Hello everyone,
I am trying to connect ESP32-CAM to MySQL database, first I did it successfully when the MySQL sever is running on my laptop and both ESP32-CAM and my laptop are connecting to the same WiFi network.
When I tried to connect ESP32-CAM to MySQL server existed in another laptop existed in another city, the connection was failed.
Does MySQL library have the ability to allow remote connection to MySQL? I just need to make sure the whole idea can be done to start figuring out the problem of connection - whether they are some settings on MySQL server, firewall or etc.
here is the code,
#include <WiFi.h> // Use this for WiFi instead of Ethernet.h
#include <MySQL_Connection.h>
#include <MySQL_Cursor.h>
IPAddress server_addr(192,168,***,**); // IP of the MySQL *server* here
char user[] = "****"; // MySQL user login username
char password[] = "****"; // MySQL user login password
// WiFi card example
char ssid[] = "Barahim"; // your SSID
char pass[] = "*******"; // your SSID Password
const char QUERY_POP[] = "SELECT platenumber FROM users.cars";
char query[128];
WiFiClient client;
MySQL_Connection conn((Client *)&client);
while (!Serial); // wait for serial port to connect. Needed for Leonardo only
// Begin WiFi section
Serial.printf("\nConnecting to %s", ssid);
WiFi.begin(ssid, pass);
Serial.print(".");
// print out info about the connection:
Serial.println("\nConnected to network");
Serial.print("My IP address is: ");
Serial.print("Connecting to SQL... ");
if (conn.connect(server_addr, 3306, user, password))
Serial.println("OK.");
Serial.println("FAILED.");
delay(10000);
Serial.println("> Running SELECT with dynamically supplied parameter");
// Initiate the query class instance
MySQL_Cursor *cur_mem = new MySQL_Cursor(&conn);
// Supply the parameter for the query
// Here we use the QUERY_POP as the format string and query as the
// destination. This uses twice the memory so another option would be
// to allocate one buffer for all formatted queries or allocate the
// memory as needed (just make sure you allocate enough memory and
// free it when you're done!).
sprintf(query, QUERY_POP, 9000000);
// Execute the query
cur_mem->execute(query);
// Fetch the columns and print them
column_names *cols = cur_mem->get_columns();
for (int f = 0; f < cols->num_fields; f++) {
Serial.print(cols->fields[f]->name);
if (f < cols->num_fields-1) {
Serial.print(',');
// Read the rows and print them
row_values *row = NULL;
do {
row = cur_mem->get_next_row();
if (row != NULL) {
Serial.print(row->values[f]);
Serial.print(',');
} while (row != NULL);
// Deleting the cursor also frees up memory used
delete cur_mem;
