hi all;
I've tried re-uploading the code and pressing the rest key, but neither can get rid of the snowflakes,thanks for you help.
hi all;
Does your code fill the screen with black to start with?
I can only recommend redoing the TFT display jumper wires ohterwise.
Are you certain you are using the correct library for that display?
The soldering on the header pins looks questionable.
#include <Arduino.h>
#include <TFT_eSPI.h>
#include "I2Cdev.h"
#include "MPU6050.h"
#include "Wire.h"
#define WIDTH 128
#define HEIGHT 160
int16_t ax, ay, az;
int16_t gx, gy, gz;
MPU6050 accelgyro;
TFT_eSPI tft = TFT_eSPI();
TFT_eSprite spr = TFT_eSprite(&tft);
Wire.begin();
accelgyro.setXGyroOffset(220);
accelgyro.setYGyroOffset(76);
accelgyro.setZGyroOffset(-85);
spr.createSprite(WIDTH, HEIGHT);
tft.init();
tft.setRotation(1);
spr.fillScreen(TFT_BLACK);
spr.setTextFont(2);
spr.setTextSize(1);
spr.setTextColor(TFT_GREEN);
accelgyro.initialize();
accelgyro.testConnection();
if (accelgyro.testConnection())
Serial.println("MPU6050 connection successful");}
{Serial1.println("MPU6050 connection failed");}
// accelgyro.getMotion6(&ax, &ay, &az, &gx, &gy, &gz);
accelgyro.getAcceleration(&ax, &ay, &az);
accelgyro.getRotation(&gx, &gy, &gz);
spr.setCursor(0, 0);
spr.drawString("X:" +String(ax), 0, 0);
spr.drawString("Y:" +String(ay), 0, 40);
spr.drawString("Z:" +String(az), 0, 80);
spr.drawString("GX:" +String(gx), 70, 0);
spr.drawString("GY:" +String(gy), 70, 40);
spr.drawString("GZ:" +String(gz), 70, 80);
spr.pushSprite(0,0);
There was no problem when I uploaded the code, but snowflakes appeared on the Type-C cable after shaking for a while. I also reconnected the jumper, but it didn't seem to work, but thank you for your suggestion.
Do you have another cable that makes a more solid connection?
Alternatively, power the board using a mechanically secure connection from a power supply.
Does it work if you disconnect the power then reconnect?
TFT_eSPI
I am using this library, but the problem is not with the soldering. I heard the computer prompt that the Type-C cable shook a little, and snowflakes appeared.
What happens when you unplug the Type-C cable then plug it back in?
Re-inserting the Type-C cable did not solve it, but I used the code tft.setRotation(1); to rotate to parameter 3, and then rotated back to parameter 1, which solved most of the snowflakes, thank you for your help.
