With SKIP_NONE Nothing is skipped, and the stream is not touched unless the first waiting character is valid. So if you have CR or LF as the first byte then you won’t read anything.
Are you sure the Serial Monitor was configured the right way ? What’s your line ending?
Yes indeed, but what makes no sense is that it gets the first digit, but not the second. I did try inserting a delay to make sure everything would have been received, but it made no difference.
I would like to do an experiment designed to see if it's the difference in UART chips or the difference in bootloaders that selects the problem. I would connect power, ground, Tx and Rx from the FTDI module directly to the corresponding pins on the Nano. If the Nano still works, then the FTDI isn't the problem. But of course the Nano's CH340 is still connected to Rx and Tx, and I don't know if that could result in a short. Do you think that's safe to try?
I've tried all four options. None of them work. I still just get the first digit. This is just crazy.
// IRCaptureRaw.ino Rev 2
// for ATmega328P processors (Uno, Nano, ProMini - 8 or 16MHz)
// This captures incoming IR from a remote control as raw data.
// An IR receiver module should be connected to D8.
// The Adjust variable adjusts time between On and Off periods since
// receivers may turn on faster than they turn off, or vice versa.
// Results will include any repeats.
// The displayed numbers alternate between transmitting and idle states.
const int maxEntries = 650;
unsigned int bitTime[maxEntries]; // store uSeconds in each state
int Adjust = 40, newAdjust; // receiver turn on, turn off times not the same
const byte recvPin = 8;
volatile unsigned int timerMSB, capMSB; // third byte of 24-bit timer (ICR1 = 1st two)
volatile bool Capture; // a state change occurred, and time was captured
unsigned long timerLO, timerHI, newTime, prevTime;
int i, j, k, maxMSB;
bool activeLO; // receiver output is low when receiving carrier
bool Waiting, Start, nothing;
Serial.begin (115200);
pinMode(recvPin, INPUT_PULLUP);
activeLO = true; // assume no transmission happening now
if (!digitalRead(recvPin)) activeLO = false;
maxMSB = 30 >> (F_CPU == 8000000); // capture time = 1 sec
Serial.println(maxMSB);
cli();
TCCR1A = 0; // set up Timer1
TCCR1B = 0;
TCCR1C = 0;
TCNT0 = 0; // clear Timer1
TIFR1 = 0xFF; // clear flags
TIMSK1 = 0b00100001; // enable capture and overflow interrupt (GPS)
TCCR1A = 0b00000000; // Normal mode, no output, WGM #0
sei();
Start = true;
if(Start) { // initialize everything on start or restart
Start = false;
i = 0;
j = 1;
Waiting = true;
Capture = false;
nothing = false;
cli();
if (activeLO) TCCR1B = 0b00000010; // falling edge capture, timer1 on, prescale /8
else TCCR1B = 0b01000010; // rising edge capture, timer1 on, prescale /8
TIFR1 = 0xFF; // clear flags register
sei();
Serial.print(F("Adjust = ")); Serial.println(Adjust);
Serial.println(F("Enter new Adjust value, or [Enter]"));
while (!Serial.available());
if((Serial.peek() == 13) || (Serial.peek() == 10)) nothing = true;
newAdjust = Serial.parseInt(SKIP_NONE); // Adjust can be negative
if ((newAdjust) || !nothing) Adjust = newAdjust;
while(Serial.available()) Serial.read();
Serial.println(F("Waiting for IR transmission..."));
TIMSK0 = 0; // Disable Timer0 interrupts (millis)
if (Waiting) { // keep MSB cleared
if (timerMSB) timerMSB = 0;
if(Capture) { // input has changed state
Capture = false;
Waiting = false;
timerLO = ICR1; // read timer values
timerHI = capMSB;
newTime = (timerHI << 16) + timerLO; // combine timer counts to one long value
if (maxMSB == 30) newTime = (newTime +1) >> 1;
if (i) { // skip i=0
bitTime[i] = newTime - prevTime; // collect duration and activity state
prevTime = newTime; // prepare for next state change
TCCR1B ^= 0b01000000; // switch to capture on opposite edge
i++;
if ((timerMSB > maxMSB) || (i > maxEntries)) { // collect data for one second after first
TCCR1B &= 0xFE; // stop Timer1 clock
TIMSK0 = 1; // resume millis interrupt
for (k = 1; k < i; k++) { // adjust on (Mark) and off (Space) times
if (k & 1) bitTime[k] -= Adjust; // shift Adjust from On to Off
else bitTime[k] += Adjust;
Serial.println(); // display output
Serial.println(F(" On Off On Off On Off On Off"));
while (j < i) {
for (k = 0; k < 8; k++) {
Serial.print(" ");
if (bitTime[j] <10000) Serial.print(" ");
if (bitTime[j] < 1000) Serial.print(" ");
if (bitTime[j] < 100) Serial.print(" ");
if (bitTime[j] < 10) Serial.print(" ");
Serial.print (bitTime[j]);
j++;
if (j == i) break;
else Serial.print (",");
Start = true;
ISR(TIMER1_CAPT_vect) {
capMSB = timerMSB; // also capture MSB at same instant
Capture = true;
ISR(TIMER1_OVF_vect) {
timerMSB++; // increment MSB on overflow
I have further information. Instead of trying to see if the Nano produces the same problem with the FTDI UART module, I dug out a CP2102 UART module, and a CH340G UART module from my junque box, and tried both of them with the Pro Mini.
And I have the same single-character response with both of them as I did with the FTDI module. So I think that narrows it down to either the bootloader and fuses, or something the IDE is doing in compiling for the Pro Mini that it isn't doing for the Nano.
I should have said that this is a 3.3V 8MHz Pro Mini from 2016, and I'm pretty sure the 328P is genuine. But I've never actually looked at the bootloader, and I need to do that. And I'm running IDE v1.8.8. The Boards.txt file says the bootloader for the 5V 16MHz Pro Mini is the same as the Nano Old Bootloader. But the 8MHz Pro Mini has a different bootloader, so perhaps there's a problem there.
