my
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "\.\COM3": The semaphore timeout period has expired.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
:frowning:
(deleted)
at IDE tools/ports, check what port the system "sees". if many ports displayed, select the most high value (eg com22).
if the board are you using is a clone, you may need drivers so PC to "see" the usb chip.
