I use 4 servo (mg995)
my servo always go to 90 degree before the degree that I wanted
this is the code of arduino
#include <Servo.h>
Servo servo0; // servo up&down for camera
Servo servo1; // servo right%left for camera
Servo servo2; // servo up&down for hose
Servo servo3; // servo right%left for hose
int servo_0_angle ; // servo up&down for camera
int servo_1_angle ; // servo right%left for camera
int servo_2_angle ; // servo up&down for hose
int servo_3_angle ; // servo right%left for hose
int relay = 0 ;
int sum =0 ;
void setup(){
// Set the baud rate
servo0.attach(2); // servo up&down for camera
servo1.attach(13); // servo right%left for camera
servo2.attach(26); // servo up&down for hose
servo3.attach(42); // servo right%left for hose
pinMode(5, OUTPUT);
digitalWrite(5, LOW);
void loop(){
if(Serial.available() > 0 ) {
servo_0_angle = Serial.parseInt();
servo_1_angle = Serial.parseInt();
servo_2_angle = Serial.parseInt();
servo_3_angle = Serial.parseInt();
relay = Serial.parseInt();
if(servo_0_angle > 0)
servo0.write(servo_0_angle);
delay(1000) ;
if(servo_1_angle > 0)
servo1.write(servo_1_angle);
delay(1000) ;
if(relay > 0){
if(servo_2_angle > 0)
servo2.write(servo_2_angle);
delay(1000) ;
if(servo_3_angle > 0)
servo3.write(servo_3_angle);
delay(1000) ;
digitalWrite(5, HIGH);
delay(5000);
relay = 0 ; }
// Compute a sum to prove we have integers
sum = servo_0_angle + servo_1_angle + servo_2_angle + servo_3_angle ;
// We do println to add a new line character '\n' at the end
// of the comma-separated stream of integers
Serial.print(servo_0_angle); Serial.print(",");
Serial.print(servo_1_angle); Serial.print(",");
Serial.print(servo_2_angle); Serial.print(",");
Serial.print(servo_3_angle); Serial.print(",");
Serial.print(relay); Serial.print(",");
Serial.println(sum);
