#include "esp_camera.h"
#include <WiFi.h>
#include "esp_timer.h"
#include "img_converters.h"
#include "Arduino.h"
#include "fb_gfx.h"
#include "soc/soc.h" //disable brownout problems
#include "soc/rtc_cntl_reg.h" //disable brownout problems
#include "esp_http_server.h"
#include "fd_forward.h"
#include "fr_forward.h"
//Replace with your network credentials
const char* ssid = "Asyrafwifi@unifi";
const char* password = "PanliA559";
#define PART_BOUNDARY "123456789000000000000987654321"
#define PWDN_GPIO_NUM 32
#define RESET_GPIO_NUM -1
#define XCLK_GPIO_NUM 0
#define SIOD_GPIO_NUM 26
#define SIOC_GPIO_NUM 27
#define Y9_GPIO_NUM 35
#define Y8_GPIO_NUM 34
#define Y7_GPIO_NUM 39
#define Y6_GPIO_NUM 36
#define Y5_GPIO_NUM 21
#define Y4_GPIO_NUM 19
#define Y3_GPIO_NUM 18
#define Y2_GPIO_NUM 5
#define VSYNC_GPIO_NUM 25
#define HREF_GPIO_NUM 23
#define PCLK_GPIO_NUM 22
#define FACE_COLOR_RED 0x000000FF
#define FACE_COLOR_GREEN 0x0000FF00
#define FACE_COLOR_YELLOW (FACE_COLOR_RED | FACE_COLOR_GREEN)
#define DETECT_FACE_TIME 2000
#define NUM_FRAME 10
#define PERCENT_WEAR_MASK_TH 80
#define START_RUN 'a'
#define RESTART_ESP32 'r'
#define RESTART_SCAN 'n'
typedef struct {
size_t size; //number of values used for filtering
size_t index; //current value index
size_t count; //value count
int sum;
int * values; //array to be filled with values
} ra_filter_t;
static const char* _STREAM_CONTENT_TYPE = "multipart/x-mixed-replace;boundary=" PART_BOUNDARY;
static const char* _STREAM_BOUNDARY = "\r\n--" PART_BOUNDARY "\r\n";
static const char* _STREAM_PART = "Content-Type: image/jpeg\r\nContent-Length: %u\r\n\r\n";
httpd_handle_t stream_httpd = NULL;
static mtmn_config_t mtmn_config = {0};
static int8_t detection_enabled = 1;
static ra_filter_t ra_filter;
short gsFace_Detected = 0;
short gsIsInStream = 0;
short gusRestart_Scan = 0;
unsigned long gulStart_IsInStream_Reset_Timer = 0;
short gsArrayIsFaceDetect[NUM_FRAME] = {0,0,0,0,0,0,0,0,0,0};
unsigned short gusIsMask_Detect = 0;
unsigned short gusFrame_Count = 0;
unsigned short gusIsStart = 0;
WRITE_PERI_REG(RTC_CNTL_BROWN_OUT_REG, 0); //disable brownout detector
Serial.setDebugOutput(false);
camera_config_t config;
config.ledc_channel = LEDC_CHANNEL_0;
config.ledc_timer = LEDC_TIMER_0;
config.pin_d0 = Y2_GPIO_NUM;
config.pin_d1 = Y3_GPIO_NUM;
config.pin_d2 = Y4_GPIO_NUM;
config.pin_d3 = Y5_GPIO_NUM;
config.pin_d4 = Y6_GPIO_NUM;
config.pin_d5 = Y7_GPIO_NUM;
config.pin_d6 = Y8_GPIO_NUM;
config.pin_d7 = Y9_GPIO_NUM;
config.pin_xclk = XCLK_GPIO_NUM;
config.pin_pclk = PCLK_GPIO_NUM;
config.pin_vsync = VSYNC_GPIO_NUM;
config.pin_href = HREF_GPIO_NUM;
config.pin_sscb_sda = SIOD_GPIO_NUM;
config.pin_sscb_scl = SIOC_GPIO_NUM;
config.pin_pwdn = PWDN_GPIO_NUM;
config.pin_reset = RESET_GPIO_NUM;
config.xclk_freq_hz = 20000000;
config.pixel_format = PIXFORMAT_JPEG;
config.frame_size = FRAMESIZE_QVGA;
config.jpeg_quality = 10;
config.fb_count = 1;
// Camera init
esp_err_t err = esp_camera_init(&config);
if (err != ESP_OK) {
Serial.printf("Camera init failed with error 0x%x", err);
return;
sensor_t * s = esp_camera_sensor_get();
s->set_vflip(s, 1);//flip camera
//s->set_brightness(s, 1);//up the blightness just a bit
//s->set_saturation(s, -2);//lower the saturation
// Wi-Fi connection
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
delay(100);
Serial.print("#");
Serial.print(WiFi.localIP());
Serial.println(",");
