Hello guys!
I'm working on a project where I have attached a HMC5883L and MPU 9250. The readings from both the devices are fine.
Problem is when I servo write my MPU value to servo motor, it's heating up to the point it stops working.
I was wondering that is it a coincident that two of the servos turned out to be faulty or is it something in the code causing that?
thanks!
junaidhalepota:
hadn't tried it before running it with the code, but definitely not after burning...
Then you need a new servo - but you probably did not need me to tell you that.
The overheating may have been caused by your code trying to force the motor beyond its physical end-stop. Servos are not designed to be able to produce their maximum torque continuously.
