Windows 10
Arduino IDE 1.8.12
Was learning to create libraries and ran into an issue when using "Sketch...Include Library...Add .ZIP Library"
The library name is t_OS and here is the structure...
t_OS
t_OS\examples
t_OS\src
t_OS\keywords.txt
t_OS\library.properties
t_OS\examples\t_OS_Basic
t_OS\examples\t_OS_Basic\t_OS_Basic.ino
t_OS\src\t_OS.cpp
t_OS\src\t_OS.h
So to when I first created the ZIP file , I right-click on the directory t_OS, select Send To, then Compressed (zipped) folder.
Creating the t_OS.zip file using this method, the t_OS.zip will import successfully into the Arduino IDE.
I wanted to automate the process using a Windows powershell script.
I create another t_OS.zip using powershell and get the following error when importing into the Arduino IDE.
Any help would be appreciated.
Regards,
John
Arduino: 1.8.12 (Windows 10), Board: "SparkFun RedBoard Turbo"
Arduino Version: 1.8.12
java.io.FileNotFoundException: C:\Users\FLIGHT~1\AppData\Local\Temp\arduino_797132\t_OS154132\t_OS\examples (The system cannot find the path specified)
at java.io.FileOutputStream.open0(Native Method)
at java.io.FileOutputStream.open(FileOutputStream.java:270)
at java.io.FileOutputStream.(FileOutputStream.java:213)
at java.io.FileOutputStream.(FileOutputStream.java:162)
at processing.app.tools.ZipDeflater.deflate(ZipDeflater.java:50)
at processing.app.Base.handleAddLibrary(Base.java:2366)
at processing.app.Base$6.actionPerformed(Base.java:1114)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886)
at java.awt.Component.processMouseEvent(Component.java:6539)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6304)
at java.awt.Container.processEvent(Container.java:2239)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2297)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4904)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4535)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4476)
at java.awt.Container.dispatchEventImpl(Container.java:2283)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
at java.awt.EventQueue$4.run(EventQueue.java:733)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
file1 t_OS.zip (1.9 KB)
file2 t_OS.zip (1.73 KB)