mtmn_config = mtmn_init_config();
// Start streaming web server
startCameraServer();
short sNum_Detect = 0;
short sPercent_Wear_Mask = 0;
char szData[10];
char szTemp[10];
memset(szData, '\0', sizeof(szData));
if(usRead_Serial_Data(szData, sizeof(szData)) > 0) //read data request from Arduino
if(szData[0] == START_RUN) // start face_detection algorithm
gusIsStart = 1;
gusFrame_Count = 0;
else if(szData[0] == RESTART_ESP32) // restart ESP32-CAM in case of ESP32-CAM hung up
ESP.restart();
else if(szData[0] == RESTART_SCAN)
gusRestart_Scan = 1;
if(gsIsInStream == 1)
if(millis() - gulStart_IsInStream_Reset_Timer > DETECT_FACE_TIME)
gsIsInStream = 0;
else if(gsIsInStream == 0)
if(gusIsStart == 1)
vFace_Detection_Offline();
if(gusFrame_Count >= NUM_FRAME) // scanning for 10 times
for(short i=0; i<NUM_FRAME; i++)
if(gsArrayIsFaceDetect[i] == 0)
sNum_Detect++; // number of face not detected
sPercent_Wear_Mask = map(sNum_Detect, 0, NUM_FRAME, 0, 100); //calculate the percentage of face not detected
if(gusRestart_Scan == 1)
Serial.println('\0');
memset(szTemp, '\0', sizeof(szTemp));
sprintf(szTemp, "*%d,",sPercent_Wear_Mask);
Serial.println(szTemp); //send percentage number to Arduino
gusFrame_Count = 0;
gusIsStart = 0;
void startCameraServer()
httpd_config_t config = HTTPD_DEFAULT_CONFIG();
config.server_port = 80;
httpd_uri_t index_uri = {
.uri = "/",
.method = HTTP_GET,
.handler = stream_handler,
.user_ctx = NULL
ra_filter_init(&ra_filter, 20);
mtmn_config.type = FAST;
mtmn_config.min_face = 80;
mtmn_config.pyramid = 0.707;
mtmn_config.pyramid_times = 4;
mtmn_config.p_threshold.score = 0.6;
mtmn_config.p_threshold.nms = 0.7;
mtmn_config.p_threshold.candidate_number = 20;
mtmn_config.r_threshold.score = 0.7;
mtmn_config.r_threshold.nms = 0.7;
mtmn_config.r_threshold.candidate_number = 10;
mtmn_config.o_threshold.score = 0.7;
mtmn_config.o_threshold.nms = 0.7;
mtmn_config.o_threshold.candidate_number = 1;
//Serial.printf("Starting web server on port: '%d'\n", config.server_port);
if (httpd_start(&stream_httpd, &config) == ESP_OK) {
httpd_register_uri_handler(stream_httpd, &index_uri);
static esp_err_t stream_handler(httpd_req_t *req)
camera_fb_t * fb = NULL;
esp_err_t res = ESP_OK;
size_t _jpg_buf_len = 0;
uint8_t * _jpg_buf = NULL;
char * part_buf[64];
dl_matrix3du_t *image_matrix = NULL;
bool detected = false;
int face_id = 0;
static int64_t last_frame = 0;
if(!last_frame)
last_frame = esp_timer_get_time();
res = httpd_resp_set_type(req, _STREAM_CONTENT_TYPE);
if(res != ESP_OK)
return res;
httpd_resp_set_hdr(req, "Access-Control-Allow-Origin", "*");
while(true)
gsIsInStream = 1;
gulStart_IsInStream_Reset_Timer = millis(); //restart timer
detected = false;
face_id = 0;
fb = esp_camera_fb_get();
if (!fb)
Serial.println("Camera capture failed");
res = ESP_FAIL;
if(!detection_enabled || fb->width > 400)
if(fb->format != PIXFORMAT_JPEG)
bool jpeg_converted = frame2jpg(fb, 80, &_jpg_buf, &_jpg_buf_len);
esp_camera_fb_return(fb);
fb = NULL;
if(!jpeg_converted)
Serial.println("JPEG compression failed");
res = ESP_FAIL;
_jpg_buf_len = fb->len;
_jpg_buf = fb->buf;
image_matrix = dl_matrix3du_alloc(1, fb->width, fb->height, 3);
if (!image_matrix)
Serial.println("dl_matrix3du_alloc failed");
res = ESP_FAIL;
if(!fmt2rgb888(fb->buf, fb->len, fb->format, image_matrix->item))
Serial.println("fmt2rgb888 failed");
res = ESP_FAIL;
box_array_t *net_boxes = NULL;
