My Servo vibrates rapidly.
The servo (Futaba S3003) that I am using for my project sometimes vibrates rapidly after it has finished rotating. I have to give it a little push with my finger to get it to stop, which sort of defeats the purpose of the whole project because my project was simply to control a servo remotely using two buttons, one to rotate clockwise 90 degrees, and the other button to rotate 90 degrees anticlockwise.
I thought it may have because both of my if statements are inside the void loop (), so they could be repeatedly running. To fix this I created a variable called limiter, to make sure no same rotation could happen twice in a row.
Is it possible to do what I've done below or am I missing something?
I declared "int limiter = 1;" in void setup ()
void loop(){
  // read the state of the pushbutton value:
  buttonState = digitalRead(buttonPin);
if (buttonState == HIGH && limiter == 1) {
    // rotate clockwise
    myservo.writeMicroseconds(1800);
    limiter = 2;
  if (buttonState != HIGH && limiter == 2) {
    // rotate anticlockwise
    myservo.writeMicroseconds(1200);
    limiter = 1;
I really hope there's a problem somewhere there (there's definitely no problem elsewhere) because I don't want to have to buy a bloody servo again, it takes ages to deliver too. :0 Cheers :blush:
Hopefully you are not attempting to power the servo from the Arduino. If so, don't. Use a separate power supply and connect the grounds together.
I second what jremington said, plus make sure you are using bypass capacitors on both power supplies.
Two button servo code.
//zoomkat servo button test 12-29-2011
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include <Servo.h>
int button1 = 4; //button pin, connect to ground to move servo
int press1 = 0;
int button2 = 5; //button pin, connect to ground to move servo
int press2 = 0;
Servo servo1;
  pinMode(button1, INPUT);
  pinMode(button2, INPUT);
  servo1.attach(7);
  digitalWrite(4, HIGH); //enable pullups to make pin high
  digitalWrite(5, HIGH); //enable pullups to make pin high
  press1 = digitalRead(button1);
  if (press1 == LOW)
    servo1.write(170);
  press2 = digitalRead(button2);
  if (press2 == LOW)
    servo1.write(10);
