DELETEdeleteDELETEDELETEdeleteDELETEee
Verify all five devices independently, then verify again when each device is added.
- Arduino
- motor shield
- HC-06
- QTR (first emitter, second emitter, then both emitters)
- PID
thank you for respond.
Uno-A0 and A1 don't work.
Motor shield-find
HC06-TXD work,RXD not work
QTR-fine i use only 4 analog pin
PID-fine
Show the two, minimum sketches that show these pins do not work.
this is test code on HC06.
N/A
I don't have skate for that yet. I also beware of RXD using 3.3 V and VCC 5V.
Does your motor shield use these pins for another device?
it doesn't use for another device, its empty. i tried all analog pin (motor shild mount on Uno) only A0 and A1 get low read rate unleash the another get high read rate.
Do your devices work with the Arduino when the motor shield is removed?
Sounds like it is working. Pololu says:
strong reflectance, such as when the sensor is over a white surface, its output voltage will tend towards 0 V
Here is the QTR application notes page:
