hey all
I'm currently converting a vintage 60's desk rotary phone into a mobile phone. I have the handset and bells worked out, and the only thing that is confusing me is programming the rotary dial - to - keyboard thing. Basically, for each number you spin on the dial, you get a closed switch opening for around 0.05 seconds or so, the number of which depends on what was dialled (1 = 1, 5 = 5, 0 = 10 etc) with the switch closing for 0.05 seconds between each signal, and the time between each number is 0.5 seconds, and after 3 seconds of no action, the 'call' button is activated. That's the input. The output is 'pressing the buttons' on an old Nokia, or contacting a ground terminal with one of eleven (0 - 9 and 'call') terminals.
So:
[DIGITAL INPUT (pulses of open circuitness)] -> [identified and translated to the mobile (like a switch, connecting gnd and the associated terminal)] -> [if time between set of pulses is >1 sec, start new number] -> [if no pulses for 3 secs, activate call] .
I can do the turnoff bit physically, with the contacts that are activated when the handset is put down. XD
The only code I know is Morse :P, and although I know this can be done with arduino, I don't know how to write the code to do this. If you can help, it'd be appreciated.
Thanks.
