My servo motor isnt moving when ir sensor senses something
I am trying to get the servo motor to turn 180 degrees and then back to 0 degrees when the IR sensor senses something Circuit. techleader
import time
from pyfirmata import Arduino, util
board = Arduino('COM5')
iterator = util.Iterator(board)
iterator.start()
motor = board.get_pin('d:6:s')
sensorPinNo = 2
sensorPin = board.get_pin('d:' + str(sensorPinNo) + ':i')
print("Nothing is being sensed ")
rlt = sensorPin.read()
while True:
    if rlt:
        print("Sensor has detected something")
        def setServoAngle(angle):
            print("Wiping In Progress")
            for i in range(0, 180):
                setServoAngle(i)
                motor.write(angle)
            for i in range(180, 1, -1):
                setServoAngle(i)
                motor.write(angle)
        print("Program Exit")
        board.exit()
I have: Arduino uno, servo motor, IR sensor, Buzzer, LED, Resistors, Breadboard, Jumper wires
Are you going to post the Arduino code ?
…all of it ..
