N-channel MOSFET protection!?
I want to use a logic level N-Channel MOSFET as a switch for a externally powered RGB LED strip. But I don't know if I must protect the MOSFET or not! If I must protect it can someone tell me how to protect it please. :) Thank you :)
GoldenClick: I want to use a logic level N-Channel MOSFET as a switch for a externally powered RGB LED strip. But I don't know if I must protect the MOSFET or not! If I must protect it can someone tell me how to protect it please. :) Thank you :)
I think it depends on what you want to protect it against. Eg... like too much current through it. Or applying the wrong polarity voltages across pairs of its terminals etc.
A led strip is not an inductive load so putting a flyback diode across the load is not going to accomplish anything because a led strip does not generate back EMF.
If the mosfet is used correctly there is no need to protect it from reverse polarity.
Use a fuse that blows when a current passes through it that is too high.
