My UNO is only playing 1 line of my script
when i try to listen to this script on my Piezzo on Pin 8 it only read 1 line and not all the music can someone help me?
#include “pitches.h”
// notes in the melody:
int melody = {
NOTE_D4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_D4,
NOTE_A3, NOTE_C4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_E4, NOTE_F4, NOTE_F4,
NOTE_F4, NOTE_G4, NOTE_E4, NOTE_E4, NOTE_D4, NOTE_C4, NOTE_C4, NOTE_D4,
0, NOTE_A3, NOTE_C4, NOTE_B3, NOTE_D4, NOTE_B3, NOTE_E4, NOTE_F4,
NOTE_F4, NOTE_C4, NOTE_C4, NOTE_C4, NOTE_C4, NOTE_D4, NOTE_C4,
NOTE_D4, 0, 0, NOTE_A3, NOTE_C4, NOTE_D4, NOTE_D4, NOTE_D4, NOTE_F4,
NOTE_G4, NOTE_G4, NOTE_G4, NOTE_A4, NOTE_A4, NOTE_A4, NOTE_A4, NOTE_G4,
NOTE_A4, NOTE_D4, 0, NOTE_D4, NOTE_E3, NOTE_F4, NOTE_F4, NOTE_G4, NOTE_A4,
NOTE_D4, 0, NOTE_D4, NOTE_F4, NOTE_E4, NOTE_E4, NOTE_F4, NOTE_D4
// note durations: 4 = quarter note, 8 = eighth note, etc.:
int noteDurations = {
4,8,4,8,4,8,8,8,8,4,8,4,8,4,8,8,8,8,4,8,4,8,
4,8,8,8,8,4,4,8,8,4,4,8,8,4,4,8,8,
8,4,8,8,8,4,4,8,8,4,4,8,8,4,4,8,4,
8,4,8,8,8,4,4,4,8,4,8,8,8,4,4,8,8
// iterate over the notes of the melody:
for (int thisNote = 0; thisNote < 8; thisNote++) {
// to calculate the note duration, take one second divided by the note type.
//e.g. quarter note = 1000 / 4, eighth note = 1000/8, etc.
int noteDuration = 1000 / noteDurations[thisNote];
tone(8, melody[thisNote], noteDuration);
// to distinguish the notes, set a minimum time between them.
// the note’s duration + 30% seems to work well:
int pauseBetweenNotes = noteDuration * 1.30;
delay(pauseBetweenNotes);
// stop the tone playing:
noTone(8);
// no need to repeat the melody.
How many notes would you expect this to play?
Steve
This for loop will only play 8 notes. You can either change 8 to the number of notes in the melody array, or (my preferred method) would be to add -1 at the end of the melody array (don’t forget to add a comma at the end of the previous line) and then change the for loop to:
for (int thisNote = 0; melody[thisNote] != -1; thisNote++) {
This method allows you change the notes without having to change the count in the for loop.
Pete
Or
#define NOTES (sizeof(melody)/sizeof(int))  // standard C idiom for static array element count
for (int thisNote = 0; thisNote < NOTES; thisNote++) {
Change this line:
for this line:
for (int thisNote = 0; thisNote < 88; thisNote++) {
It should then work as you expect it. I changed it minimally so you recognize your code but you should really use multidimensional arrays if you expect to use fixed size note packets, so you can mix sequences easier.
