Hello
I am a bit suprise about what return a 'Serial.print()' while I want to print a struct.
I am rewriting my code, and I want to have a file for each station, with different default values.
For exemple, I define if a sensor is active or not, or a analog pin where a sensor is connected to.
I created a struct as the following
struct ini_station
const char* nom;
const int station_id;
bool actif; //Activate station: true/false
const int32_t tx_interval; // // (sec) 15, 30, 60 (1mn), 120 (2mn), 300 (5mn), 900 (15mn), 1800 (30mn), 3600sec (1h)
const bool mprint; // Display print in the terminal
const int sd; //Activate SD card: 0=inactive; 1=active; 2=active and read config from SD
//boolean conf_from_sd = false; // If sd is active and conf_from_sd, the sensor configuration from SD will considered instead of the conf from that ino file
bool logger; // (sd must be true) If true, the station activity will be saved into the SD card
const bool oled; // Activate the OLED display
const bool rtc; // Activate the RTC DS3231 clock
const bool eeprom; // Activate the EEPROM chip. It must be true to save the LoRaWAN keys
const bool watchdog;
const bool sleepMode;
const int lora; // 0=unactivate LoRaWAN; 1=OTAA; 2=ABP
const bool temperature_active; // te; a;
const bool pressure_active; // pr; b;
const bool humidity_active; // hu; c
const bool luminosity_active; // lu; d;
const byte wm1_active; // w1; e;
const byte wm2_active; // w2; f;
const byte wm3_active; // w3; g;
const bool datetime_active; // da; h;
const bool temperature_soil_active; // ts; i; // Must define the analog pin
const byte gauge_active; // ga; j;
const bool battery_active; // ba; k;
const byte wattering_active; // ar; l;
const byte aneno_active; // an; m;
const bool irtemp_active; // ir; n;
const bool wrm_active; // wr; o
const byte bud1_active; // b1; p;
const byte bud2_active; // b2; q;
const byte bud3_active; // b3; r;
const byte bud4_active; // b4; s;
const byte sun_active; // su; t;
const byte wdirection_active; // wd; u;
const byte wdirection_offset;
const byte sf110bud_active; // sb; v;
const byte sf110leaf_active; // sl; w;
const char * nomDuCapteur;
const uint8_t codeDuCapteur;
ini_station station = {
"Station 23", // Station name
23, // station ID
true, // station active (true or false)
900, // TX INTERVAL (sec) 15, 30, 60 (1mn), 120 (2mn), 300 (5mn), 900 (15mn), 1800 (30mn), 3600sec (1h)
true, // mprint
0, // SD card: 0=inactive; 1=active; 2=active and read config from SD
true, // LOGGER: (SD must not be 0) If true, the station activity will be saved into the SD card
false, // OLED: Active or not
true, // RTC DS3231 I2C
true, // EEMPROM: Active or not
true, // Watchdog
false, // SLEEP: Active the sleep mode (Arduinolowpower)
1, // LoRaWAN: 0=unactivate; 1=OTAA; 2=ABP; 10=OTAA disable sending; 20=ABP disable sending
false, // te; a;
false, // pr; b;
false, // hu; c
false, // lu; d;
0, // w1; e; // 0=Unactive; 14=A0; *15=A1*; 16=A2; 17=A3; 18=A4; 19=A5
0, // w2; f; // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
0, // w3; g; // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
false, // da; h;
false, // ts; i; // Must define the analog pin
0, // ga; j; // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
false, // ba; k;
0, // ar; l; // WATTERING // 0=Unactive; 14=A0; 15=A1; 16=A2; 17=A3; *18=A4*; 19=A5
0, // an; m; // WWIND SPEED // 0=Unactive; *14=A0*; 15=A1; 16=A2; 17=A3; 18=A4; 19=A5
true, // ir; n;
false, // wr; o
14, // b1; p; // 0=Unactive; *14=A0*; 15=A1; 16=A2; 17=A3; 18=A4; 19=A5
15, // b2; q; // 0=Unactive; 14=A0; *15=A1*; 16=A2; 17=A3; 18=A4; 19=A5
