I want to share my version of the processing protocol Modus Slava RTU
Kandiral Ruslan
https://kandiral.ru
KRModbusRTUSlaveUART0min.h
Ver.: 1.0
https://kandiral.ru/arduino/modbus_slave_na_arduino.html
#ifndef KRMODBUSRTUSLAVE_H_
#define KRMODBUSRTUSLAVE_H_
#if ARDUINO >= 100
#include <Arduino.h>
#else
#include <WProgram.h>
#endif
#if defined(UBRRH) && defined(UBRRL)
#define ubrrh &UBRRH
#define ubrrl &UBRRL
#define ucsra &UCSRA
#define ucsrb &UCSRB
#define ucsrc &UCSRC
#define udr &UDR
#else
#define ubrrh &UBRR0H
#define ubrrl &UBRR0L
#define ucsra &UCSR0A
#define ucsrb &UCSR0B
#define ucsrc &UCSR0C
#define udr &UDR0
#endif
#include "KRRegisters.h"
#define MB_READ_TIMEOUT 50
#define MB_WEIT_RESP_TIME 5
#define MBRTU_MAX_BUF 17
uint8_t mbDataBuffer[MBRTU_MAX_BUF];
volatile uint16_t _mb_crc=0xFFFF;
volatile uint8_t mbDataBufferPos, mbDataBufferCount=0;
volatile bool MBDenyRX=false;
void MBCRC(byte bt){
_mb_crc ^= bt;
uint16_t _mb_crc_flag;
for(uint8_t j = 0; j < 8; j++) {
_mb_crc_flag = _mb_crc & 0x0001;
_mb_crc >>=1;
if(_mb_crc_flag)_mb_crc ^= 0xA001;
#if defined(USART_RX_vect)
ISR(USART_RX_vect)
#elif defined(USART0_RX_vect)
ISR(USART0_RX_vect)
#elif defined(USART_RXC_vect)
ISR(USART_RXC_vect) // ATmega8
#else
#error "Don't know what the Data Received vector is called for Serial"
#endif
if(!(*ucsra & (1 << UPE0))){
uint8_t bt=*udr;
if(MBDenyRX || mbDataBufferCount==MBRTU_MAX_BUF)return;
mbDataBuffer[mbDataBufferCount++]=bt;
if(mbDataBufferCount>2)MBCRC(mbDataBuffer[mbDataBufferCount-3]);else _mb_crc = 0xFFFF;
}else *udr;
#if defined(UART0_UDRE_vect)
ISR(UART0_UDRE_vect)
#elif defined(UART_UDRE_vect)
ISR(UART_UDRE_vect)
#elif defined(USART0_UDRE_vect)
ISR(USART0_UDRE_vect)
#elif defined(USART_UDRE_vect)
ISR(USART_UDRE_vect)
#else
#error "Don't know what the Data Register Empty vector is called for Serial"
#endif
if(mbDataBufferPos<mbDataBufferCount){
*udr=mbDataBuffer[mbDataBufferPos++];
*ucsra |= 1 << TXC0;
if(mbDataBufferPos==mbDataBufferCount){
*ucsrb &= ~(1 << UDRIE0);
MBDenyRX=false;
class KRModbusRTUSlave{
private:
KRRegisters *regs;
uint8_t addr;
uint8_t prvBytes;
uint32_t tm, tm0;
public:
KRModbusRTUSlave(KRRegisters ®isters, uint8_t addr_){
regs = ®isters;
addr=addr_;
prvBytes=0;
void begin(uint32_t baudRate){
uint16_t wd=(F_CPU / 4 / baudRate - 1) / 2;
*ucsra = 1<<U2X0;
if (((F_CPU == 16000000UL) && (baudRate == 57600)) || (wd >4095)){
*ucsra = 0;
wd = (F_CPU / 8 / baudRate - 1) / 2;
*ubrrh = wd >> 8;
*ubrrl = wd;
*ucsrc = (1<<UCSZ01) | (1<<UCSZ00);
*ucsrb = (1<<RXCIE0)|(1<<RXEN0)|(1<<TXEN0);
void _DO();
void KRModbusRTUSlave::_DO(){
uint8_t bytes=prvBytes;
prvBytes=mbDataBufferCount;
if(prvBytes==0)return;
uint32_t ctm=millis();
if (bytes!=prvBytes) {
if(bytes==0)tm0=ctm + MB_READ_TIMEOUT;
tm = ctm + MB_WEIT_RESP_TIME;
return;
if(ctm<tm0 && ctm<tm)return;
MBDenyRX=true;
if(prvBytes<4 || (byte)_mb_crc != mbDataBuffer[prvBytes-2] || (byte)(_mb_crc >> 8) != mbDataBuffer[prvBytes-1] || (mbDataBuffer[0]>0 && mbDataBuffer[0]!=addr)){
prvBytes=0;
MBDenyRX=false;
return;
uint16_t index, len, reg16;
uint8_t i,n;
_mb_crc = 0xFFFF;
mbDataBuffer[0]=addr;
MBCRC(mbDataBuffer[0]);
MBCRC(mbDataBuffer[1]);
switch(mbDataBuffer[1]){
case 0x03:
case 0x04:
index=(((uint16_t)mbDataBuffer[2] << 8) | mbDataBuffer[3]);
len=(((uint16_t)mbDataBuffer[4] << 8) | mbDataBuffer[5]);
prvBytes=3;
mbDataBuffer[2]=len*2;
MBCRC(mbDataBuffer[2]);
for(i=index;i<index+len;i++){
reg16=regs->read(i);
mbDataBuffer[prvBytes]=reg16 >> 8;
MBCRC(mbDataBuffer[prvBytes]);
prvBytes++;
mbDataBuffer[prvBytes]=reg16;
prvBytes++;
case 0x06:
index=((mbDataBuffer[2] << 8) | mbDataBuffer[3]);
reg16=((mbDataBuffer[4] << 8) | mbDataBuffer[5]);
regs->write(index,reg16);
MBCRC(mbDataBuffer[3]);
MBCRC(mbDataBuffer[4]);
MBCRC(mbDataBuffer[5]);
prvBytes=6;
case 0x10:
len=((mbDataBuffer[4] << 8) | mbDataBuffer[5]);
prvBytes=6;
n=0;
reg16=mbDataBuffer[6]>n?mbDataBuffer[n+7]:0;
n++;
reg16=(reg16 << 8) | (mbDataBuffer[6]>n?mbDataBuffer[n+7]:0);
n++;
regs->write(i,reg16);
default:
prvBytes=3;
mbDataBuffer[1]= mbDataBuffer[1] | (uint8_t)128;
mbDataBuffer[2]=1; // ILLEGAL FUNCTION
_mb_crc = 0xFFFF;
mbDataBuffer[prvBytes++] = (byte)_mb_crc;
mbDataBuffer[prvBytes++] = (byte)(_mb_crc >> 8);
mbDataBufferCount=prvBytes;
prvBytes=0;
mbDataBufferPos=0;
if(*ucsra & (1<<UDRE0)){
mbDataBufferPos=1;
*udr = mbDataBuffer[0];
*ucsrb |= 1 << UDRIE0;
#endif // KRMODBUSRTUSLAVE_H_
A detailed example of use can be found here.Modbus Slave на Arduino
