mystery toy - uses photocells to play music when light changes
Hi, I have a kids toy that uses a photocell. When the photocell is covered up, it plays a sound. When the photocell is exposed to light again, the sound plays again.
How is this being done? I often would like to monitor a low-to-high or high-to-low transition on an analog pin for a microcontroller, but I don't want to keep reading the analog input; that would kill battery consumption. Is there a trick to translating the transition from low voltage (say ~.4V or less) to high voltage (~vcc-0.5), and turning that into a digital wake up from sleep?
I know some fancier microcontroller have ULP processors that can do analog pin reading capabilities. But I'm interested in learning a way to do this with hardware.
Thanks!
I am not sure where the toy has anything to do with anything. Can you simply state your objective without using the toy as an example ?
to save power. * Run MPU @ 1Mhz * use the sleep function
Which MPU ? The Arduino clock speed is configurable . I have never used other clock speeds with the UNO but have used many different clock speeds with ATtiny85s. Did you look at this?
or
this ?
I would use a micropower op amp as a comparator to monitor the photocell voltage divider, and wake up the processor when a certain light level is reached.
Are you talking about "hacking " the toy ?
Maybe a schmitt trigger ckt would work.
Just use a capacitor to change a level change into a pulse.
Hi, Configure the LDR potential divider to be below logic 0 threshold volts with dark and above logic 1 threshold volts when light.
Tom... :)