if(gusIsStart == 1)
net_boxes = face_detect(image_matrix, &mtmn_config);
//gusFrame_Count++;
if (net_boxes || fb->format != PIXFORMAT_JPEG)
if(net_boxes)
detected = true;
draw_face_boxes(image_matrix, net_boxes);
free(net_boxes->score);
free(net_boxes->box);
free(net_boxes->landmark);
free(net_boxes);
if(!fmt2jpg(image_matrix->item, fb->width*fb->height*3, fb->width, fb->height, PIXFORMAT_RGB888, 90, &_jpg_buf, &_jpg_buf_len))
Serial.println("fmt2jpg failed");
res = ESP_FAIL;
fb = NULL;
_jpg_buf = fb->buf;
dl_matrix3du_free(image_matrix);
if(res == ESP_OK)
size_t hlen = snprintf((char *)part_buf, 64, _STREAM_PART, _jpg_buf_len);
res = httpd_resp_send_chunk(req, (const char *)part_buf, hlen);
if(res == ESP_OK)
res = httpd_resp_send_chunk(req, (const char *)_jpg_buf, _jpg_buf_len);
if(res == ESP_OK)
res = httpd_resp_send_chunk(req, _STREAM_BOUNDARY, strlen(_STREAM_BOUNDARY));
if(fb)
fb = NULL;
_jpg_buf = NULL;
else if(_jpg_buf)
free(_jpg_buf);
_jpg_buf = NULL;
if(res != ESP_OK)
if(detected == 1)
gsFace_Detected = 1; //detect face
if(gusIsStart == 1)
if(gusFrame_Count < NUM_FRAME)
gsArrayIsFaceDetect[gusFrame_Count] = gsFace_Detected;
gusIsStart = 0; //Reset
gusFrame_Count++;
delay(1);
last_frame = 0;
return res;
void vFace_Detection_Offline()
camera_fb_t * frame;
frame = esp_camera_fb_get();
dl_matrix3du_t *image_matrix = dl_matrix3du_alloc(1, frame->width, frame->height, 3);
fmt2rgb888(frame->buf, frame->len, frame->format, image_matrix->item);
esp_camera_fb_return(frame);
box_array_t *boxes = face_detect(image_matrix, &mtmn_config);
if(boxes)
free(boxes->score);
free(boxes->box);
free(boxes->landmark);
free(boxes);
gusFrame_Count++;
static void draw_face_boxes(dl_matrix3du_t *image_matrix, box_array_t *boxes)
int x, y, w, h, i;
uint32_t color = FACE_COLOR_YELLOW;
fb_data_t fb;
fb.width = image_matrix->w;
fb.height = image_matrix->h;
fb.data = image_matrix->item;
fb.bytes_per_pixel = 3;
fb.format = FB_BGR888;
for (i = 0; i < boxes->len; i++){
// rectangle box
x = (int)boxes->box[i].box_p[0];
y = (int)boxes->box[i].box_p[1];
w = (int)boxes->box[i].box_p[2] - x + 1;
h = (int)boxes->box[i].box_p[3] - y + 1;
fb_gfx_drawFastHLine(&fb, x, y, w, color);
fb_gfx_drawFastHLine(&fb, x, y+h-1, w, color);
fb_gfx_drawFastVLine(&fb, x, y, h, color);
fb_gfx_drawFastVLine(&fb, x+w-1, y, h, color);
#if 0
// landmark
int x0, y0, j;
for (j = 0; j < 10; j+=2) {
x0 = (int)boxes->landmark[i].landmark_p[j];
y0 = (int)boxes->landmark[i].landmark_p[j+1];
fb_gfx_fillRect(&fb, x0, y0, 3, 3, color);
#endif
static ra_filter_t * ra_filter_init(ra_filter_t * filter, size_t sample_size){
memset(filter, 0, sizeof(ra_filter_t));
filter->values = (int *)malloc(sample_size * sizeof(int));
if(!filter->values){
return NULL;
memset(filter->values, 0, sample_size * sizeof(int));
filter->size = sample_size;
return filter;
static int ra_filter_run(ra_filter_t * filter, int value){
return value;
filter->sum -= filter->values[filter->index];
filter->values[filter->index] = value;
filter->sum += filter->values[filter->index];
filter->index++;
filter->index = filter->index % filter->size;
if (filter->count < filter->size) {
filter->count++;
return filter->sum / filter->count;
unsigned short usRead_Serial_Data(char *szData, short sDataSize)
short i=0;
if(Serial.available())
*(szData+i) = Serial.read();
i++;
delay(2);
while(Serial.available())
i++;
if(i >= sDataSize)
delay(2);
return i;
