since yesterday it is not more possible to upload any sketch to the board. The linux side works without problems.
The red led on the board is lit continuously. I know this problem from my uno and mega time the bootloader is not responding.
But I get now error messages only the hint uploading.
I tried a reset with the on board buttons but nothing happens.
Have anyone a suggestion.
thanks for your reply. I used my MAC and I connected the yun by usb. I got no error messages nothing. The yun hangs in the upload. The ide shows only the message that uploading will be done.
The red LED is on. It is possible to connect the Linux side by WIFI. It seems like bootloader problem in the AVR.
thanks for your answer. I have a MAC there is no COM Port available. I tried all existing ports for my
yun /dev/cu.usbmodem.. and /dev/tty.usbmodem. I developed over more than 3 weeks without any problems.
thanks it works, great. Now it's possible again to load sketches. I ordered yesterday a new yun. :-(, because I thought it is not possible to reset the bootloader. For my opinion it is necessary to provide this solution in the documentation. I have another UNO and Mega in the drawer with same problem. How can I reset the bootloader from uno and mega?
Greetings
Andreas
As Federico said, an AVR programmer will allow you to re-burn the bootloader. Here are a couple of common AVR programmers available in the USA. There should be something similar available where you are. Check eBay, there are some inexpensive programmers available from China.
The process for burning the bootloader is well documented. Try a Google search for it.
you ask me what do you do to crash the yun. I reproduce this errors.
If in the sketch is a programming error and you use the serial monitor and you get a never-ending output. In this case it is not possible to upload any new sketch. The serial interface of AVR is blocked. Just only helps your solution.
Sorry, I don't get it.
zaxarias asked about how you could corrupt the bootloader.
You are saying you cannot upload a new sketch while you keep the serial port open to watch the linux side running (did I get that right?).
I think the two issues are not related, but I may miss something. Do I?
In my sketch I declared a dynamic char array with not enough space for a given String(this was my mistake). I put a greater char in it (in this case without null termination). Then I make Serial.println on this field and I get never ending output on the monitor.
The red LED is on and new upload is not possible.
Try it or ask again.
