I'm using Arduino Uno for my load cell project is not showing in my port area still yesterday , I'm try to add my drivers also and that my all ports are working properly because I'm check my pend rive to confirm that working or not , so how can I solve this issue
Some questions
- Did it work before?
- Is it recognised if you disconnect evevrything except the USB?
- Which operating system?
- What does your operating system think about your board (e.g. windows device manager, linux lsusb and dmesg, no idea about a Mac)?
- Which version of the IDE?
- Do you have a link to the exact Uno that you bought?
1.yes
2.no
3. windows 10
4.windows device manager
5.my ide version 1.8.19
So what does Windows device manager think of your board?
And you did not answer (6). We would like / need to know of you have an original / clone with 16U2 or a clone with another TTL-to-USB converter.
Additional questions that I forgot.
- What was all connected to the board when it started failing? Drawing will help.
- How was it powered? USB only? External and USB? Drawing will help.
i don't know because it's my brother kit
he is also forgot -
actually I'm connecting my board to 12v power supply also but unfortunately forgot to connect fuse, it's external power supply
but now board are connect it's led and TX,RX EVERY LED glove correctly but only thing port only not showing in my pc -
I think I'm ever thing shared in upside message line
OK, I would like to know the model of the chip closest to the USB port.
Is it square like shown or rectangular with pins only on two sides. To read the type, you will have to angle it in good light and possibly take a macro photo (if your phone / camera has that functionality) to be able to read. The square one is possibly Atmel 16U2, a rectangular one probably a CH340.
If your board is not detected, that chip has probably died. The 16U2 seems to be very prone to power issues (not saying that you can't kill a CH340).
A fuse in the 12V line will protect the power supply, not your board. Was nothing else connected like motors, solenoids, relays etc.
My chip rectangular and removal one is atmel atmega328p pu