16, // b3; r; // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
17, // b4; s; // 0=Unactive; 14=A0; 15=A1; 16=A2; *17=A3*; 18=A4; 19=A5
0, // su; t; // SUN: // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
0, // wd; u; //WIND DIRECTION 0=Unactive; 14=A0; *15=A1*; 16=A2; 17=A3; 18=A4; 19=A5 and the WindDirectionOffset
0, // Offset of the wind direction bar from the Noth (Degree). 0 if the bar point to the North
0, // sb; v; // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
0, // sl; w; // 0=Unactive; 14=A0; 15=A1; *16=A2*; 17=A3; 18=A4; 19=A5
Then in my ino file, at some point, I print the configuration
Serial.print(F("Name:\t")); Serial.println(F(station.nom));
Serial.print(F("Station ID:\t")); Si.sprintln(F(station.station_id),0);
Serial.print(F("Interval (s):\t")); Serial.println(F(station.tx_interval));
Serial.print(F("Print:\t")); Serial.println(F(station.mprint));
Serial.print(F("SD:\t")); Serial.println(F(station.sd));
if(station.sd == 0) station.logger = false;
Serial.print(F("Logger:\t")); Serial.println(F(station.logger));
Serial.print("\t"); Serial.println(F("! SD must be active !"));
Serial.print(F("OLED:\t")); Serial.println(F(station.oled));
Serial.print(F("RTC:\t")); Serial.println(F(station.rtc));
Serial.print(F("EEPROM:\t")); Serial.println(F(station.eeprom));
Serial.print(F("Watchdog:\t")); Serial.println(F(station.watchdog));
Serial.print(F("Sleep mode:\t")); Serial.println(F(station.sleepMode));
Serial.print(F("LoRaWAN:\t")); Serial.println(F(station.lora));
Serial.println(F("SENSORS"));
Serial.print(F("Temperature (I2C):\t")); Serial.println(F(station.temperature_active));
Serial.print(F("Pression (I2C):\t")); Serial.println(F(station.pressure_active));
Serial.print(F("Humidity (I2C):\t")); Serial.println(F(station.humidity_active));
Serial.print(F("Luminosity (I2C):\t")); Serial.println(F(station.luminosity_active));
Serial.print(F("Watermark 1:\t")); Serial.println(F(station.wm1_active));
Serial.print(F("Watermark 2:\t")); Serial.println(F(station.wm2_active));
Serial.print(F("Watermark 3:\t")); Serial.println(F(station.wm3_active));
Serial.print(F("RTC Date/Time (I2C):\t")); Serial.println(F(station.datetime_active));
Serial.print(F("Temperature Soil (1Wire):\t")); Serial.println(F(station.temperature_soil_active));
Serial.print(F("Rain:\t")); Serial.println(F(station.gauge_active));
Serial.print(F("Battery:\t")); Serial.println(F(station.battery_active));
Serial.print(F("Wattering:\t")); Serial.println(F(station.wattering_active));
Serial.print(F("Wind speed:\t")); Serial.println(F(station.aneno_active));
Serial.print(F("Temp. IR (I2C):\t")); Serial.println(F(station.irtemp_active));
Serial.print(F("WRM:\t")); Serial.println(F(station.wrm_active));
Serial.print(F("Bud 1:\t")); Serial.println(F(station.bud1_active));
Serial.print(F("Bud 2:\t")); Serial.println(F(station.bud2_active));
Serial.print(F("Bud 3:\t")); Serial.println(F(station.bud3_active));
Serial.print(F("Bud 4:\t")); Serial.println(F(station.bud4_active));
Serial.print(F("Sun:\t")); Serial.println(F(station.sun_active));
Serial.print(F("Wind direction:\t")); Serial.println(F(station.wdirection_active));
Serial.print(F("SF110 Bud:\t")); Serial.println(F(station.sf110bud_active));
Serial.print(F("SF110 Leaf:\t")); Serial.println(F(station.sf110leaf_active));
Only the first line print: Station 23 and the second line should print 23
The third should print 900 and the forth 0 for false.
Oever, all ine excepted the first, print nothing
How can it be possible, that Serial.print do not print a int, byte or bool varaiable?
