Name change upon button click
I have written a programme in which display print change upon button clicking.
but some time print change twice upon single click, i dont found any solution please help me.
My code is
#include <LiquidCrystal.h>
const byte buttonPin = 7;
int buttonPushCounter = 0; // counter for the number of button presses
boolean buttonState = LOW; // current state of the button
boolean lastButtonState = LOW; // previous state of the button
// lcd constructor made global in scope so the whole program can sse it
LiquidCrystal lcd(32, 30, 28, 26, 24, 22);
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.setCursor(0, 0);
lcd.print("Hi I am Robocook");
lcd.setCursor(5, 2);
lcd.print("2018");
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
// read the pushbutton input pin:
buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
if (buttonState != lastButtonState)
if (buttonState == HIGH)
// if the current state is HIGH then the button
// went from off to on:
buttonPushCounter++; // add one to counter
lcd.clear();
if (buttonPushCounter > 3) // if couter over 3 reset the counter to 1 to show "Jon"
// and not "Hello All"
buttonPushCounter = 1;
Serial.println(buttonPushCounter);
switch (buttonPushCounter) // choose what to display based on buttonPushCounter value
case 0:
lcd.print("I am Robocook"); // show "Hello All until first button press
case 1:
lcd.print("Ram");
case 2:
lcd.print("Jimmy");
case 3:
lcd.print("Sid");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
You probably want some button debouncing.
Just to test if that is the problem, you can change this:
to this:
    delay( 100) ;
If that solves the problem, then restructure the logic so the sketch does not accept a button press, if the last accepted button press was less than 100 mS ago.
ok i will let you soon
this worked for me , thanks sir :slight_smile:
OK. That was for testing. Generally, although there can be exceptions, it is not a good idea to have delay() statements in the loop.
