Im just starting to work with arduinos and I having an issue. I have gotten n64 controller to work with a servo motor but i can't figure out a way to make the servo motor not reset with the position of the joystick because i want to control another servo on the other axis of the n64 controllers joystick along with having the first servo stay at its location.
Here is my code i based it off the knob/N64 code i find. there is more to it just ran out of room
int i;
unsigned char data, addr;
// Command to send to the gamecube
// The last bit is rumble, flip it to rumble
// yes this does need to be inside the loop, the
// array gets mutilated when it goes through N64_send
unsigned char command[] = {0x01};
// don't want interrupts getting in the way
noInterrupts();
// send those 3 bytes
N64_send(command, 1);
// read in data and dump it to N64_raw_dump
N64_get();
// end of time sensitive code
interrupts();
// translate the data in N64_raw_dump to something useful
translate_raw_data();
for (i=0; i<16; i++) {
Serial.print(N64_raw_dump*, DEC);*
int i;
noInterrupts();
N64_get();
interrupts();
Serial.print(N64_raw_dump, DEC);
Serial.print(' ');
Serial.print(N64_status.stick_x, DEC);
Serial.print(' ');
Serial.print(N64_status.stick_y, DEC);
Serial.print(" \n");
// Serial.print(" Stick X:");
// Serial.print(N64_status.stick_x, DEC);
// Serial.print(" Stick Y:");
//Serial.println(N64_status.stick_y, DEC);
// DEBUG: print it
//print_N64_status();
delay(25);
val = map(N64_status.stick_y , -90, 90, 0, 180);
myservo.write(val);
delay(15);
Also. You code only contains the code to move one server "myservo".
Please post the code with 2 servo's that you say doesn't work.
If your code is too big to post (which seems odd as the limit is 9000 or more characters), upload your ino file
I believe that to the people that don't care about the rules and don't care about read the rules don't deserve a answer different that "read the rules". I read the rules before starting post why they don't need to read it?
click the MODIFY button in the upper right of the post window.
Highlight all you code.
click the "#" CODE TAGS button on the toolbar above just to the left of the QUOTE button.
click SAVE (at the bottom).
When you post code on the forum, please make a habit of using the code tags "#" button.
Here is the code i figured out the motor issue and it resetting. another thing i am thinking since i can control two motors on a joystick can i control another set when the A button (N64_status.data2) is pressed and held. any tips thanks and sorry for not following the rules im new to the forums.
int i;
noInterrupts();
N64_get();
interrupts();
Serial.print(N64_raw_dump[i], BIN);
Serial.print(' ');
Serial.print(N64_status.stick_x, BIN);
Serial.print(' ');
Serial.print(N64_status.stick_y, BIN);
// Serial.print(N64_status.stick_x, BIN);
//Serial.println(N64_status.stick_y, BIN);
if (N64_status.data1 == LOW)
controlServoX();
controlServoY();
controlServoX2();
controlServoY2();
// DEBUG: print it
delay(25);
void controlServoX) {
if (N64_status.stick_x > 10 && currentServoPosition >=0)
currentServoPosition = currentServoPosition - 90; //can change the number to make it move quicker
else if (N64_status.stick_x > 90 && currentServoPosition >= 0){
//Do nothing the servo is already at its max
else if (N64_status.stick_x < -10 && currentServoPosition < 180){
currentServoPosition = currentServoPosition + 15; //can change the number to make it move quicker
else if (N64_status.stick_x < -10 && currentServoPosition >= 180){
else{
//Do nothing Stick is roughly centre
myservo.write(currentServoPosition);
void controlServoY() {
if (N64_status.stick_y > 10 && currentServoPosition >=0)
else if (N64_status.stick_y > 90 && currentServoPosition >= 0){
else if (N64_status.stick_y < -10 && currentServoPosition < 180){
else if (N64_status.stick_y < -10 && currentServoPosition >= 180){
else{
myservo1.write(currentServoPosition);
void controlServoX2() {
if (N64_status.data1 == HIGH)
else{
myservo2.write(currentServoPosition);
void controlServoY2() {
else{
myservo3.write(currentServoPosition);
