N64PadtoUSB Code not Appearing as Gaming HID
Libraries Used:
ArduinoJoystickLibrary
N64PadForArduino
Board: Genuine Arduino Micro
OS: Windows 10 64bit
Issue: Windows doesn't see Micro as a Gaming HID
This code is from the creator of the N64Pad library and can be found in the examples on the git page linked above. It compiles fine and when uploaded to the Micro, the leds perform as expected and the code at 144
if ((pad.buttons & N64Pad::BTN_LRSTART) != 0) {
flashes the led as expected, so the board is "seeing" the N64 controller. But that's it- nothing else happens.
When the N64PadDump code is uploaded, it performs as expected, displaying all pressed buttons in the serial monitor. When the GCPadToUSB code is uploaded, windows reports a new usb gaming device has been plugged in, and it shows up in the Game Controllers interface. I have been staring at this sketch and comparing it to the GCPad code, and I can't see anything out of place.
The author of the code responded to the same issue by saying that they don't know anything about Windows, so I'm posting here. Thanks for your time!
 * This file is part of N64Pad for Arduino.                                    *
 * Copyright (C) 2015-2021 by SukkoPera                                        *
 * N64Pad is free software: you can redistribute it and/or modify              *
 * it under the terms of the GNU General Public License as published by        *
 * the Free Software Foundation, either version 3 of the License, or           *
 * (at your option) any later version.                                         *
 * N64Pad is distributed in the hope that it will be useful,                   *
 * but WITHOUT ANY WARRANTY; without even the implied warranty of              *
 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the               *
 * GNU General Public License for more details.                                *
 * You should have received a copy of the GNU General Public License           *
 * along with N64Pad. If not, see <http://www.gnu.org/licenses/>.              *
 * This sketch shows how the library can be used, together with the Arduino
 * Joystick Library, to turn a N64 controller into an USB one that can be used
 * on PCs or on a Raspberry Pi running a N64 emulator :).
 * For details on the Arduino Joystick Library, see
 * https://github.com/MHeironimus/ArduinoJoystickLibrary.
#include <N64Pad.h>
#include <Joystick.h>
/** \brief Dead zone for analog sticks
 * If the analog stick moves less than this value from the center position, it
 * is considered still when it emulates the D-Pad.
 * \sa ANALOG_IDLE_VALUE
const byte ANALOG_DEAD_ZONE = 20U;
/** \brief Analog sticks minimum value
 * Minimum value reported by analog sticks. This usually means that the stick is
 * fully either at the top or left position. Note that some sticks might not get
 * fully down to this value.
 * Note that this should actually b -128 to 127, however, the true Nintendo 64
 * controller range is about 63% of it (mechanically limited), so the actual
 * range is about -81 to 81. Worn controllers might report even less, so we are
 * leaving this here for easy customization.
 * \sa ANALOG_MAX_VALUE
const int8_t ANALOG_MIN_VALUE = -80;
/** \brief Analog sticks maximum value
 * Maximum value reported by analog sticks. This usually means that the stick is
 * fully either at the bottom or right position. Note that some sticks might not
 * get fully up to this value.
 * \sa ANALOGI_MIN_VALUE
const int8_t ANALOG_MAX_VALUE = 80;
/** \brief Analog sticks idle value
 * Value reported when an analog stick is in the (ideal) center position. Note
 * that old and worn-out sticks might not self-center perfectly when released,
 * so you should never rely on this precise value to be reported.
