Hi, Im writing code in Arduino editor and using ESP32.
When is disabled the "ArduinoCloud.update();" the ultrasonic sensor is writting out raw value in variable "doba" and working properly (This is what I want). But when the "ArduinoCloud.update();" is enabled the variable "doba" is writting out only "0" all the time.
I have the same isue with soil moisture sensor and i don't know what to do.
Here is my code with Arduino IoT cloud connection.
Sketch generated by the Arduino IoT Cloud Thing "Untitled"
https://create.arduino.cc/cloud/things/83004a78-17dc-46f3-b7e3-d36d0fbaeb86
Arduino IoT Cloud Variables description
The following variables are automatically generated and updated when changes are made to the Thing
float cyklusSVETLA;
float nadrzPLNOST;
float vzduchTEPLOTA;
float vzduchVLHKOST;
bool techMISTO;
Variables which are marked as READ/WRITE in the Cloud Thing will also have functions
which are called when their values are changed from the Dashboard.
These functions are generated with the Thing and added at the end of this sketch.
// Ultrazvukový senzor (vodní nádrž)
#define TRIGPIN 25
#define ECHOPIN 26
int obsahNadrze;
long doba, vzdalenost;
const int prazdny = 34;
const int plny = 5;
#include "thingProperties.h"
delay(1500);
pinMode(VLAHA_A, INPUT);
pinMode(VLAHA_D, INPUT);
initProperties();
// Connect to Arduino IoT Cloud
ArduinoCloud.begin(ArduinoIoTPreferredConnection);
The following function allows you to obtain more information
related to the state of network and IoT Cloud connection and errors
the higher number the more granular information you’ll get.
The default is 0 (only errors).
Maximum is 4
setDebugMessageLevel(2);
ArduinoCloud.printDebugInfo();
ArduinoCloud.update(); // !!!!!!!!!!!!!
senzory();
void senzory() {
digitalWrite(TRIGPIN, LOW);
delayMicroseconds(2);
digitalWrite(TRIGPIN, HIGH);
delayMicroseconds(5);
doba = pulseIn(ECHOPIN, HIGH);
vzdalenost = doba / 58.31;
obsahNadrze = map(vzdalenost, prazdny, plny, 0, 100);
obsahNadrze = constrain(obsahNadrze, 0, 100);
nadrzPLNOST = obsahNadrze;
Serial.println(doba);
That is telling you that: "Returns the length of the pulse in microseconds or gives up and returns 0 if no complete pulse was received within the timeout.".
So, there is NO pulse occurring. Time to begin to track down how you have things wired and powered.
I have everything wired properly I'm 100% sure. Like I said earlier everything works when ArduinoCloud.Update(); isn't in my code. I was wondering if could be there some timing problem like the ultrasonic sensor is sending data at the same time as the Arduino update function?
This is why. It's not wrong, It's just it works. It blocks your program execution until an echo is returned or the 1 second time-out occurs. Read the documentation on pulseln().
Okay then let's put this code aside.
I have the same problem with soil moisture sensor.
Here is the code:
Thing
float flower;
int sensorPin = 25;
int sensorValue;
int procento;
#define VLAHA_A 25
#define VLAHA_D 26
int vlhkostZeminyProcent;
bool digit = 0;
// Initialize serial and wait for port to open:
// This delay gives the chance to wait for a Serial Monitor without blocking if none is found
delay(1500);
// Defined in thingProperties.h
initProperties();
ArduinoCloud.update(); // !!!!!!!!!!!!!!!!!!!!!!!
sensorValue = analogRead(sensorPin);
procento = map(sensorValue, 4095, 860, 0, 100);
Serial.print("Analog Value: ");
Serial.println(sensorValue);
Serial.print("Moisture percent: ");
Serial.print(procento);
Serial.println("%");
flower = procento;
When I Google for ESP32, I get back it is powered by 3.3 volts, not 5 volts.
So your circuit board has a regulator to ensure all is running on 3.3 volts, even when powered by a higher voltage. All the pins on your board must use 3.3 volts, in and out.
