my serial monitor doesn't show any output even after uploading and uploading my
#include<SoftwareSerial.h>
#include "DHT.h"
SoftwareSerial Serial1(2,3); // Software serial library to make pin 2 and 3 as Rx & Tx for GSM module
#define Pump_Realy 6
#define DHT_Sensor 7
#define Moisture_Sensor A0
#define DHTTYPE DHT11 // DHT 11
DHT dht(DHT_Sensor, DHTTYPE);
pinMode(Pump_Realy,OUTPUT); //Set pin 6 as OUTPUT pin
pinMode(Moisture_Sensor, INPUT);
pinMode(Moisture_Sensor, INPUT_PULLUP);
pinMode(DHT_Sensor, INPUT);
gsmInit(); // gsmInit function is called for initialize the GSM module
Serial1.begin(9600); // Initialize serial and wait for port to open - opens serial port, sets data rate to 9600 bits per second:
Serial.begin(9600); // Initialize serial and wait for port to open - opens serial port, sets data rate to 9600 bits per second:
while (! Serial); // wait for serial port to connect. Needed for native USB
Serial.println("Speed 0 to 255");
Serial.println(F("DHT11 test!"));
dht.begin();
Serial.println("DHT11 Humidity & temperature Sensor\n\n");
delay(1000); //Wait before accessing Sensor
void loop() // the loop routine runs over and over again forever:
// Reading temperature or humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
float h = dht.readHumidity(); // Read temperature as Celsius (the default)
float t = dht.readTemperature(); // Read temperature as Fahrenheit (isFahrenheit = true)
float f = dht.readTemperature(true); // Check if any reads failed and exit early (to try again).
if (isnan(h) || isnan(t) || isnan(f))
Serial.println(F("Failed to read from DHT sensor!"));
return;
float hif = dht.computeHeatIndex(f, h); // Compute heat index in Fahrenheit (the default)
float hic = dht.computeHeatIndex(t, h, false); // Compute heat index in Celsius (isFahreheit = false)
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(f);
Serial.print(F("°F Heat index: "));
Serial.print(hic);
Serial.print(hif);
Serial.println(F("°F"));
int sensorValue = analogRead(Moisture_Sensor); //Read data from soil moisture sensor
Serial.print(" Soil humidity = ");
Serial.println(sensorValue); // print out the value you read:
Serial.print("% ");
delay(10); // delay in between reads for stability
int flag=0;
if(sensorValue ==1 && flag==0)
if(sensorValue ==1)
sendSMS("Low Soil Moisture detected. Pump turned ON");
digitalWrite(Pump_Realy, HIGH); //if soil moisture sensor provides HIGH value send HIGH value to motor pump and motor pump get ON
delay(1000); //Wait for few second and then continue the loop.
flag=1;
else if(sensorValue==0 && flag==1)
if(sensorValue ==0)
sendSMS("Soil Moisture is Normal. Pump turned OFF");
digitalWrite(Pump_Realy, LOW); //if soil moisture sensor provides LOW value send LOW value to motor pump and motor pump goes OFF
flag=0;
void sendSMS(String msg) // A SMS is being sent to the user
Serial1.println("AT+CMGF=1");
Serial1.print("AT+CMGS=");
Serial1.print('"');
Serial1.print("+61452410776"); //User mobile number
Serial1.print('"');
Serial1.println();
Serial1.println(msg);
Serial1.write(26);
void gsmInit() // GSM Communication to user
boolean at_flag=1;
while(at_flag)
Serial1.println("AT");
while(Serial1.available()>0)
if(Serial1.find("OK"))
at_flag=0;
Serial1.println("ATE0");
boolean net_flag=1;
while(net_flag)
Serial1.println("AT+CPIN?");
if(Serial1.find("READY"))
net_flag=0;
Serial1.println("AT+CNMI=2,2,0,0,0");
Serial1.println("AT+CSMP=17,167,0,0");
Serial1.flush();
Have you tested if you can get the individual components to work and display the values on Serial Monitor? E.g. using an example sketch for the DHT or a simple analogRead code for the moisture sensor?
You have one (probably unrelated) bug in your code; you call gsmInit() before you have configured the baudrate for Serial1.
PS
Please read How to use this forum - please read. - Installation & Troubleshooting - Arduino Forum and pay specific attention to point #7 about posting code using code tags; next please edit your post and add the code tags.
What baud rate have you selected in the serial monitor? Does it match the 9600 set by the code?
Why does your sketch wait for Serial input? Press a key...
DrDiettrich:
Where? I think that that is for the GSM.
I know that some controllers are said to require such a loop, but others will be locked until a character arrives via USB.
OK.
That waits for the serial connection to be established, not for characters :wink:
And "required" depends on the needs; it's only required if one does not want to miss initial output of the Arduino (or possibly wants to receive data immediately (never tested).
For a test I'd simply omit that loop and find out...
DrDiettrich:
Let me know your results :smiley: :smiley:
