myFirstLibrary, miles out?
We all like blinky things, and I like a 'breathing' LED on projects when it fits in..
I've added it to a couple of different things now, so decided to use it to make a library.
I've got the functionality as I want it (i think), but I'm not sure I'm going about it in a great way. I may have over-complicated it a tad. Could anyone spare their time to share any thoughts or tips please?
Breathe.h
#include "Arduino.h"														// let us use Arduino
#ifndef Breathe_h															// guard against library being included twice
#define Breathe_h
class Breathe{
public:
	Breathe(byte debugOn,int LEDPin,byte brMin,byte brMax,byte brUpdateTime, byte brStep);
	void maintain();															// makes changes to LED brightness, maintains breathing
	void stop();																// stops breathing
	byte _debugOn;															// if 1/true enables debugging, if 0/false disables debugging messages
private:
	byte _breathingIn;														// direction of led fade (breathing in=getting brighter)
	int _LEDPin;																// LED pin
	byte _brMin;																// minimum brightness
	byte _brMax;																// maximum brightness
	byte _brUpdateTime;													// ms between brightness updates
	byte _brLvl;																// current brightness level
	byte _brStep;															// amount to increment/decrement brightness for each update
	byte _breathing;															// currently breathing? (last breath out or stopped if not)
	unsigned long _brCurTime;											// current time(ms)
	unsigned long _lstbrUpdateTime;									// last time brightness changed
#endif
Breathe.cpp
#include "Breathe.h"
Breathe::Breathe(byte debugOn,int LEDPin, byte brMin,byte brMax,byte brUpdateTime, byte brStep){
	_debugOn=debugOn;
	_breathingIn=true;														// direction of led fade (breathing in=getting brighter)
	_brStep=brStep;
	_brCurTime=millis();
	_lstbrUpdateTime=0;													// last time breath brightness changed
	_LEDPin=LEDPin;
	_brMin=brMin;
	_brMax=brMax;
	_brUpdateTime=brUpdateTime;
	_brLvl=_brMin;
	_breathing=true;
	if(_debugOn){																// send message over serial
		Serial.print("Breathe_starting:	");
		Serial.print("LEDPin ");
		Serial.print(_LEDPin);
		Serial.print("brMin ");
		Serial.print(_brMin);
		Serial.print(" brMax ");
		Serial.print(_brMax);
		Serial.print(" brUpdateTime ");
		Serial.println(_brUpdateTime);
	pinMode(_LEDPin, OUTPUT);										// make LED pin an output
	analogWrite(_LEDPin, _brLvl);										// write lowest brightness value
	_lstbrUpdateTime=_brCurTime;									// record time brightness was updated
void Breathe::maintain(){
	_brCurTime=millis();													// record current time
	if(_brCurTime>=_lstbrUpdateTime+_brUpdateTime){		// if it's time to breathe
		if(_breathing){
				Serial.print("Breathe_maintain:	");
			if(_breathingIn){													// brightness increasing
				if(_brLvl>=_brMax-_brStep){							// hit the end, stop and go back
					_brLvl=_brMax;
					_breathingIn=false;
				} else {															// keep going
					_brLvl=_brLvl+_brStep;
			} else {																// brightness decreasing
				if(_brLvl<=_brMin+_brStep){							// hit the end, stop and go back
					_brLvl=_brMin;
					_breathingIn=true;
					_brLvl=_brLvl-_brStep;
		} else if (_brLvl>=_brMin){										// last breath out, stopping
				Serial.print("Breath_stop:	");
			if(_brLvl<=_brMin){												// write 0 to LED
				_brLvl=0;
				analogWrite(LED_BUILTIN, _brLvl);
				_breathingIn=true;											// reset for new breath
		if(_debugOn&&_brLvl>=_brMin){								// send message over serial
			Serial.print("breathingIn ");
			Serial.print(_breathingIn);
			Serial.print(" brLvl ");
			Serial.print(_brLvl);
			Serial.print(" uptime(ms) ");
			Serial.println(millis());
		if(_brLvl>0){															// if not writing 0
		_lstbrUpdateTime=_brCurTime;								// record last updated time
void Breathe::stop(){
	_breathing=false;
Breathe.ino
#include <Breathe.h>														// include the breathe library
Breathe breathing(true,LED_BUILTIN,1,155,50,5);				// start breathing (byte debugging true/false 1/0, int LED pin, byte min brightness (use >1), byte max brightness, byte update every ms, byte move by 5)
void setup(){
	Serial.begin(115200);													// start serial monitor for USB debugging
void loop(){
	breathing.maintain();													// keep breathing, must be called repeatedly
	if(millis()==5000){
		breathing._debugOn=false;										// flip debugging on/off while breathing
	if(millis()==10000){
		breathing.stop();													// stop breathing
Breathe.zip (2.54 KB)
Don't cross-post.
If this is just something for your own use you may not need to create a library with the complications that entails . Just put your code in a separate .ino file and put a copy of that file in whichever project you want to use it with.
...R
Other thread removed.
Thanks, I'd created it in better suited place and somehow missed removing the first.
Robin2:
...R
It's a learning exercise, it doesn't need to be a library but thanks for the easy approach-it's often exactly what I'd be after.
mad_tunes:
Breathe.cpp
_debugOn=debugOn;
_brStep=brStep;
_LEDPin=LEDPin;
_brMin=brMin;
_brMax=brMax;
_brLvl=_brMin;
_breathing=true;
	if(_breathing){
				_brLvl=_brMax;
				_breathingIn=false;
				_brLvl=_brMin;
				_breathingIn=true;
			_brLvl=0;
_breathing=false;
I guess I have not been on this forum for so long that I am not totally jaded.
I understand why you wrote the library if even as a learning experience as the title suggests it is your first library.
I downloaded it and some of the first things I have noticed is you are using the built in LED which is a digital pin not a analog pin at least on my Duemilanove I am testing this on. Second you have hard coded LED_BUILTIN for your analogWrites in your Breathe.cpp file. Nothing to hard for me to change but wanted to let you know.
I for one don't think its too bad for a first library. Yea sure it might be a little over the top but hey if you have good examples then I guess its up to the end user to trim it down if they want or to not use it at all.
I think its cool anyway. Even though my vote counts for SQUAT here.
Thanks a lot and well spotted Tekati
