Hello everyone i have a problem with my project.
I try to read data transmitted by a sensor with SPI link (MISO MOSI CS CLCK) on my Sparkfun board plugged on an Arduino MEGA. Also work in the library Seeed_Arduino_CAN.
I realized the attached code but after debugging and from what I observe in the console I am blocked at the level of my void loop :
unsigned char len = 0;
unsigned char buf[8];
if (CAN_MSGAVAIL == CAN.checkReceive()) { // check if data coming
CAN.readMsgBuf(&len, buf); // read data, len: data length, buf: data buf
unsigned long canId = CAN.getCanId();
Apparently the problem is the : if (CAN_MSGAVAIL == CAN.checkReceive()) I tried to replace the == by != and my code works but I get false values... and i dont know what to do.
I give you my complete code here with which I get the following result on my console :
15:41:34.730 -> CAN init ok!
15:41:34.776 -> SD card is present & ready
15:41:34.776 -> File created!
#include <SPI.h>
#include <SD.h>
#include <TimeLib.h>
#include "mcp2515_can.h"
//*********************CAN Sheild declarations*********************
const int SPI_CS_PIN = 53;
const int CAN_INT_PIN = 2;
mcp2515_can CAN(SPI_CS_PIN);
//*********************SD Sheild declarations**********************
File myFile;
const int SD_CS_PIN = 9;
//*********************Record Excel declarations*******************
char filename[16];
unsigned long reads_recorded = 0;
uint16_t i = 0;
//*********************Switch and Led declarations*****************
const int buttonPin = 40; // the number of the pushbutton pin
const int ledPin = 41; // the number of the LED pin
//********************* Program SETUP *****************************
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
SERIAL_PORT_MONITOR.begin(115200);
while (CAN_OK != CAN.begin(CAN_500KBPS, MCP_16MHz)) { // init can bus : baudrate = 500k
SERIAL_PORT_MONITOR.println("CAN init fail, retry...");
while (1); //wait here forever
SERIAL_PORT_MONITOR.println("CAN init ok!");
if (SD.begin(SD_CS_PIN))
SERIAL_PORT_MONITOR.println("SD card is present & ready");
//initialise filename
sprintf(filename, "can_%.03d.csv", i);
myFile = SD.open(filename, FILE_WRITE);
if (myFile) // it opened OK
//add header to file
myFile.println("Time,Pression,Temperature,co2_hydrogen,humidity");
myFile.close();
SERIAL_PORT_MONITOR.println("File created!");
SERIAL_PORT_MONITOR.println("Error opening file");
SERIAL_PORT_MONITOR.println("SD card missing or failure");
pinMode(CAN_INT_PIN, INPUT);
//********************* Fonction ecrire dans Excel ***********************
void writeToFile(float press_pascal, float temp_degC, float co2_true, float humi_pourcent)
myFile.print(String(minute()));
myFile.print(":");
myFile.print(String(second()));
myFile.print(";");
myFile.print(String(press_pascal, 2));
myFile.print(";");
myFile.print(String(temp_degC, 2));
myFile.print(";");
myFile.print(String(co2_true, 2));
myFile.print(";");
myFile.println(String(humi_pourcent, 2));
myFile.close();
//********************* Program LOOP ************************
if (digitalRead(buttonPin) == HIGH)
if(CAN_MSGAVAIL == CAN.checkReceive())
digitalWrite(ledPin, HIGH); // turn LED on
SERIAL_PORT_MONITOR.println("_____Pression_____");
uint16_t press_raw;
memcpy(&press_raw, &buf[0], 2); //buf[0] is the first byte in buf, 2 because you want 2 bytes
float press_pascal = ((press_raw * 0.0078125) - 250);
SERIAL_PORT_MONITOR.println(press_pascal, 2); // value to copy on excel
SERIAL_PORT_MONITOR.println("_____Temperature_____");
uint16_t temp_raw;
memcpy(&temp_raw, &buf[2], 2); //buf[2] is the third byte in buf, 2 because you want 2 bytes
float temp_degC = ((temp_raw * 0.3125) - 273) / 100;
SERIAL_PORT_MONITOR.println(temp_degC, 2);
SERIAL_PORT_MONITOR.println("_____CO2_Hydrogen_____");
uint16_t co2_raw;
memcpy(&co2_raw, &buf[4], 2); //buf[4] is the fifth byte in buf, 2 because you want 2 bytes
float co2_true = ((co2_raw * 1) - 0) / 100;
SERIAL_PORT_MONITOR.println(co2_true, 2);
SERIAL_PORT_MONITOR.println("_____Humidity_%_____");
uint16_t humi_raw;
memcpy(&humi_raw, &buf[6], 2); //buf[6] is the six byte in buf, 1 because you want 1 bytes
float humi_pourcent = ((humi_raw * 0.4) - 0);
SERIAL_PORT_MONITOR.println(humi_pourcent, 2);
writeToFile(press_pascal, temp_degC, co2_true, humi_pourcent);
++reads_recorded;
digitalWrite(ledPin, LOW); // turn LED off
//********************* Creation new files excel ***********************
//create new filenames for every 1800 lines written to file
if(reads_recorded == 1800) { //reset counter
reads_recorded = 0;
//increment file counter
++i;
//update finename
//add header to new file
myFile.close();
SERIAL_PORT_MONITOR.println("New File created!");
Sorry the code is a bit long because the project is almost entirely coded but I still have this problem to solve I hope someone can help me
