My serial monitor isn't working
My Serial monitor isn't functioning it is coded to show me the water levels as an analog output and was functioning well the first tries but know it only shows "o" zero I need help
int pump =2;
int sensorPower =6;
int sensorpin =A0;
int threshold =700;
int waterdelay =750;
int waterpostdelay =5000;
void setup(){
     pinMode(sensorpin, INPUT);
     pinMode(pump, OUTPUT);
void loop(){
     int SensorValue = analogRead(sensorpin);
     if(SensorValue <=threshold){
           digitalWrite(pump, HIGH);
           delay(waterdelay);
           digitalWrite(pump, LOW);
           delay(waterpostdelay);
     else{
     Serial.print("Analog output: ");
     Serial.println(readSensor());
int readSensor() {
  digitalWrite(sensorPower, HIGH);
  delay(10);
  int val =analogRead(sensorpin);
  digitalWrite(sensorPower, LOW);
```That is the code I used but the serial monitor shows
Analog output : 0   everytime I upload the code
Welcome to the forum
Your readSensor() function does not return a value. You will have received warnings about that if you have verbose reporting turned on
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved202449-4916-8ytqwn.5cngt\sketch_may9a\sketch_may9a.ino: In function 'int readSensor()':
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved202449-4916-8ytqwn.5cngt\sketch_may9a\sketch_may9a.ino:38:9: warning: unused variable 'val' [-Wunused-variable]
C:\Users\Bob2\AppData\Local\Temp\.arduinoIDE-unsaved202449-4916-8ytqwn.5cngt\sketch_may9a\sketch_may9a.ino:40:1: warning: no return statement in function returning non-void [-Wreturn-type]
Thanks it actually worked I had missed the return val
It's the compiler warning setting, not the verbose output :slight_smile:
@jayson45tfgjhvgytfjk, set it to All
