mySerial.write(55);
If you have a lot of printing todo example :
mySerial.write(55);
mySerial.write(54);
mySerial.write(55);
mySerial.write(56);
Is there any memory to be saved by going
uint8_t var1 = 55;
mySerial.write(var1);
mySerial.write(54);
mySerial.write(56);
Thanks D
You can test that yourself; just compile it and see what the IDE tells you about memory usage.
I've placed your snippets in loop()
First one:
Sketch uses 2,566 bytes (7%) of program storage space. Maximum is 32,256 bytes.
Global variables use 124 bytes (6%) of dynamic memory, leaving 1,924 bytes for local variables. Maximum is 2,048 bytes.
Second one:
Without context it's difficult to say what is the correct approach. Where do the numbers come from? Below a different way
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3);
byte values2print[] = {55, 54, 55, 56};
  mySerial.begin(115200);
  for (byte cnt = 0; cnt < sizeof(values2print); cnt++)
    mySerial.write(values2print[cnt]);
Sketch uses 2,562 bytes (7%) of program storage space. Maximum is 32,256 bytes.
Global variables use 128 bytes (6%) of dynamic memory, leaving 1,920 bytes for local variables. Maximum is 2,048 bytes.
Sketch uses 2,616 bytes (8%) of program storage space. Maximum is 32,256 bytes.
This however only tells part of the story. Although it looks like the latter uses less memory, that is not true; at the moment that loop() is called, the array is created and hence you will have to add 4 bytes to the reported memory usage.
You can place the array in PROGMEM to save RAM.
Delta_G:
Why not just:
Serial.print(F("7678"));
That puts it in PROGMEM and saves a ton of code.
Bit difficult if it isn't ascii :wink: The example data is, but that is just example data :slight_smile:
