include <ccspi.h>
#include <SPI.h>
#include <string.h>
#include "utility/debug.h"
#include <stdlib.h>
String result;
int motorCommand[4];
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ   3
#define ADAFRUIT_CC3000_VBAT  5
#define ADAFRUIT_CC3000_CS    10
// Motor pins
int enableA = 6;
int enableB = 9;
int pinA1 = 4;
int pinA2 = 2;
int pinB1 = 7;
int pinB2 = 8;
const unsigned long
  dhcpTimeout     = 60L * 1000L, // Max time to wait for address from DHCP
  connectTimeout  = 15L * 1000L, // Max time to wait for server connection
  responseTimeout = 15L * 1000L; // Max time to wait for data from server
uint32_t t;
int resultLength;
// WiFi network (change with your settings !)
#define WLAN_SSID       "*****"        // cannot be longer than 32 characters!
#define WLAN_PASS       "*****"
#define WLAN_SECURITY   WLAN_SEC_WPA2 // This can be WLAN_SEC_UNSEC, WLAN_SEC_WEP, WLAN_SEC_WPA or WLAN_SEC_WPA2
// What TCP port to listen on for connections.
#define LISTEN_PORT           8888
// Create CC3000 instances
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS, ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT,
                                         SPI_CLOCK_DIV2);
// Create server
Adafruit_CC3000_Server robotServer(LISTEN_PORT);
  result = "";
  pinMode (enableA, OUTPUT);
  pinMode (enableB, OUTPUT);
  pinMode(pinA1, OUTPUT);
  pinMode(pinA2, OUTPUT);
  pinMode(pinB1, OUTPUT);
  pinMode(pinB2, OUTPUT);
  /* Initialise the module */
  Serial.println(F("\nInitializing..."));
  if (!cc3000.begin())
    Serial.println(F("Couldn't begin()! Check your wiring?"));
    while(1);
  if (!cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY)) {
    Serial.println(F("Failed!"));
    while(1);
  Serial.println(F("Connected!"));
  Serial.println(F("Request DHCP"));
  while (!cc3000.checkDHCP())
    delay(100); // ToDo: Insert a DHCP timeout!
  /* Display the IP address DNS, Gateway, etc. */
  while (! displayConnectionDetails()) {
  // Start listening for connections
  robotServer.begin();
  Serial.println(F("Listening for connections..."));
  //enable Motors
  enable();
  // Try to get a client which is connected.
  Adafruit_CC3000_ClientRef client = robotServer.available();
  if (client) {
     boolean currentLineIsBlank = true;
     // Check if there is data available to read.
     while (client.available()) {
       char c = client.read();
       result = result + c;
       Serial.write(c);
       // Delete HTTP headers
      if(result.endsWith("Content-Type: text/html"))
        result="";
       if (c == '\n' && currentLineIsBlank) {
          // send a standard http response header
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println();
       if (c == '\n') {
          // you're starting a new line
        else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
     // give the web browser time to receive the data
    delay(5);
    // close the connection:
    client.close();
    Serial.println("client disconnected");
    Serial.print("result: ");
    Serial.println (result);
    // Format result and extract the variables
 //   format_result(motorCommand,result);
  //  Serial.print ("After format: ");
    //Serial.println (String(motorCommand[0]) + ":" + String(motorCommand[1]) + ":" + String(motorCommand[2]) + ":" + String(motorCommand[3]));
    // Print received values
    //Serial.println("Motor 1 speed: " + String(motorCommand[0]) + " and direction: " + String(motorCommand[2]));
    //Serial.println("Motor 2 speed: " + String(motorCommand[1]) + " and direction: " + String(motorCommand[3]));
    // Send motor commands
    //send_motor_command(enableA,motorCommand[0],motorCommand[2]);
    //send_motor_command(enableB,motorCommand[1],motorCommand[3]);
    send_motor_command(motorCommand[0],motorCommand[1],motorCommand[2],motorCommand[3]);
    Serial.print ("Motor command 1: ");
    Serial.print (motorCommand[0]);
    Serial.println (motorCommand[2]);
    Serial.print ("Motor command 2: ");
    Serial.print (motorCommand[1]);
    Serial.println (motorCommand[3]);
    // Reset result variable
    result = "";
void send_motor_command(int left, int right, int fwd, int bwd) {
  //lets check what we have
  if (fwd) {
    forward();
    //delay(1000); //1s
  if (bwd) {
    backward();
    //delay (500); // 1/2s
  if (left) {
    turnLeft();
  if (right) {
    turnRight();
  //stop
  if ((!left) && (!right) && (!fwd) && (!bwd)) {
