Nail Biting Sensor Help!...
Hello,
I am trying to understand which exact Arduino I should use... my requirements are simple, I need two parts basically.
  1. A tiny sensor with buzzer to put on the collar of the shirt. (smallest possible...)
  2. A (magnetic?) part to wear on the finger. like a ring...
whenever the ring part is coming close to the collar part, the buzzer should go off...
so that if a person doen't notice that if he is biting his nails / pulling hair from his heard / touching the face often. the buzzer should pull his attention.
is this possible at all? which kit / sensor / parts do I need to accomplish this.
Thanks in advance...
Sounds like you could do everything with a arduino Uno, a buzzer, and a hall effect sensor. Although, there would probably be wires everywhere.
I would suggest making it vibrate rather than beep. Use an Arduino GEMMA or the FLORA and the hall effect sensor. You'll need a ring with a rare earth magnet in it too.
The only problem I can see with hall effect is proximity, dependent on strength of magnet you may have to get within a few centimeters of the sensor to trigger it. A magnetometer might be more suited as the sensitivity is greater...
Perhaps an NFC ring and suitable sensor?
