My sketch doesn't seem to start if the serial monitor is not open
This is exactly as it seems, I have sufficient power, i'm running windows. I have no errors when uploading the sketch works perfectly when the usb cable is connected but for some reason when the cable isn't connected it wont run. What have I done wrong? I have a 10k resistor from RX to the GND pin and I've looked everywhere. I'm using an Arduino Leonardo with a WiFi shield. All I need to do is plug it into my computer and open the serial monitor it works. WTH?
#include <Thread.h>
#include <SPI.h>
#include <WiFi.h>
#include <WiFiUdp.h>
#ifdef __AVR__
#include <avr/power.h>
#endif
#define PIN      6
#define NUMPIXELS      30
// Time Gatherer data
char ssid[] = "RexNetLocal";  //  your network SSID (name)
char pass[] = "8602055300";       // your network password
unsigned int localPort = 2390;      // local port to listen for UDP packets
int keyIndex = 0;
int status = WL_IDLE_STATUS;
IPAddress timeServer(129, 6, 15, 28); // time.nist.gov NTP server
const int NTP_PACKET_SIZE = 48;
byte packetBuffer[ NTP_PACKET_SIZE];
WiFiUDP Udp; //Udp for pulling data
int hour;
int minute;
int second;
//Pixel Control Thread Data
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
Thread pixelControlThread = Thread();
//Pixel Mainthread Method
void pixelCallback(){
  Serial.print("\nPixel Callback Method Called at : ");
  Serial.print(hour);
  Serial.print(':');
  Serial.print(minute);
  Serial.print(':');
  Serial.println(second);
  int brightness;
  int sunrise = 4;
  int sunset = 22;
  if(hour == sunrise - 1){
    brightness = (255.0*(minute/120.0));
  } else if(hour == sunrise){
    brightness = (255.0*((minute+60.0)/120.0));
  } else if(hour == sunset - 1){
    brightness = (255.0 - (255.0*(minute/120.0)));
  } else if(hour == sunset){
    Serial.println("sunset");
    brightness = (255.0 - (255.0*((minute+60.0)/120.0)));
  } else if (hour > sunset || hour < sunrise){
    brightness = 0.0;
  } else if (hour < sunset){
    brightness = 255.0;
    Serial.print("ERROR");
    brightness = 255;
  Serial.print("Brightness set to: ");
  Serial.println(brightness);
  for(int i=0;i<30;i++){
    pixels.setPixelColor(i, pixels.Color(brightness,brightness,0)); // Yellow color that shifts with the daytime.
  pixels.show(); // This sends the updated pixel color to the hardware.
void setup(){
  pixels.begin(); // This initializes the NeoPixel library.
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  // check for the presence of the shield:
  if (WiFi.status() == WL_NO_SHIELD) {
    Serial.println("WiFi shield not present");
    // don't continue:
    while (true);
  // attempt to connect to Wifi network:
  while (status != WL_CONNECTED) {
    Serial.print("Attempting to connect to SSID: ");
    Serial.println(ssid);
    status = WiFi.begin(ssid, pass);
    delay(15000);
  Serial.println("\nConnected to WiFi");
  printWifiStatus();
  Serial.println("\nStarting connection to server...");
  Udp.begin(localPort);
  pixelControlThread.onRun(pixelCallback);
  pixelControlThread.setInterval(500);
void loop(){
  sendNTPpacket(timeServer); // send an NTP packet to a time server
  // wait to see if a reply is available
  while(!Udp.parsePacket()){
  if (Udp.parsePacket()) {
    Udp.read(packetBuffer, NTP_PACKET_SIZE); // read the packet into the buffer
    //the timestamp starts at byte 40 of the received packet and is four bytes,
    // or two words, long. First, esxtract the two words:
    unsigned long highWord = word(packetBuffer[40], packetBuffer[41]);
    unsigned long lowWord = word(packetBuffer[42], packetBuffer[43]);
    unsigned long secsSince1900 = highWord << 16 | lowWord;
    const unsigned long seventyYears = 2208988800UL;
    unsigned long epoch = secsSince1900 - (60*60*4) - seventyYears;
    Serial.print("\nThe EST time is ");       // UTC is the time at Greenwich Meridian (GMT)
    Serial.print(((epoch  % 86400L) / 3600)); // print the hour (86400 equals secs per day)
    hour = (((epoch  % 86400L) / 3600));
    Serial.print(':');
    if (((epoch % 3600) / 60) < 10) {
      // In the first 10 minutes of each hour, we'll want a leading '0'
      Serial.print('0');
    Serial.print((epoch  % 3600) / 60); // print the minute (3600 equals secs per minute)
    minute = ((epoch  % 3600) / 60);
    Serial.print(':');
    if ((epoch % 60) < 10) {
      // In the first 10 seconds of each minute, we'll want a leading '0'
      Serial.print('0');
    Serial.println(epoch % 60); // print the second
    second = (epoch % 60);
  if(pixelControlThread.shouldRun())
  pixelControlThread.run();
  // wait ten seconds before asking for the time again
  delay(10000);
// send an NTP request to the time server at the given address
unsigned long sendNTPpacket(IPAddress& address) {
  //Serial.println("1");
  // set all bytes in the buffer to 0
  memset(packetBuffer, 0, NTP_PACKET_SIZE);
  // Initialize values needed to form NTP request
  // (see URL above for details on the packets)
  //Serial.println("2");
  packetBuffer[0] = 0b11100011;   // LI, Version, Mode
  packetBuffer[1] = 0;     // Stratum, or type of clock
  packetBuffer[2] = 6;     // Polling Interval
  packetBuffer[3] = 0xEC;  // Peer Clock Precision
  // 8 bytes of zero for Root Delay & Root Dispersion
  packetBuffer[12]  = 49;
  packetBuffer[13]  = 0x4E;
  packetBuffer[14]  = 49;
  packetBuffer[15]  = 52;
  //Serial.println("3");
  // all NTP fields have been given values, now
  // you can send a packet requesting a timestamp:
  Udp.beginPacket(address, 123); //NTP requests are to port 123
  //Serial.println("4");
  Udp.write(packetBuffer, NTP_PACKET_SIZE);
  //Serial.println("5");
  Udp.endPacket();
  //Serial.println("6");
void printWifiStatus() {
  // print the SSID of the network you're attached to:
  Serial.print("\nSSID: ");
  Serial.println(WiFi.SSID());
  // print your WiFi shield's IP address:
  IPAddress ip = WiFi.localIP();
  Serial.print("IP Address: ");
  Serial.println(ip);
  // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("signal strength (RSSI):");
  Serial.print(rssi);
  Serial.println(" dBm");
rex_dorchester:
So what's providing the power when the USB cable is disconnected?
  while (!Serial) {
Comment this out and see what happens.