    stopRobot();
void format_result(int* array, String result) {
 result.trim();
 resultLength = result.length();
 Serial.println(result);
int commaPosition;
 int i = 0;
 do
      commaPosition = result.indexOf(',');
      if(commaPosition != -1)
          Serial.println( result.substring(0,commaPosition));
          array[i] = result.substring(0,commaPosition).toInt();
          i = i+1;
          result = result.substring(commaPosition+1, result.length());
         if(result.length() > 0) {
   while(commaPosition >=0);
    @brief  Tries to read the IP address and other connection details
bool displayConnectionDetails(void)
  uint32_t ipAddress, netmask, gateway, dhcpserv, dnsserv;
  if(!cc3000.getIPAddress(&ipAddress, &netmask, &gateway, &dhcpserv, &dnsserv))
    Serial.println(F("Unable to retrieve the IP Address!\r\n"));
    return false;
    Serial.print(F("\nIP Addr: ")); cc3000.printIPdotsRev(ipAddress);
    Serial.print(F("\nNetmask: ")); cc3000.printIPdotsRev(netmask);
    Serial.print(F("\nGateway: ")); cc3000.printIPdotsRev(gateway);
    Serial.print(F("\nDHCPsrv: ")); cc3000.printIPdotsRev(dhcpserv);
    Serial.print(F("\nDNSserv: ")); cc3000.printIPdotsRev(dnsserv);
    return true;
void enable() {
  digitalWrite (enableA, HIGH);
  digitalWrite (enableB, HIGH);
void disable() {
  digitalWrite (enableA, LOW);
  digitalWrite (enableB, LOW);
//function direction
void backward() {
  digitalWrite (pinA1, LOW);
  digitalWrite (pinA2, HIGH);
  digitalWrite (pinB1, HIGH);
  digitalWrite (pinB2, LOW);
void forward() {
  digitalWrite (pinA1, HIGH);
  digitalWrite (pinA2, LOW);
  digitalWrite (pinB1, LOW);
  digitalWrite (pinB2, HIGH);
void turnRight() {
  //motorA backward
  //motorB forward
  //delay for 1/2s is enough
  stopRobot();
void turnLeft() {
  //motorA forward
  //motorB backward
  stopRobot();
void stopRobot() {
So why are you using port 3000 in your connect attempts (or the default port 80)?
Omg that's right I didn't even recognize that
thanks very much
But I'm sorry there are another thing after i change ports
The car only accepts the first command always so when i want to change the direction by adding 192.168.1.10/storrobot or any other command except the first command it's not response and give me the page are not available
Another thing thats I recognize that tha car moving in the same way always wat ever the first command is
It's always one of the wheels clockwise And another counter clockwise what ever wat is the command?
Is the problem with codes arrangements I should to add something or there is mistake in directions function
plz anyone can help
when i wrote http://192.168.1.10/turnRight
the serial monitor accept the command but the car doesnt move
and also when i change to for ex http://192.168.1.10/forward
the browse says page not available until i close the serial monitor and open it again the brows accepted
why its not accept changing direction from brows and why the car doesnt move?
also when i remove the USB cable and write the ip add the brows say not availble how to make the command send through wifi
noura91:
thanks very much
In the code you posted, it appears that the commands are a comma separated list after the slash (I think) - in the format of:
{left},{right},{forward},{backward}
Where each field is a character (can be any character I think).
Three commas (ie - four empty fields) - or four zeros (?) is the command for "stop" (that, or nothing after the slash means stop?).
Anyhow - so, with that in mind, the following links should (?) work (?):
http://192.168.1.10/ => stop (?)
http://192.168.1.10/,,, => stop (?)
http://192.168.1.10/0,0,0,0 => stop (?)
http://192.168.1.10/1,,, => left (?)
http://192.168.1.10/1,0,0,0 => left
http://192.168.1.10/,1,, => right (?)
http://192.168.1.10/0,1,0,0 => right
http://192.168.1.10/,,1, => forward (?)
http://192.168.1.10/0,0,1,0 => forward
http://192.168.1.10/,,,1 => backward (?)
http://192.168.1.10/0,0,0,1 => backward
At least - that's how I am interpreting the code. Without the actual hardware in front of me, plus the code on the robot and the serial monitor running - I really don't know if that is the proper way it's supposed to work, or if there is something else needed.
Hopefully that will at least help you debug it and understand the code better. Good luck!
:slight_smile:
ok
thank u cr0sh im going to try it and tell u the result
