MyTimer.ino:4:19: fatal error: Timer.h: No such file or directory
I'm trying to get a simple timer to work and found a timer example on the Arduino site. It calls timer.h.
I have timer.h in my program files but i get an error "no such file or directory" I'm using Arduino UNO and 1.6.5.
Here's the link to the example i'm trying to duplicate: http://playground.arduino.cc/Code/Timer
Here's my sample code that will not run
#include "timer.h"
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
You have to download and install the library from https://github.com/JChristensen/Timer - did you do this?
Here i have attached timerlibray , you need to unzip this library folder in to library folder of arduino .
Then try to upload code
timer.zip (33.7 KB)
Thanks for the replys
I've downloaded the ZIP file--how did you know to go there and get it? I didn't see anything in the playground.arduino about this
I added the code ... /code around my post--cool how it ads a Code section.
Thanks again
Kris
I am using library fro gps communication & real time application. ofcourse support from forum team
KrisKasprzak: ...
I've downloaded the ZIP file--how did you know to go there and get it? I didn't see anything in the playground.arduino about this ...
Kris
1) You got the code from the User Code Library. Since it is user code, it isn't included in the IDE download 2) On that page it tells you where to go to get the library.
Installation
You can download the library from here:
As with all libraries, unzip the file into the 'libraries' folder in your Arduino directory, which will be in something like 'My Documents\Arduino' on Windows, 'Documents/Arduino' on Mac etc. If this is the first library you have installed, you will need to create a directory there called 'libraries'.
man i fill silly... I just looked at the code and stopped there.
Thanks again.
PS... this Arduino stuff is addicting, I've recently bought a SD shield, and a 20 x 4 display comes in today. I'm like a kid in a candy store :)
