Myoware doesn't work
Good catch Tom.
Those solder joints look less than ideal as well. You should test them with a multimeter.
Igor1409:
Tom, I used this connection scheme (this scheme from medium.com tutorial). Is it wrong?
This image is incorrect. The GND pin is the middle one on the sensor labeled “-”.
Tengo el mismo problema con el sensor, no me funciona, estoy leyendo todo lo que han comentado, pero sigue sin funcionar el sensor myoware, hay alguna solución?
