The myoware shield when connected disconnects the arduino uno from being visible or seen as connected. Although it is still connected. When I have the myoware shield on the uno and connect them together they are undetectable. Why is the myoware shield blocking the connection and how do I fix it?
Welcome to the forum
Your topic was MOVED to its current forum category which is more appropriate than the original as it has nothing to do with Installation and Troubleshooting of the IDE
You can wait for a helper knowing the stuff You talk about or You can read and follow this link: How to get the best out of this forum - Using Arduino / Project Guidance - Arduino Forum
I don't know what You're talking about. Show a logic block diagram explaining the setup, post links to datasheets of the stuff You use.
The myoware shield is attached to the arduino uno. they are both then attached to the pc. The pc does not recognize them as a device.
The arduino uno is recognized as a device when it is by itself so it is an issue with the shield being seen as a second device or blocking the uno from being recognized.