 * \sa ANALOG_MIN_VALUE
const int8_t ANALOG_IDLE_VALUE = 0;
N64Pad pad;
Joystick_ usbStick (
	JOYSTICK_DEFAULT_REPORT_ID,
	JOYSTICK_TYPE_MULTI_AXIS,
	10,			// buttonCount
	0,			// hatSwitchCount (0-2)
	true,		// includeXAxis
	true,		// includeYAxis
	false,		// includeZAxis
	true,		// includeRxAxis
	true,		// includeRyAxis
	false,		// includeRzAxis
	false,		// includeRudder
	false,		// includeThrottle
	false,		// includeAccelerator
	false,		// includeBrake
	false		// includeSteering
bool mapAnalogToDPad = false;
#define deadify(var, thres) (abs (var) > thres ? (var) : 0)
void flashLed (byte n) {
	for (byte i = 0; i < n; ++i) {
		digitalWrite (LED_BUILTIN, LOW);
		delay (40);
		digitalWrite (LED_BUILTIN, HIGH);
		delay (80);
void setup () {
	pinMode (LED_BUILTIN, OUTPUT);
	// Init Joystick library
	usbStick.begin (false);		// We'll call sendState() manually to minimize lag
	usbStick.setXAxisRange (ANALOG_MIN_VALUE, ANALOG_MAX_VALUE);
	usbStick.setYAxisRange (ANALOG_MIN_VALUE, ANALOG_MAX_VALUE);
	usbStick.setRxAxisRange (ANALOG_MIN_VALUE, ANALOG_MAX_VALUE);
	usbStick.setRyAxisRange (ANALOG_MAX_VALUE, ANALOG_MIN_VALUE);		// Analog is positive UP on controller, DOWN in joystick library
void loop () {
	static boolean haveController = false;
	if (!haveController) {
		if (pad.begin ()) {
			// Controller detected!
				haveController = true;
				delay (333);
		if (!pad.read ()) {
			// Controller lost :(
			// Controller was read fine
				// This combo toggles mapAnalogToDPad
				mapAnalogToDPad = !mapAnalogToDPad;
				flashLed (2 + (byte) mapAnalogToDPad);
				// Map buttons!
				usbStick.setButton (0, (pad.buttons & N64Pad::BTN_B) != 0);
				usbStick.setButton (1, (pad.buttons & N64Pad::BTN_A) != 0);
				usbStick.setButton (2, (pad.buttons & N64Pad::BTN_C_LEFT) != 0);
				usbStick.setButton (3, (pad.buttons & N64Pad::BTN_C_DOWN) != 0);
				usbStick.setButton (4, (pad.buttons & N64Pad::BTN_C_UP) != 0);
				usbStick.setButton (5, (pad.buttons & N64Pad::BTN_C_RIGHT) != 0);
				usbStick.setButton (6, (pad.buttons & N64Pad::BTN_L) != 0);
				usbStick.setButton (7, (pad.buttons & N64Pad::BTN_R) != 0);
				usbStick.setButton (8, (pad.buttons & N64Pad::BTN_Z) != 0);
				usbStick.setButton (9, (pad.buttons & N64Pad::BTN_START) != 0);
				if (!mapAnalogToDPad) {
					// D-Pad makes up the X/Y axes
					if ((pad.buttons & N64Pad::BTN_UP) != 0) {
						usbStick.setYAxis (ANALOG_MIN_VALUE);
					} else if ((pad.buttons & N64Pad::BTN_DOWN) != 0) {
						usbStick.setYAxis (ANALOG_MAX_VALUE);
						usbStick.setYAxis (ANALOG_IDLE_VALUE);
					if ((pad.buttons & N64Pad::BTN_LEFT) != 0) {
						usbStick.setXAxis (ANALOG_MIN_VALUE);
					} else if ((pad.buttons & N64Pad::BTN_RIGHT) != 0) {
						usbStick.setXAxis (ANALOG_MAX_VALUE);
						usbStick.setXAxis (ANALOG_IDLE_VALUE);
					// The analog stick gets mapped to the X/Y rotation axes
					usbStick.setRxAxis (pad.x);
					usbStick.setRyAxis (pad.y);
					// Both the D-Pad and analog stick control the X/Y axes
					if ((pad.buttons & N64Pad::BTN_UP || pad.y > ANALOG_DEAD_ZONE) != 0) {
					} else if ((pad.buttons & N64Pad::BTN_DOWN || pad.y < -ANALOG_DEAD_ZONE) != 0) {
					if ((pad.buttons & N64Pad::BTN_LEFT || pad.x < -ANALOG_DEAD_ZONE) != 0) {
					} else if ((pad.buttons & N64Pad::BTN_RIGHT || pad.x > ANALOG_DEAD_ZONE) != 0) {
				// All done, send data for real!
				usbStick.sendState ();
